    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 24.7k Views 7 Watching
    • V Offline
      Volkae @sdetweil
      Python3 was already installed (up to date).
      Module seems to work fine but does not switch HDMI off…
        sdetweil @Volkae
        @Volkae so have u tried the command it uses, on the terminal window
        from the code
        /usr/bin/vcgencmd display_power 0
        make sure to do this over ssh, so you can turn it back on
        /usr/bin/vcgencmd display_power 1
        • V Offline
          Volkae @sdetweil
          then it shows me:
          display_power=1
          HDMI is still alive…
            sdetweil @Volkae
            @Volkae those two were off and on
            if you do off
            does it turn off?
            • V Offline
              Volkae @sdetweil
              No, it does not switch HDMI off
                sdetweil @Volkae
                @Volkae works perfectly on my pi 4…
                what pi version are you using?
                • V Offline
                  Volkae @sdetweil
                  I´m using a pi3.
                  Maybe that´s the problem??
                    sdetweil @Volkae
                    @Volkae worked on my pi3 as well…
                      JoeFranz @sdetweil
                      @sdetweil same here https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi?page=1
                        sdetweil @JoeFranz
                        @JoeFranz @Volkae this appears to be a problem related to the raspi os kernel level
                        https://forums.raspberrypi.com/viewtopic.php?t=339079
                          JoeFranz @sdetweil
                          Thanks @sdetweil for the link :-)
                          It is probably due to the current firmware 5.15
                          With
                          rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                          I installed version 5.10. It now works again with the standby on the HDMI connection.
                          Greetings Joerg
                            blouzbee
                            all these modules and all these guides you can find online all fail to tell you that at some point a kernel or driver update broke vcgencmd and tvservice commands for the newer pis or Rasberry OS. I spent so many hours making mine work.
                            xrandr --output HDMI-1 --off
                            xrandr --output HDMI-1 --auto
                            these worked for me, maybe they’ll work for you, I dunno.
                              sdetweil @blouzbee
                              @blouzbee cool…
                              yeh tvservice went away in bullseye
                              they are trying to get rid of all the old ‘raspberry pi’ unique stuff to maintain
                              • V Offline
                                Volkae @sdetweil
                                Seems that there is no way for me to swich off HDMI via PIR-Sensor :-(
                                Maybe I will find a way to do this with a python-Scrip out of MagicMirror but I´m a just a beginner and it seems to be not easy…
                                  sdetweil @Volkae
                                  @Volkae did u see @JoeFranz post about changing the OS firmware down a couple levels?
                                  https://forum.magicmirror.builders/topic/17202/mmm-pir-sensor-lite-does-not-switch-hdmi-off/13?_=1662126560261
                                  • V Offline
                                    Volkae @sdetweil
                                    I will try to downgrade
                                    • G Offline
                                      grena Module Developer
                                      Hello all,
                                      I think I have restored the compatibility of MMM-PIR-Sensor-Lite with Bullseye (lastest firmware). See issue on GitHub and more information in ReadMe
                                      Can you install the testing version to confirm the resolution of this issue?
                                      cd ~/MagicMirror/modules/MMM-PIR-Sensor-Lite
                                      git pull
                                      git checkout testing
                                      Thanks for your feedback!
                                      • G grena referenced this topic on
                                      • V Offline
                                        Volkae @grena
                                        @grena
                                        Hey grena,
                                        seems to work fine on my Raspi 3!!!
                                        Thank you, great support!!!
                                        V 1 Reply Last reply Reply Quote 1
                                        • V Offline
                                          Volkae @Volkae
                                          @grena
                                          Oh, now another problem:
                                          After switching off HDMI by MMM-PIR-Sensor-Lite the livestream-picture from MMM-RTSPStream is not in the frame when HDMI is switched on again by PIR .
                                          • G Offline
                                            grena Module Developer @Volkae
                                            @Volkae, have you updated the module from the testing branch since your last message that it worked?
