    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
    • luisestradaL
      luisestrada @BKeyport
      @BKeyport It’s a Pro icon, do you pay for it?
      • BKeyportB
        BKeyport Module Developer @luisestrada
        @luisestrada ahh, that must be it. Although I’ve had pro icons before.
        • luisestradaL
          luisestrada
          Thank you very much.
          It took me some time to figure out that I could use symbol: “blank”, to not to show any icon, I was getting an error because before, I was using symbol: null :beaming_face_with_smiling_eyes:
          It’s working exactly as I wanted :)
            MMRIZE
            Small news.
            Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
            • N
              nmacd @MMRIZE
              @MMRIZE Thank you all for your help! I got fresh copies of everything and was more careful when making changes, it now works which is great. The new issue I am having is it’s only displaying 11 appointments, 10 Google calendar and 1 US Holiday. When I delete an event the next one later down the calendar shows up. Is there a setting to set the max entries or something to that nature?
              • N
                nmacd @nmacd
                @nmacd My bad just found it, the default calendar had the limit, all set thanks again
                • T
                  techlady
                  Hi
                  I would like to know how to make the calendar smaller. As you can see in the picture, my tv is in portrait, and the calendar takes up a lot of space. Where and what changes in custom css could I make to make it smaller and more rectangular? Thank you.
                    MMRIZE @techlady
                    @techlady
                    Adjust ‘maxEventLines’ and ‘eventHeight’. The heighr of day cell would be calculated by maxEventLines x eventHeight.
                    • K
                      KD
                      Hi Guys,
                      Just installed a brand new MM instance and downloaded the latest MMM-CalendarExt3 but for some reason i get no entries from my google calendars…
                      I get entries if i setup MMM-CalendarExt2 or the default calendar but not on MMM-CalendarExt3…
                      Here is my Config
                        module: "MMM-CalendarExt3",
                        position: "bottom_center",
                          mode: "month",
                          instanceId: "basicCalendar",
                          locale: 'en-UK',
                      	fontSize: '25px',
                      	refreshInterval: 10000,
                          maxEventLines: 5,
                          firstDayOfWeek: 1,
                          calendarSet: ["KD", "Tini"],
                          broadcastPastEvents: true,
                      			className: "KD",
                      			url: "https://calendar.google.com/calendar/ical/basic.ics",
                      			color: "green"
                      			className: "tini",
                      			color: "pink"
                        sdetweil @KD
                        @KD if you use the calendar url in a browser, it should download a file, just text. you an edit that to see if there are events
                        • K
                          KD @sdetweil
                          @sdetweil Hi there - i can download the file by putting the URL in the browser and open it in Outlook and see the events…
                          Also, I use both URL’s in another 2 magic mirrors I have in the house… I’m confident it’s not the URL’s
                            sdetweil @KD
                            @KD ok, this looks like the bug I introduced in 2.20. fixed in 2.21, October 1
                            broadcastPastEvents loads up the past events then the new, and the bug cuts off after the 1st maximumEntries
                            so u have to increase maximum entries
                            • K
                              KD @sdetweil
                              @sdetweil Thanks Sam - do you mean “maxEventLines”?
                              If yes I have set them up to 10 now and still nothing
                                  mode: "month",
                                  locale: 'en-UK',
                              	fontSize: '25px',
                                  maxEventLines: 10,
                                  firstDayOfWeek: 1,
                                sdetweil @KD
                                @KD no in the base calendar module. default
                                maximumEntries defaults to 10,
                                that is where you have broadcastPastEvents:true
                                • K
                                  KD @sdetweil
                                  @sdetweil Thank you Sam, i tried that and still nothing…
                                  Here is my config now:
                                      mode: "month",
                                      locale: 'en-UK',
                                  	fontSize: '25px',
                                      maxEventLines: 10,
                                      firstDayOfWeek: 1,
                                      maximumEntries: 100,
                                  			className: "KD",
                                  			color: "green"
                                  			className: "tini",
                                  			color: "pink"
                                    sdetweil @KD
                                    @KD for the short term add
                                    position: “top_left”,
                                    to the calendar module location
                                    let’s make sure it is working
                                    • K
                                      KD @sdetweil
                                      @sdetweil Thanks Sam - I now get Loading… than “error in the calendar module check log for more details” and finally no upcoming events… not sure how I have broken it as it was working yesterday… i also tried to replace the default calendar with
                                      git checkout modules/default/calendar/calendar.js
                                      As per one of your other posts in the forum but got "updated 0 (zero) paths from the index…
                                        sdetweil @KD
                                        @KD u have to be I the MagicMirror folder for the git checkout to work
                                        you should not have changed that file anyhow
                                        all config is done thru config.js
                                        can u show the output where u start mm?
