    MMM-NewsFeed multiple instances
    12 Posts 3 Posters 2.9k Views 3 Watching
      sdetweil @Egnos
      @Egnos this module does not support multiple instances
      you can try to use the copy approach
      copy the MMM-Newsfeed module folder
      to another named folder in the module directory, MMM-Newsfeed2 for example
      in the new folder, rename the MMM-Newsfeed.js to match the new folder name. MMM-Newsfeed2.js
      edit that file and change the module.register(
      to use the new folder name
      in all cases the new name must match exactly as the system is case sensitive.
      then in config.js use the new folder name for module:
      • E Offline
        Egnos @sdetweil
        I have already tried your advice but it didn’t work.
        The strange thing is that if I launch the two modules together, only MMM-NewsFeed starts.
        If I start them individually then the MMM-NewsFeed2 works too.
        When launched together, MMM-NewsFeed always prevails, not allowing the execution of MMM-NewsFeed2.
        daniele@raspberry:~/MagicMirror $ npm start
        > magicmirror@2.20.0 start
        > ./run-start.sh $1
        [15.09.2022 13:57.13.128] [LOG] Starting MagicMirror: v2.20.0
        [15.09.2022 13:57.13.132] [LOG] Loading config ...
        [15.09.2022 13:57.13.135] [LOG] Loading module helpers ...
        [15.09.2022 13:57.13.137] [LOG] No helper found for module: alert.
        [15.09.2022 13:57.13.148] [LOG] Initializing new module helper ...
        [15.09.2022 13:57.13.148] [LOG] Module helper loaded: updatenotification
        [15.09.2022 13:57.13.149] [LOG] No helper found for module: clock.
        [15.09.2022 13:57.13.379] [LOG] Initializing new module helper ...
        [15.09.2022 13:57.13.379] [LOG] Module helper loaded: MMM-SystemStats
        [15.09.2022 13:57.13.427] [LOG] Initializing new module helper ...
        [15.09.2022 13:57.13.427] [LOG] Module helper loaded: MMM-NewsFeed
        [15.09.2022 13:57.13.437] [LOG] Initializing new module helper ...
        [15.09.2022 13:57.13.437] [LOG] Module helper loaded: MMM-NewsFeed2
        [15.09.2022 13:57.13.438] [LOG] All module helpers loaded.
        [15.09.2022 13:57.13.491] [LOG] Starting server on port 8080 ...
        [15.09.2022 13:57.13.501] [LOG] Server started ...
        [15.09.2022 13:57.13.502] [LOG] Connecting socket for: updatenotification
        [15.09.2022 13:57.13.502] [LOG] Starting module helper: updatenotification
        [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-SystemStats
        [15.09.2022 13:57.13.503] [LOG] Connecting socket for: MMM-NewsFeed
        [15.09.2022 13:57.13.504] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0
        [15.09.2022 13:57.13.505] [LOG] Connecting socket for: MMM-NewsFeed2
        [15.09.2022 13:57.13.506] [LOG] [FEED] MMM-NewsFeed Version: 1.2.0
        [15.09.2022 13:57.13.507] [LOG] Sockets connected & modules started ...
        Ready to go! Please point your browser to: http://localhost:8080
        Starting chromium browser now, have patience, it takes a minute
        [15.09.2022 13:57.16.780] [INFO]  Checking git for module: MMM-SystemStats
        [15.09.2022 13:57.16.835] [INFO]  Checking git for module: MMM-NewsFeed
        [15.09.2022 13:57.16.850] [INFO]  Checking git for module: MMM-NewsFeed2
        [15.09.2022 13:57.16.865] [INFO]  Checking git for module: default
        [15.09.2022 13:57.23.546] [LOG]   [FEED] MMM-NewsFeed est now initialized!
        [15.09.2022 13:57.23.910] [LOG]   [FEED] MMM-NewsFeed est now initialized!
        • E Offline
          Egnos
          I realized that the two instances overlap, regardless of the position given in the configuration.
          both modules work (MMM-NewsFeed and MMM-NewsFeed2) but “cover” each other …
            sdetweil @Egnos
            @Egnos then you would have to have to fiddle with CSS
            so would have to rename the css file and change the response to getStyles to the new name…
            THEN you could use custom.css to attempt to fix
            as I said, you could ‘try’ the rename approach… sometimes not so easy…
            • E Offline
              Egnos @sdetweil
              @sdetweil said in MMM-NewsFeed multiple instances:
              Below the “MMM-NewsFeed2.css” file contained in the module but I can’t find "getStyles ":
              /* Magic Mirror
               * Module: NewsFeed
               * By @bugsounet -- Dupont Cédric <bugsounet@bugsounet.fr>
               * MIT Licensed.
