    MMM-PIR-Sensor-Lite does not switch HDMI off
    43 Posts 7 Posters 20.2k Views 7 Watching
    • V Offline
      Volkae @sdetweil
      then it shows me:
      display_power=1
      HDMI is still alive…
        sdetweil @Volkae
        @Volkae those two were off and on
        if you do off
        does it turn off?
        • V Offline
          Volkae @sdetweil
          No, it does not switch HDMI off
            sdetweil @Volkae
            @Volkae works perfectly on my pi 4…
            what pi version are you using?
            • V Offline
              Volkae @sdetweil
              I´m using a pi3.
              Maybe that´s the problem??
                sdetweil @Volkae
                @Volkae worked on my pi3 as well…
                  JoeFranz @sdetweil
                  @sdetweil same here https://forum.magicmirror.builders/topic/17185/pir-sensor-problem-after-restart-raspi?page=1
                    sdetweil @JoeFranz
                    @JoeFranz @Volkae this appears to be a problem related to the raspi os kernel level
                    https://forums.raspberrypi.com/viewtopic.php?t=339079
                      JoeFranz @sdetweil
                      Thanks @sdetweil for the link :-)
                      It is probably due to the current firmware 5.15
                      With
                      rpi-update b976c54917e240630c05a9b383010f1492bc61b4
                      I installed version 5.10. It now works again with the standby on the HDMI connection.
                      Greetings Joerg
                        blouzbee
                        all these modules and all these guides you can find online all fail to tell you that at some point a kernel or driver update broke vcgencmd and tvservice commands for the newer pis or Rasberry OS. I spent so many hours making mine work.
                        xrandr --output HDMI-1 --off
                        xrandr --output HDMI-1 --auto
                        these worked for me, maybe they’ll work for you, I dunno.
                        • 1 / 5
