    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 23.6k Views 7 Watching
      sdetweil @Volkae
      @Volkae so have u tried the command it uses, on the terminal window
      from the code
      /usr/bin/vcgencmd display_power 0
      make sure to do this over ssh, so you can turn it back on
      /usr/bin/vcgencmd display_power 1
      • V Offline
        Volkae @sdetweil
        then it shows me:
        display_power=1
        HDMI is still alive…
          sdetweil @Volkae
          @Volkae those two were off and on
          if you do off
          does it turn off?
          • V Offline
            Volkae @sdetweil
            No, it does not switch HDMI off
              sdetweil @Volkae
              @Volkae works perfectly on my pi 4…
              what pi version are you using?
              • V Offline
                Volkae @sdetweil
                I´m using a pi3.
                Maybe that´s the problem??
                  sdetweil @Volkae
                  @Volkae worked on my pi3 as well…
                    JoeFranz @sdetweil
                    @sdetweil same here https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi?page=1
                      sdetweil @JoeFranz
                      @JoeFranz @Volkae this appears to be a problem related to the raspi os kernel level
                      https://forums.raspberrypi.com/viewtopic.php?t=339079
                        JoeFranz @sdetweil
                        Thanks @sdetweil for the link :-)
                        It is probably due to the current firmware 5.15
                        With
                        rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                        I installed version 5.10. It now works again with the standby on the HDMI connection.
                        Greetings Joerg
                          blouzbee
                          all these modules and all these guides you can find online all fail to tell you that at some point a kernel or driver update broke vcgencmd and tvservice commands for the newer pis or Rasberry OS. I spent so many hours making mine work.
                          xrandr --output HDMI-1 --off
                          xrandr --output HDMI-1 --auto
                          these worked for me, maybe they’ll work for you, I dunno.
                            sdetweil @blouzbee
                            @blouzbee cool…
                            yeh tvservice went away in bullseye
                            they are trying to get rid of all the old ‘raspberry pi’ unique stuff to maintain
                            • V Offline
                              Volkae @sdetweil
                              Seems that there is no way for me to swich off HDMI via PIR-Sensor :-(
                              Maybe I will find a way to do this with a python-Scrip out of MagicMirror but I´m a just a beginner and it seems to be not easy…
                                sdetweil @Volkae
                                @Volkae did u see @JoeFranz post about changing the OS firmware down a couple levels?
                                https://forum.magicmirror.builders/topic/17202/mmm-pir-sensor-lite-does-not-switch-hdmi-off/13?_=1662126560261
                                • V Offline
                                  Volkae @sdetweil
                                  I will try to downgrade
                                  • G Offline
                                    grena Module Developer
                                    Hello all,
                                    I think I have restored the compatibility of MMM-PIR-Sensor-Lite with Bullseye (lastest firmware). See issue on GitHub and more information in ReadMe
                                    Can you install the testing version to confirm the resolution of this issue?
                                    cd ~/MagicMirror/modules/MMM-PIR-Sensor-Lite
                                    git pull
                                    git checkout testing
                                    Thanks for your feedback!
                                    • G grena referenced this topic on
                                    • V Offline
                                      Volkae @grena
                                      @grena
                                      Hey grena,
                                      seems to work fine on my Raspi 3!!!
                                      Thank you, great support!!!
                                      V 1 Reply Last reply Reply Quote 1
                                      • V Offline
                                        Volkae @Volkae
                                        @grena
                                        Oh, now another problem:
                                        After switching off HDMI by MMM-PIR-Sensor-Lite the livestream-picture from MMM-RTSPStream is not in the frame when HDMI is switched on again by PIR .
                                        • G Offline
                                          grena Module Developer @Volkae
                                          @Volkae, have you updated the module from the testing branch since your last message that it worked?
                                          • V Offline
                                            Volkae @grena
                                            @grena
                                            yes, I did but I did not run RTSPStream while running the testing branch, sorry.
