    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
    • A
      almightyyoshi @MMRIZE
      @MMRIZE
      Thanks for the help. I actually just had to specify singleday and fullday along with the calendar name, which I’m ashamed I didn’t think of before.
        sfb
        @MMRIZE Sorry if this has already been reported: I just installed MMM-CalendarExt3 and it appears to be listing my calendar events (Google Calendar .ics) in reverse order (events on each day are listed from latest to earliest). Not sure what additional information is helpful, but I’m using month view, locale is en-US, using timeFormat: 12, and this is all that’s in my module config:
        			module: "MMM-CalendarExt3",
        			position: "bottom_center",
        			title: "",
        				mode: "month",
        				instanceId: "basicCalendar",
        				locale: 'en-US',
        				maxEventLines: 5,
        				firstDayOfWeek: 1,
        				calendarSet: ['work', 'home', 'us-holidays', "leisure"],
        Any idea what might be happening? Thank you!
        • S sfb referenced this topic on
          sfb @sfb
          @MMRIZE I found the discrepancy! It show up in the correct order on Chromium based browsers, however is in the reverse order when viewed on Firefox.
          @sfb said in MMM-CalendarExt3:
          			title: "",
          				mode: "month",
          				locale: 'en-US',
          				maxEventLines: 5,
          				firstDayOfWeek: 1,
          M 1 Reply Last reply
            MMRIZE @sfb
            @sfb
            interesting symptom.
            I suspect some CSS property compatibility issues.(maybe -webkit and -moz diffrence) I’ll look inside at what happens in Firefox. Anyway, MM is supposed to work on Electron in standalone mode, So I regard Chromium as a de facto standard environment of MM.
              sfb @MMRIZE
              @MMRIZE Thanks for looking into it! Totally understandable. I’ve been testing MM serving from a docker container and viewed in various environments, so it’s not a typical setup.
              • N
                nmacd
                I am very new to this so I apologize if this is a dumb question. I love the layout here, but I am having an issue getting the weekly calendar to populate. I have the default calendar and its working, but what I am trying to do is to have my google account show up in the weekly.
                Thanks, and again I am sorry if this is simple. Any help would be appreciated.
                  MMRIZE @nmacd
                  @nmacd
                  mode: 'week',
                  in the config section of the module would be that.
                  Could you upload your config here to let me see what you were trying?
                  N 1 Reply Last reply
                  • N
                    nmacd @MMRIZE
                    @MMRIZE
                    module: “calendar”,
                    position: “top_center”,
                    broadcastPastEvents: true, // <= IMPORTANT to see past events
                    url: “https://calendar.google.com/calendar/”,
                    name: “Calendar”, // <= RECOMMENDED to assign name
                    color: “red” // <= RECOMMENDED to assign color
                    		title: "",
                    			mode: "month",
                    			locale: 'en-US',
                    			maxEventLines: 5,
                    			firstDayOfWeek: 1,
                    			calendars: ['https://calendar.google.com/'] -
                    I have my calendar string in there from google I just deleted the identifier.
                    As you can see the calendar event test is showing top center, but is not on the calendar.
                    I like the current view just would like the calendar to populate.
                    Also in my config file everything is lined up just didn’t transfer well.
                    Thanks again for your patience
                    M 2 Replies Last reply
                      MMRIZE @nmacd
                      @nmacd
                      I think your google calendar has so many events, so the past old events(years or months ago events) would be also huge numbers. They might consume all the quota of ‘maximumEntries’. Probably that is not the bug of the default calendar module, but also not expected behaviors.
                      Anyway someone said it would be fixed in 2.21. I wish that upgrade could fix this kind of issue.
                      Until then, adjust your maximumEvents and maximumNumberOfDays to include recent events to the broadcasted notification.
                      N S 2 Replies Last reply
                      • emloweE
                        emlowe Module Developer
                        CX3? I’m still using OG CX …
                        I couldn’t get CX2 to do what I was doing with CX so I never upgraded at all - it still runs, but it does have trouble parsing some kinds of calendar items.
                        I use OG CX to do
                        1. A single Day scrolling view for my 7" “Desktop MM” - not much screen space on the 7" screen so can only show a single day on one half in a scrolling loop
                        2. A 3-day view for the Kitchen Family Screen - an entire week makes things too small so you cannot see easily - a 3 day view fits nicely though and can use a nice large font
                        I’ll agree that CX2 was crazy complicated to configure though - and I gave up trying to get it look like I wanted.
