    [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons
    25 Posts 3 Posters 7.9k Views 2 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @Cr4z33
      @Cr4z33
      the short answer: Yes it can, maaayyyybee?
      Does your powermeter send the data via MQTT already?
      Do you have the MMM-MQTTbridge module configured to connect to your MQTT broker, subscribe for the topic(s) and send the data via notification?
      How does the data look like? Is it plain text or is it a JSON object?
      If it is JSON how is the data structured and which values do you want to display?
      Cr4z33C 1 Reply Last reply Reply Quote 1
      • Cr4z33C Offline
        Cr4z33 @wishmaster270
        @wishmaster270 said in [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons:
        Yes
        Nope, but I will set it up as soon as I finish posting this reply! :thumbs_up_light_skin_tone:
        I’ve got Zigbee2MQTT running in a Docker and if I look at its logs it shows lines like
        Zigbee2MQTT:info  2022-10-04 15:45:08: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":645,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
        Zigbee2MQTT:info  2022-10-04 15:45:10: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":610,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
        I want to display the power value.
          @Cr4z33
          Should be no problem:
          MMM-MQTTbridge/dict/mqttDictionary.js:
          var mqttHook = [
              mqttTopic: "zigbee2mqtt/BTicino F20T60A",
              mqttPayload: [
                  payloadValue: "",
                  mqttNotiCmd: ["POWERMETER"],
                  mqttPayload: ""
          var mqttNotiCommands = [
              commandId: "POWERMETER",
              notiID: "POWERMETER_VALUES",
          module.exports = { mqttHook,  mqttNotiCommands};
          config.js:
          			module: "MMM-ValuesByNotification",
                                          updateInterval: 60,
                                          reuseCount: 5,
          				groups: [
          						items: [
          								notification: "POWERMETER_VALUES",
          								itemTitle: "Power",
          								values: [
          										valueUnit: "W",
          										jsonpath: "power",
          Will look like:
          You may want to configure the updateInterval and/or reuseCount to your needs.
          • Cr4z33C Offline
            @wishmaster270 thank you it worked at first try!
            Now I can go on with some aesthetic changes like icons, etc. :D
              @Cr4z33
              Just tested a view things.
              If you like you can use font awesome icon instead of the title:
                                              updateInterval: 60,
                                              reuseCount: 5,
              				groups: [
              						items: [
              								//itemTitle: "Power",
              								values: [
              										classes: "power",
              										valueIcon: "fa fa-bolt",
              										valueUnit: "W",
              										jsonpath: "power",
              custom.css:
              .vbn .valueIcon.power {
                color: orange;
              • Cr4z33C Offline
                @wishmaster270 thanks I applied that instead.
                Anyway to add some offset to the module to be aligned with the other modules on the left?
                  @Cr4z33
                  sorry i do not understand exactly what you mean
                  Cr4z33C 2 Replies Last reply Reply Quote 0
                  • Cr4z33C Offline
                    @wishmaster270 I wanted to move your module way more to the left so to align it with my other modules (Google Assistant, clock and Spotify).
                    However nevermind as I opted to have your module on top instead. ;)
                    • Cr4z33C Offline
                      @wishmaster270 sorry for bothering you again… :grinning_face_with_sweat:
                      What if I want no border?
                      Would I have to edit the module’s CSS or can I just add something to custom.css?
                        @Cr4z33
                        No problem.
                        Simply add
                        .vbn .groupWrapper {
                          border-style: none;
                          padding: 0px;
                        to your custom.css
                        Ps.: Try to never ever edit any files in the module directory (except mentioned in the documentation) as you will get problems with updates in the future otherwise!
