    MMM-CalendarExt3
    689 Posts 82 Posters 3.0m Views 86 Watching
      sdetweil @MMRIZE
      @MMRIZE I am the one that caused the bug in 2.20, fixed in 2.21 oct 1
      if u want to test the develop branch
      see
      https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code
        MMRIZE @nmacd
        @nmacd
        I found what’s wrong.
        calendars: ['https://calendar.google.com/'],
        You need to set the names of calendar, in this case you assigned “Calendar” as the name of your google calendar.
        So it should be calendarSet:[‘Calendar’], . Or just leave as blank([]) to get all the calendars.
          sdetweil @MMRIZE
          @MMRIZE as this is the 3rd or 4th time users have had trouble with this
          you should put out a debugging message
          unable to locate calendar with name property equal to “???”
          maybe list the names you found…
          luisestradaL 1 Reply Last reply Reply Quote 0
          • luisestradaL Offline
            luisestrada @sdetweil
            Hi @sdetweil @MMRIZE
            This used to be possible before, but after implementing the weather icons, it stopped working. It’s not a big deal but it’s a nice to have feature.
            As you know, MagicMirror uses a very old version of Font Awesome. I updated mine to the most recent version and it now includes the Canadian flag and many other brand icons. Unfortunately, for brands, you have to use “fas” or “fa-solid”, and for brands you have to use “fab” or “fa-brands”. I solved this by tweaking the code in calendar.js and config.js. I also tried to do the same in MMM-CalendarEXT3.js, line 242, but when I try to update config.js calendar module, the calendar shows no data. The reason, because MMM-CalendarEXT3 module does not accept spaces in symbol.
            CalendarEXT3.js, line 242:
            symbol.className = "fa fa-fw fa" + s;
            config.js, for birthday calendar
            symbol: "s fa-cake-candles",
            config.js, for Canadian holidays
            symbol: "b fa-canadian-maple-leaf",
            The space breaks my code, I wanted to choose either “b” or “s” in the symbol field
            How the icons look in the native calendar
            Unfortunately, not allowing spaces, forces me to decide which one to use or “fas” or “fab”
              MMRIZE @luisestrada
              @luisestrada
              Maybe line 472-473 needs to be modified to allow ‘fa-brand’ instead of fixed ‘fa-solid’. I’ll check in a few days.
                MMRIZE @luisestrada
                @luisestrada
                I fixed. Update your module.
                I don’t know your code modification, so I applied these syntaxes.
                /* In your default calendar config */
                symbol: ['fa-brands fa-canadian-maple-leaf'],
                /* or */
                symbol: ['brands canadian-maple-leaf'],
                /* of course below are also allowed */
                symbol: 'brands canadian-maple-leaf',
                /* But if you want multi-icons, use array */
                symbol: ['brands google-drive', 'solid calendar'],
                • BKeyportB Offline
                  BKeyport Module Developer @MMRIZE
                  @MMRIZE
                  any idea why I can’t use this icon in this situation to set it up?
                  https://fontawesome.com/v5/icons/bowling-pins?s=solid
                  module: "calendar", // Built in
                  //position: "top_right",
                  	broadcastEvents: true,
                  	broadcastPastEvents: false,
                  	fetchInterval: 30000,
                  	maximumEntries: 20,
                  	customEvents: [{keyword: 'bowling', symbol: 'bowling-pins'}],
                  Do I need to do the transform on your side, is it something else?
                  it does work with other icons, like “user”
                  thanks!
                  M luisestradaL 2 Replies Last reply Reply Quote 0
                    MMRIZE @BKeyport
                    @BKeyport
                    I have no idea why this “bowling-pins” icon would not appear. maybe font-awesome CSS version issue?"
                      luisestrada @BKeyport
                      @BKeyport It’s a Pro icon, do you pay for it?
                      • BKeyportB Offline
                        BKeyport Module Developer @luisestrada
                        @luisestrada ahh, that must be it. Although I’ve had pro icons before.
                          luisestrada
                          Thank you very much.
                          It took me some time to figure out that I could use symbol: “blank”, to not to show any icon, I was getting an error because before, I was using symbol: null :beaming_face_with_smiling_eyes:
                          It’s working exactly as I wanted :)
                            MMRIZE
                            Small news.
                            Now it could get the events from randomBrainstormer/MMM-GoogleCalendar module also.
                            • N Offline
                              nmacd @MMRIZE
                              @MMRIZE Thank you all for your help! I got fresh copies of everything and was more careful when making changes, it now works which is great. The new issue I am having is it’s only displaying 11 appointments, 10 Google calendar and 1 US Holiday. When I delete an event the next one later down the calendar shows up. Is there a setting to set the max entries or something to that nature?
                              • N Offline
                                nmacd @nmacd
                                @nmacd My bad just found it, the default calendar had the limit, all set thanks again
                                • T Offline
                                  techlady
                                  Hi
                                  I would like to know how to make the calendar smaller. As you can see in the picture, my tv is in portrait, and the calendar takes up a lot of space. Where and what changes in custom css could I make to make it smaller and more rectangular? Thank you.
                                    MMRIZE @techlady
                                    @techlady
                                    Adjust ‘maxEventLines’ and ‘eventHeight’. The heighr of day cell would be calculated by maxEventLines x eventHeight.
                                    • K Offline
                                      KD
                                      Hi Guys,
                                      Just installed a brand new MM instance and downloaded the latest MMM-CalendarExt3 but for some reason i get no entries from my google calendars…
                                      I get entries if i setup MMM-CalendarExt2 or the default calendar but not on MMM-CalendarExt3…
                                      Here is my Config
                                        module: "MMM-CalendarExt3",
                                        position: "bottom_center",
                                          mode: "month",
                                          instanceId: "basicCalendar",
                                          locale: 'en-UK',
                                      	fontSize: '25px',
                                      	refreshInterval: 10000,
                                          maxEventLines: 5,
                                          firstDayOfWeek: 1,
                                          calendarSet: ["KD", "Tini"],
                                          broadcastPastEvents: true,
                                      			className: "KD",
                                      			url: "https://calendar.google.com/calendar/ical/basic.ics",
                                      			color: "green"
                                      			className: "tini",
                                      			color: "pink"
                                        sdetweil @KD
                                        @KD if you use the calendar url in a browser, it should download a file, just text. you an edit that to see if there are events
                                        • K Offline
                                          KD @sdetweil
                                          @sdetweil Hi there - i can download the file by putting the URL in the browser and open it in Outlook and see the events…
                                          Also, I use both URL’s in another 2 magic mirrors I have in the house… I’m confident it’s not the URL’s
                                            sdetweil @KD
                                            @KD ok, this looks like the bug I introduced in 2.20. fixed in 2.21, October 1
                                            broadcastPastEvents loads up the past events then the new, and the bug cuts off after the 1st maximumEntries
                                            so u have to increase maximum entries
                                            • 34
                                            • 35
                                            • 5 / 35
