    MMM-CalendarExt3
    689 Posts 82 Posters 3.2m Views 86 Watching
      MMRIZE @luisestrada
      @luisestrada
      I fixed. Update your module.
      I don’t know your code modification, so I applied these syntaxes.
      /* In your default calendar config */
      symbol: ['fa-brands fa-canadian-maple-leaf'],
      /* or */
      symbol: ['brands canadian-maple-leaf'],
      /* of course below are also allowed */
      symbol: 'brands canadian-maple-leaf',
      /* But if you want multi-icons, use array */
      symbol: ['brands google-drive', 'solid calendar'],
      • BKeyportB
        BKeyport Module Developer @MMRIZE
        @MMRIZE
        any idea why I can’t use this icon in this situation to set it up?
        https://fontawesome.com/v5/icons/bowling-pins?s=solid
        module: "calendar", // Built in
        //position: "top_right",
        	broadcastEvents: true,
        	broadcastPastEvents: false,
        	fetchInterval: 30000,
        	maximumEntries: 20,
        	customEvents: [{keyword: 'bowling', symbol: 'bowling-pins'}],
        Do I need to do the transform on your side, is it something else?
        it does work with other icons, like “user”
        thanks!
        M luisestradaL 2 Replies Last reply Reply Quote 0
          MMRIZE @BKeyport
          @BKeyport
          I have no idea why this “bowling-pins” icon would not appear. maybe font-awesome CSS version issue?"
          • luisestradaL
            luisestrada @BKeyport
            @BKeyport It’s a Pro icon, do you pay for it?
            • BKeyportB
              BKeyport Module Developer @luisestrada
              @luisestrada ahh, that must be it. Although I’ve had pro icons before.
              • luisestradaL
                luisestrada
                Thank you very much.
                It took me some time to figure out that I could use symbol: “blank”, to not to show any icon, I was getting an error because before, I was using symbol: null :beaming_face_with_smiling_eyes:
                It’s working exactly as I wanted :)
                  MMRIZE
                  Small news.
                  Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
                  • N
                    nmacd @MMRIZE
                    @MMRIZE Thank you all for your help! I got fresh copies of everything and was more careful when making changes, it now works which is great. The new issue I am having is it’s only displaying 11 appointments, 10 Google calendar and 1 US Holiday. When I delete an event the next one later down the calendar shows up. Is there a setting to set the max entries or something to that nature?
                    • N
                      nmacd @nmacd
                      @nmacd My bad just found it, the default calendar had the limit, all set thanks again
                      • T
                        techlady
                        Hi
                        I would like to know how to make the calendar smaller. As you can see in the picture, my tv is in portrait, and the calendar takes up a lot of space. Where and what changes in custom css could I make to make it smaller and more rectangular? Thank you.
                          MMRIZE @techlady
                          @techlady
                          Adjust ‘maxEventLines’ and ‘eventHeight’. The heighr of day cell would be calculated by maxEventLines x eventHeight.
                          • K
                            KD
                            Hi Guys,
                            Just installed a brand new MM instance and downloaded the latest MMM-CalendarExt3 but for some reason i get no entries from my google calendars…
                            I get entries if i setup MMM-CalendarExt2 or the default calendar but not on MMM-CalendarExt3…
                            Here is my Config
                              module: "MMM-CalendarExt3",
                              position: "bottom_center",
                                mode: "month",
                                instanceId: "basicCalendar",
                                locale: 'en-UK',
                            	fontSize: '25px',
                            	refreshInterval: 10000,
                                maxEventLines: 5,
                                firstDayOfWeek: 1,
                                calendarSet: ["KD", "Tini"],
                                broadcastPastEvents: true,
                            			className: "KD",
                            			url: "https://calendar.google.com/calendar/ical/basic.ics",
                            			color: "green"
                            			className: "tini",
                            			color: "pink"
                              sdetweil @KD
                              @KD if you use the calendar url in a browser, it should download a file, just text. you an edit that to see if there are events
                              • K
                                KD @sdetweil
                                @sdetweil Hi there - i can download the file by putting the URL in the browser and open it in Outlook and see the events…
                                Also, I use both URL’s in another 2 magic mirrors I have in the house… I’m confident it’s not the URL’s
                                  sdetweil @KD
                                  @KD ok, this looks like the bug I introduced in 2.20. fixed in 2.21, October 1
                                  broadcastPastEvents loads up the past events then the new, and the bug cuts off after the 1st maximumEntries
                                  so u have to increase maximum entries
                                  • K
                                    KD @sdetweil
                                    @sdetweil Thanks Sam - do you mean “maxEventLines”?
                                    If yes I have set them up to 10 now and still nothing
                                        mode: "month",
                                        locale: 'en-UK',
                                    	fontSize: '25px',
                                        maxEventLines: 10,
                                        firstDayOfWeek: 1,
                                      sdetweil @KD
                                      @KD no in the base calendar module. default
                                      maximumEntries defaults to 10,
                                      that is where you have broadcastPastEvents:true
                                      • K
                                        KD @sdetweil
                                        @sdetweil Thank you Sam, i tried that and still nothing…
                                        Here is my config now:
                                            mode: "month",
                                            locale: 'en-UK',
                                        	fontSize: '25px',
                                            maxEventLines: 10,
                                            firstDayOfWeek: 1,
                                            maximumEntries: 100,
                                        			className: "KD",
                                        			color: "green"
                                        			className: "tini",
                                        			color: "pink"
                                          sdetweil @KD
                                          @KD for the short term add
                                          position: “top_left”,
                                          to the calendar module location
                                          let’s make sure it is working
                                          • K
                                            KD @sdetweil
                                            @sdetweil Thanks Sam - I now get Loading… than “error in the calendar module check log for more details” and finally no upcoming events… not sure how I have broken it as it was working yesterday… i also tried to replace the default calendar with
                                            git checkout modules/default/calendar/calendar.js
                                            As per one of your other posts in the forum but got "updated 0 (zero) paths from the index…
                                            • 34
                                            • 35
                                            • 6 / 35
