    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 26.0k Views 7 Watching
    • V
      Volkae
      My MM works fine but I have a problem using MMM-PIR-Sensor-Lite. The modul is running, the countdown is shown on the MM but when the countdown shows 0 it does not switch HDMI off so the monitor is still alive.
      What can I do??
        sdetweil @Volkae
        @Volkae this module requires python3, which is not installed by default… and not listed in the requirements
        V 1 Reply Last reply
        • V
          Volkae @sdetweil
          Python3 was already installed (up to date).
          Module seems to work fine but does not switch HDMI off…
            sdetweil @Volkae
            @Volkae so have u tried the command it uses, on the terminal window
            from the code
            /usr/bin/vcgencmd display_power 0
            make sure to do this over ssh, so you can turn it back on
            /usr/bin/vcgencmd display_power 1
            • V
              Volkae @sdetweil
              then it shows me:
              display_power=1
              HDMI is still alive…
                sdetweil @Volkae
                @Volkae those two were off and on
                if you do off
                does it turn off?
                • V
                  Volkae @sdetweil
                  No, it does not switch HDMI off
                    sdetweil @Volkae
                    @Volkae works perfectly on my pi 4…
                    what pi version are you using?
                    • V
                      Volkae @sdetweil
                      I´m using a pi3.
                      Maybe that´s the problem??
                        sdetweil @Volkae
                        @Volkae worked on my pi3 as well…
                        J 1 Reply Last reply
                          JoeFranz @sdetweil
                          @sdetweil same here https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi?page=1
                            sdetweil @JoeFranz
                            @JoeFranz @Volkae this appears to be a problem related to the raspi os kernel level
                            https://forums.raspberrypi.com/viewtopic.php?t=339079
                              JoeFranz @sdetweil
                              Thanks @sdetweil for the link :-)
                              It is probably due to the current firmware 5.15
                              With
                              rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                              I installed version 5.10. It now works again with the standby on the HDMI connection.
                              Greetings Joerg
                                blouzbee
                                all these modules and all these guides you can find online all fail to tell you that at some point a kernel or driver update broke vcgencmd and tvservice commands for the newer pis or Rasberry OS. I spent so many hours making mine work.
                                xrandr --output HDMI-1 --off
                                xrandr --output HDMI-1 --auto
                                these worked for me, maybe they’ll work for you, I dunno.
                                  sdetweil @blouzbee
                                  @blouzbee cool…
                                  yeh tvservice went away in bullseye
                                  they are trying to get rid of all the old ‘raspberry pi’ unique stuff to maintain
                                  • V
                                    Volkae @sdetweil
                                    Seems that there is no way for me to swich off HDMI via PIR-Sensor :-(
                                    Maybe I will find a way to do this with a python-Scrip out of MagicMirror but I´m a just a beginner and it seems to be not easy…
                                      sdetweil @Volkae
                                      @Volkae did u see @JoeFranz post about changing the OS firmware down a couple levels?
                                      https://forum.magicmirror.builders/topic/17202/mmm-pir-sensor-lite-does-not-switch-hdmi-off/13?_=1662126560261
                                      • V
                                        Volkae @sdetweil
                                        I will try to downgrade
                                        • G
                                          grena Module Developer
                                          Hello all,
                                          I think I have restored the compatibility of MMM-PIR-Sensor-Lite with Bullseye (lastest firmware). See issue on GitHub and more information in ReadMe
                                          Can you install the testing version to confirm the resolution of this issue?
                                          cd ~/MagicMirror/modules/MMM-PIR-Sensor-Lite
                                          git pull
                                          git checkout testing
                                          Thanks for your feedback!
                                          • G grena referenced this topic on
                                          • V
                                            Volkae @grena
                                            @grena
                                            Hey grena,
                                            seems to work fine on my Raspi 3!!!
                                            Thank you, great support!!!