              #NEWSFEED_CONTENER {
                line-height:1.1em;
                width: 100%;
              #NEWSFEED_CONTENER.showArticle {
                opacity: 1;
                transition: opacity 1s linear;
              #NEWSFEED_CONTENER.hideArticle {
                opacity: 0;
              #NEWSFEED_TITLE {
                margin-left: auto;
                margin-right: auto;
                white-space: nowrap;
                overflow: hidden;
                text-overflow: ellipsis;
              #NEWSFEED_ARTICLE {
                font-size: 90%;
                display: flex;
              #NEWSFEED_CONTENT {
                padding: 10px;
                margin-top: 1px;
                font-size: 70%;
                text-align: left;
                height: 80px;
                display: flex;
              #NEWSFEED_IMAGE {
                margin-right: 10px;
                float: left;
                max-width: 10vw;
                max-height: 10vh;
                text-align: left;
              #NEWSFEED_DESCRIPTION {
                opacity: 0;
                line-height: 25px;
                text-align: justify;
                overflow: hidden;
                display: -webkit-box;
                -webkit-line-clamp: 3;
                -webkit-box-orient: vertical;
              #NEWSFEED_DESCRIPTION.showArticle {
                animation: 3s ease 0s normal forwards 1 fadein;
              @keyframes fadein{
                0%   { opacity:0; }
                66%  { opacity:0; }
                100% { opacity:1; }
              #NEWSFEED_DESCRIPTION.hideArticle {
                opacity: 1;
                animation: none;
              #NEWSFEED_FOOTER {
                text-align:right;
              #NEWSFEED_LOGO {
                font-size: 100%;
                font-weight: bold;
                display: flex;
              #NEWSFEED_LOGO_PARTA {
                margin-left: 10px;
              #NEWSFEED_LOGO_PARTB {
                margin-right: 10px;
              #NEWSFEED_SOURCE {
                margin-right: 8px;
                font-weight: bold;
                margin-top: -9px;
                margin-bottom: 5px;
                text-align: left;
              #NEWSFEED_SOURCE.start {
                animation-duration: .8s;
                animation-name: clignoter;
                animation-iteration-count: 2;
                transition: none;
                animation-delay: 1s;
              #NEWSFEED_SOURCE.stop {
                animation-name: stopclignoter;
                animation-iteration-count: 1;
              @keyframes clignoter {
                0%   { opacity:1; }
                40%  { opacity:0; }
                100% { opacity:1; }
              @keyframes stopclignoter {
                0%   { opacity:1; }
              #NEWSFEED_TIME {
                font-size: 50%;
                text-align: right;
                display: inline-block;
                margin-right: 10px;
                margin-top: 10px;
                margin-bottom: -5px;
              #NEWSFEED_INFO {
                width: 100%;
                height: 110px;
              #NEWSFEED_QRCODE {
                height: 120px;
                width: 120px;
                margin-top: 0px;
                margin-right: -10px;
                margin-left: 5px;
              /** Vertical **/
              #NEWSFEED_TITLE.vertical {
                display: none;
              #NEWSFEED_CONTENT.vertical {
                font-size: 80%;
              #NEWSFEED_IMAGE.vertical {
                float: unset;
                display: block;
                margin-left: auto;
                margin-right: auto;
                max-width: 20vw;
                max-height: 20vh;
              #NEWSFEED_SOURCE.vertical {
                text-align: center;
                margin-top: auto;
                margin-bottom: auto;
                line-height: 22px;
              #NEWSFEED_QRCODE.vertical {
                height: 100px;
                width: 100px;
                min-width: 100px;
                min-height: 100px;
                /* display: inline-block; */
                margin-right: 0px;
                margin-top: 3px;
                margin-left: 0px;
              #NEWSFEED_CONTENER_TITLE {
                display: flex;
              #NEWSFEED_DESCRIPTION.vertical {
                line-height: 20px;
                margin-top: 5px;
                -webkit-line-clamp: 10;
              #NEWSFEED_TIME.vertical {
                font-size: 60%;
                margin-top: 0px;
              A S 2 Replies Last reply Reply Quote 0
                Anthony Project Sponsor @Egnos
                @Egnos Why don’t you try different modules?
                • E Offline
                  Egnos @Anthony
                  @Anthony said in MMM-NewsFeed multiple instances:
                  Hi @Anthony, I have not found any RSS Feed modules that show the image of the article.
                  Do you have something to advise me?
                  Thanks.
                    sdetweil @Egnos
                    @Egnos getStyles is in the MMM-Newfeed2.js
                      @Egnos I didn’t know you want a picture too. Although this, this and this seem to have a picture of the article but better is to check them yourself to see if they fit your needs.
                      • E Offline
                        Egnos @sdetweil
                        yes yes, I already did. I tried to move it with the “custom.css” but I could not move it (probably due to my lack of knowledge of css …).
                        Can you recommend a few lines of CSS code to move MMM-Newsfeed2?
                        Now I take a look at it, I typically avoid modules with API to get from registration. But if it’s the only solution …
                        Thank you all
                          sdetweil @Egnos
                          @Egnos sorry, this one looks more difficult to move around
