    MMM-CalendarExt3
    689 Posts 82 Posters 3.3m Views 86 Watching
    • BKeyportB
      BKeyport Module Developer @luisestrada
      @luisestrada ahh, that must be it. Although I’ve had pro icons before.
      • luisestradaL
        luisestrada
        Thank you very much.
        It took me some time to figure out that I could use symbol: “blank”, to not to show any icon, I was getting an error because before, I was using symbol: null :beaming_face_with_smiling_eyes:
        It’s working exactly as I wanted :)
          MMRIZE
          Small news.
          Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
          N 1 Reply Last reply
          • N
            nmacd @MMRIZE
            @MMRIZE Thank you all for your help! I got fresh copies of everything and was more careful when making changes, it now works which is great. The new issue I am having is it’s only displaying 11 appointments, 10 Google calendar and 1 US Holiday. When I delete an event the next one later down the calendar shows up. Is there a setting to set the max entries or something to that nature?
            • N
              nmacd @nmacd
              @nmacd My bad just found it, the default calendar had the limit, all set thanks again
              • T
                techlady
                Hi
                I would like to know how to make the calendar smaller. As you can see in the picture, my tv is in portrait, and the calendar takes up a lot of space. Where and what changes in custom css could I make to make it smaller and more rectangular? Thank you.
                M 1 Reply Last reply
                  MMRIZE @techlady
                  @techlady
                  Adjust ‘maxEventLines’ and ‘eventHeight’. The heighr of day cell would be calculated by maxEventLines x eventHeight.
                  • K
                    KD
                    Hi Guys,
                    Just installed a brand new MM instance and downloaded the latest MMM-CalendarExt3 but for some reason i get no entries from my google calendars…
                    I get entries if i setup MMM-CalendarExt2 or the default calendar but not on MMM-CalendarExt3…
                    Here is my Config
                      module: "MMM-CalendarExt3",
                      position: "bottom_center",
                        mode: "month",
                        instanceId: "basicCalendar",
                        locale: 'en-UK',
                    	fontSize: '25px',
                    	refreshInterval: 10000,
                        maxEventLines: 5,
                        firstDayOfWeek: 1,
                        calendarSet: ["KD", "Tini"],
                        broadcastPastEvents: true,
                    			className: "KD",
                    			url: "https://calendar.google.com/calendar/ical/basic.ics",
                    			color: "green"
                    			className: "tini",
                    			color: "pink"
                      sdetweil @KD
                      @KD if you use the calendar url in a browser, it should download a file, just text. you an edit that to see if there are events
                      K 1 Reply Last reply
                      • K
                        KD @sdetweil
                        @sdetweil Hi there - i can download the file by putting the URL in the browser and open it in Outlook and see the events…
                        Also, I use both URL’s in another 2 magic mirrors I have in the house… I’m confident it’s not the URL’s
                          sdetweil @KD
                          @KD ok, this looks like the bug I introduced in 2.20. fixed in 2.21, October 1
                          broadcastPastEvents loads up the past events then the new, and the bug cuts off after the 1st maximumEntries
                          so u have to increase maximum entries
                          • K
                            KD @sdetweil
                            @sdetweil Thanks Sam - do you mean “maxEventLines”?
                            If yes I have set them up to 10 now and still nothing
                                mode: "month",
                                locale: 'en-UK',
                            	fontSize: '25px',
                                maxEventLines: 10,
                                firstDayOfWeek: 1,
                              sdetweil @KD
                              @KD no in the base calendar module. default
                              maximumEntries defaults to 10,
                              that is where you have broadcastPastEvents:true
                              • K
                                KD @sdetweil
                                @sdetweil Thank you Sam, i tried that and still nothing…
                                Here is my config now:
                                    mode: "month",
                                    locale: 'en-UK',
                                	fontSize: '25px',
                                    maxEventLines: 10,
                                    firstDayOfWeek: 1,
                                    maximumEntries: 100,
                                			className: "KD",
                                			color: "green"
                                			className: "tini",
                                			color: "pink"
                                  sdetweil @KD
                                  @KD for the short term add
                                  position: “top_left”,
                                  to the calendar module location
                                  let’s make sure it is working
                                  • K
                                    KD @sdetweil
                                    @sdetweil Thanks Sam - I now get Loading… than “error in the calendar module check log for more details” and finally no upcoming events… not sure how I have broken it as it was working yesterday… i also tried to replace the default calendar with
                                    git checkout modules/default/calendar/calendar.js
                                    As per one of your other posts in the forum but got "updated 0 (zero) paths from the index…
                                      sdetweil @KD
                                      @KD u have to be I the MagicMirror folder for the git checkout to work
                                      you should not have changed that file anyhow
                                      all config is done thru config.js
                                      can u show the output where u start mm?
                                      either npm start
                                      or if you use pm2, then
                                      pm2 logs --lines=50
                                      calendarext3, gets it’s info from the default calendar. so if it has problems, then u get nothing
                                      • K
                                        KD @sdetweil
                                        @sdetweil here is an output from “npm start”
                                        kd@raspberrypi:~/MagicMirror $ npm start
                                        > magicmirror@2.20.0 start
                                        [11.09.2022 14:00.12.728] [LOG]   Starting MagicMirror: v2.20.0
                                        [11.09.2022 14:00.12.736] [LOG]   Loading config ...
                                        [11.09.2022 14:00.12.743] [LOG]   Loading module helpers ...
                                        [11.09.2022 14:00.12.745] [LOG]   No helper found for module: clock.