                                        either npm start
                                        or if you use pm2, then
                                        pm2 logs --lines=50
                                        calendarext3, gets it’s info from the default calendar. so if it has problems, then u get nothing
                                        • K
                                          KD @sdetweil
                                          @sdetweil here is an output from “npm start”
                                          kd@raspberrypi:~/MagicMirror $ npm start
                                          > magicmirror@2.20.0 start
                                          [11.09.2022 14:00.12.728] [LOG]   Starting MagicMirror: v2.20.0
                                          [11.09.2022 14:00.12.736] [LOG]   Loading config ...
                                          [11.09.2022 14:00.12.743] [LOG]   Loading module helpers ...
                                          [11.09.2022 14:00.12.745] [LOG]   No helper found for module: clock.
                                          [11.09.2022 14:00.12.747] [LOG]   No helper found for module: MMM-CalendarExt3.
                                          [11.09.2022 14:00.13.011] [LOG]   Initializing new module helper ...
                                          [11.09.2022 14:00.13.012] [LOG]   Module helper loaded: calendar
                                          [11.09.2022 14:00.13.013] [LOG]   No helper found for module: weather.
                                          [11.09.2022 14:00.13.554] [LOG]   Initializing new module helper ...
                                          [11.09.2022 14:00.13.556] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                                          [11.09.2022 14:00.13.558] [LOG]   All module helpers loaded.
                                          [11.09.2022 14:00.13.725] [LOG]   Starting server on port 8080 ...
                                          [11.09.2022 14:00.13.745] [LOG]   Server started ...
                                          [11.09.2022 14:00.13.747] [LOG]   Connecting socket for: calendar
                                          [11.09.2022 14:00.13.748] [LOG]   Starting node helper for: calendar
                                          [11.09.2022 14:00.13.749] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                                          [11.09.2022 14:00.13.750] [LOG]   Sockets connected & modules started ...
                                          [11.09.2022 14:00.14.038] [ERROR] Whoops! There was an uncaught exception...
                                          [11.09.2022 14:00.14.046] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                              at Server.setupListenHandle [as _listen2] (node:net:1372:16)
                                              at listenInCluster (node:net:1420:12)
                                              at GetAddrInfoReqWrap.doListen [as callback] (node:net:1559:7)
                                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
                                            code: 'EADDRINUSE',
                                            errno: -98,
                                            syscall: 'listen',
                                            address: '127.0.0.1',
                                            port: 8080
                                          [11.09.2022 14:00.14.048] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                          [11.09.2022 14:00.14.052] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                          [11.09.2022 14:00.14.099] [LOG]   Launching application.
                                          MESA-LOADER: failed to retrieve device information
                                          MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                          failed to load driver: kms_swrast
                                          MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                          failed to load swrast driver
                                          [11.09.2022 14:00.17.129] [LOG]   Shutting down server...
                                          [11.09.2022 14:00.17.136] [LOG]   Stopping module helper: calendar
                                          [11.09.2022 14:00.17.137] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                                            sdetweil @KD
                                            @KD yep, two copies running
                                            pm2 stop all
                                            then u can do npm start
                                            • 34
                                            • 35
                                            • 6 / 35
