    Electron v20 will coming with next release but...
    Scheduled Pinned Locked Moved Upcoming Features
    9 Posts 5 Posters 9.1k Views 5 Watching
    • bugsounetB
      bugsounet Banned
      Hi, @development, @sdetweil , @karsten13 , @MichMich
      That I see next release of MM² will received Electron v20.x
      I just make a warn with this version.
      I just discover that:
      We are not able to use electron-rebuild with some dependencies
      I tried to update many dependency for compiling but it’s failed on each time
      tested with node-gyp >= 8.4.0 , electron-rebuild >=3.2.8, node >= 16.15.0
      Impact of this ?
      sample, if a user use PIR Sensor, Some hotwords for controling with vocal MM²
      Result: they can’t use it because they can’t rebuild the dedicated module
      Can you leave some time for correct this by leave electron v19.x in next release ?
      Naturaly, I (or we) will try solve this situation before the next next release (~2023-01)
      Or this forum will have many issue … unsolved !
      Thanks for reading,
      @bugsounet
      S karsten13K 2 Replies Last reply Reply Quote 0
        sdetweil @bugsounet
        @bugsounet yes, the issue is really here
        https://github.com/nodejs/nan/issues/922#issuecomment-974779085
        epoll uses nan
        • karsten13K
          karsten13 @bugsounet
          @bugsounet said in Electron v20 will coming with next release but...:
          I think there is no choice so I will revert electron on develop branch back to v19 with next dependency update …
            sdetweil @karsten13
            @karsten13 I agree
            I opened this on epoll
            https://github.com/fivdi/epoll/issues/47
            it was closed as a dup of
            https://github.com/fivdi/epoll/issues/42, about a year old
            but have little hope
              sdetweil @karsten13
              @karsten13 @bugsounet
              I opened this MM issue
              https://github.com/MichMich/MagicMirror/issues/2903
                at least in the case of PIR, it appears
                MMM-PIR-Sensor-Lite works as it uses python for triggering
                https://github.com/grenagit/MMM-PIR-Sensor-Lite
                • kayakbabeK
                  kayakbabe
                  I saw on those github issues posed above that
                  “This will result in applications that use epoll/onoff being broken after Electron 12.”
                  That means most of the button and input sensor type magicmirror modules will probably break.
                  So, I"m kinda glad I broke my new button module. and found this info right after. I think I"m going to go with a python based script and bypass the node on/off and epoll. So back to the drawing board.
                    sdetweil @kayakbabe
                    @kayakbabe where do you see 12?
                    all is ok to 19
                    kayakbabeK 1 Reply Last reply Reply Quote 0
                    • kayakbabeK
                      kayakbabe @sdetweil
                      @sdetweil said in Electron v20 will coming with next release but...:
                      all is ok to 19
                      Top comment by David