                                        [11.09.2022 14:00.12.747] [LOG]   No helper found for module: MMM-CalendarExt3.
                                        [11.09.2022 14:00.13.011] [LOG]   Initializing new module helper ...
                                        [11.09.2022 14:00.13.012] [LOG]   Module helper loaded: calendar
                                        [11.09.2022 14:00.13.013] [LOG]   No helper found for module: weather.
                                        [11.09.2022 14:00.13.554] [LOG]   Initializing new module helper ...
                                        [11.09.2022 14:00.13.556] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                                        [11.09.2022 14:00.13.558] [LOG]   All module helpers loaded.
                                        [11.09.2022 14:00.13.725] [LOG]   Starting server on port 8080 ...
                                        [11.09.2022 14:00.13.745] [LOG]   Server started ...
                                        [11.09.2022 14:00.13.747] [LOG]   Connecting socket for: calendar
                                        [11.09.2022 14:00.13.748] [LOG]   Starting node helper for: calendar
                                        [11.09.2022 14:00.13.749] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                                        [11.09.2022 14:00.13.750] [LOG]   Sockets connected & modules started ...
                                        [11.09.2022 14:00.14.038] [ERROR] Whoops! There was an uncaught exception...
                                        [11.09.2022 14:00.14.046] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
                                            at Server.setupListenHandle [as _listen2] (node:net:1372:16)
                                            at listenInCluster (node:net:1420:12)
                                            at GetAddrInfoReqWrap.doListen [as callback] (node:net:1559:7)
                                            at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:73:8) {
                                          code: 'EADDRINUSE',
                                          errno: -98,
                                          syscall: 'listen',
                                          address: '127.0.0.1',
                                          port: 8080
                                        [11.09.2022 14:00.14.048] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                        [11.09.2022 14:00.14.052] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                        [11.09.2022 14:00.14.099] [LOG]   Launching application.
                                        MESA-LOADER: failed to retrieve device information
                                        MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                        failed to load driver: kms_swrast
                                        MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: cannot open shared object file: Permission denied (search paths /usr/lib/arm-linux-gnueabihf/dri:\$${ORIGIN}/dri:/usr/lib/dri)
                                        failed to load swrast driver
                                        [11.09.2022 14:00.17.129] [LOG]   Shutting down server...
                                        [11.09.2022 14:00.17.136] [LOG]   Stopping module helper: calendar
                                        [11.09.2022 14:00.17.137] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                                          sdetweil @KD
                                          @KD yep, two copies running
                                          pm2 stop all
                                          then u can do npm start
                                          • K
                                            KD @sdetweil
                                            @sdetweil Apologies yes i had a PM2 job in the background…
                                            Here is the fresh output:
                                            [11.09.2022 14:07.14.079] [LOG]   Starting MagicMirror: v2.20.0
                                            [11.09.2022 14:07.14.088] [LOG]   Loading config ...
                                            [11.09.2022 14:07.14.094] [LOG]   Loading module helpers ...
                                            [11.09.2022 14:07.14.097] [LOG]   No helper found for module: clock.
                                            [11.09.2022 14:07.14.099] [LOG]   No helper found for module: MMM-CalendarExt3.
                                            [11.09.2022 14:07.14.368] [LOG]   Initializing new module helper ...
                                            [11.09.2022 14:07.14.370] [LOG]   Module helper loaded: calendar
                                            [11.09.2022 14:07.14.371] [LOG]   No helper found for module: weather.
                                            [11.09.2022 14:07.14.976] [LOG]   Initializing new module helper ...
                                            [11.09.2022 14:07.14.978] [LOG]   Module helper loaded: MMM-BackgroundSlideshow
                                            [11.09.2022 14:07.14.979] [LOG]   All module helpers loaded.
                                            [11.09.2022 14:07.15.149] [LOG]   Starting server on port 8080 ...
                                            [11.09.2022 14:07.15.168] [LOG]   Server started ...
                                            [11.09.2022 14:07.15.170] [LOG]   Connecting socket for: calendar
                                            [11.09.2022 14:07.15.172] [LOG]   Starting node helper for: calendar
                                            [11.09.2022 14:07.15.173] [LOG]   Connecting socket for: MMM-BackgroundSlideshow
                                            [11.09.2022 14:07.15.174] [LOG]   Sockets connected & modules started ...
                                            [11.09.2022 14:07.15.516] [LOG]   Launching application.
                                            [11.09.2022 14:07.19.711] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ - Interval: 300000
                                            [11.09.2022 14:07.19.985] [INFO]  BACKGROUNDSLIDESHOW: Reading directory "modules/MMM-BackgroundSlideshow/exampleImages/" for images.
                                            [11.09.2022 14:07.20.006] [INFO]  BACKGROUNDSLIDESHOW: 171 files found
                                            [11.09.2022 14:07.20.057] [INFO]  BACKGROUNDSLIDESHOW_NEXT_IMAGE
                                            [11.09.2022 14:07.20.058] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/exampleImages//DSC_0038.JPG"
                                            [11.09.2022 14:07.20.493] [INFO]  Calendar-Fetcher: Broadcasting 0 events.
                                            [11.09.2022 14:07.29.492] [LOG]   Shutting down server...
                                            [11.09.2022 14:07.29.493] [LOG]   Stopping module helper: calendar
                                            [11.09.2022 14:07.29.494] [LOG]   Stopping module helper: MMM-BackgroundSlideshow
                                            • 34
                                            • 35
                                            • 6 / 35