                        • N
                          nmacd @MMRIZE
                          @MMRIZE
                          So i got rid of all the events and only left the one for the “test” on 8/28 and the results are the same. Nothing is showing up in the actual calendar.
                          I will keep working on it, my guess is I am missing something simple.
                            sdetweil @MMRIZE
                            @MMRIZE I am the one that caused the bug in 2.20, fixed in 2.21 oct 1
                            if u want to test the develop branch
                            see
                            https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
                              MMRIZE @nmacd
                              @nmacd
                              I found what’s wrong.
                              calendars: ['https://calendar.google.com/'],
                              You need to set the names of calendar, in this case you assigned “Calendar” as the name of your google calendar.
                              So it should be calendarSet:[‘Calendar’], . Or just leave as blank([]) to get all the calendars.
                                sdetweil @MMRIZE
                                @MMRIZE as this is the 3rd or 4th time users have had trouble with this
                                you should put out a debugging message
                                unable to locate calendar with name property equal to “???”
                                maybe list the names you found…
                                luisestradaL 1 Reply Last reply
                                • luisestradaL
                                  luisestrada @sdetweil
                                  Hi @sdetweil @MMRIZE
                                  This used to be possible before, but after implementing the weather icons, it stopped working. It’s not a big deal but it’s a nice to have feature.
                                  As you know, MagicMirror uses a very old version of Font Awesome. I updated mine to the most recent version and it now includes the Canadian flag and many other brand icons. Unfortunately, for brands, you have to use “fas” or “fa-solid”, and for brands you have to use “fab” or “fa-brands”. I solved this by tweaking the code in calendar.js and config.js. I also tried to do the same in MMM-CalendarEXT3.js, line 242, but when I try to update config.js calendar module, the calendar shows no data. The reason, because MMM-CalendarEXT3 module does not accept spaces in symbol.
                                  CalendarEXT3.js, line 242:
                                  symbol.className = "fa fa-fw fa" + s;
                                  config.js, for birthday calendar
                                  symbol: "s fa-cake-candles",
                                  config.js, for Canadian holidays
                                  symbol: "b fa-canadian-maple-leaf",
                                  The space breaks my code, I wanted to choose either “b” or “s” in the symbol field
                                  How the icons look in the native calendar
                                  Unfortunately, not allowing spaces, forces me to decide which one to use or “fas” or “fab”
                                    MMRIZE @luisestrada
                                    @luisestrada
                                    Maybe line 472-473 needs to be modified to allow ‘fa-brand’ instead of fixed ‘fa-solid’. I’ll check in a few days.
                                      MMRIZE @luisestrada
                                      @luisestrada
                                      I fixed. Update your module.
                                      I don’t know your code modification, so I applied these syntaxes.
                                      /* In your default calendar config */
                                      symbol: ['fa-brands fa-canadian-maple-leaf'],
                                      /* or */
                                      symbol: ['brands canadian-maple-leaf'],
                                      /* of course below are also allowed */
                                      symbol: 'brands canadian-maple-leaf',
                                      /* But if you want multi-icons, use array */
                                      symbol: ['brands google-drive', 'solid calendar'],
                                      BKeyportB 1 Reply Last reply
                                      • BKeyportB
                                        BKeyport Module Developer @MMRIZE
                                        @MMRIZE
                                        any idea why I can’t use this icon in this situation to set it up?
                                        https://fontawesome.com/v5/icons/bowling-pins?s=solid
                                        module: "calendar", // Built in
                                        //position: "top_right",
                                        	broadcastEvents: true,
                                        	broadcastPastEvents: false,
                                        	fetchInterval: 30000,
                                        	maximumEntries: 20,
                                        	customEvents: [{keyword: 'bowling', symbol: 'bowling-pins'}],
                                        Do I need to do the transform on your side, is it something else?
                                        it does work with other icons, like “user”
                                        thanks!
                                        M luisestradaL 2 Replies Last reply
                                          MMRIZE @BKeyport
                                          @BKeyport
                                          I have no idea why this “bowling-pins” icon would not appear. maybe font-awesome CSS version issue?"
                                          • luisestradaL
                                            luisestrada @BKeyport
                                            @BKeyport It’s a Pro icon, do you pay for it?
                                            • 34
                                            • 35
                                            • 5 / 35
