    [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons
    25 Posts 3 Posters 9.8k Views 2 Watching
    • wishmaster270W
      wishmaster270 Module Developer @Cr4z33
      @Cr4z33
      the short answer: Yes it can, maaayyyybee?
      Does your powermeter send the data via MQTT already?
      Do you have the MMM-MQTTbridge module configured to connect to your MQTT broker, subscribe for the topic(s) and send the data via notification?
      How does the data look like? Is it plain text or is it a JSON object?
      If it is JSON how is the data structured and which values do you want to display?
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @wishmaster270
        @wishmaster270 said in [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons:
        Yes
        Nope, but I will set it up as soon as I finish posting this reply! :thumbs_up_light_skin_tone:
        I’ve got Zigbee2MQTT running in a Docker and if I look at its logs it shows lines like
        Zigbee2MQTT:info  2022-10-04 15:45:08: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":645,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
        Zigbee2MQTT:info  2022-10-04 15:45:10: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":610,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
        I want to display the power value.
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          @Cr4z33
          Should be no problem:
          MMM-MQTTbridge/dict/mqttDictionary.js:
          var mqttHook = [
              mqttTopic: "zigbee2mqtt/BTicino F20T60A",
              mqttPayload: [
                  payloadValue: "",
                  mqttNotiCmd: ["POWERMETER"],
                  mqttPayload: ""
          var mqttNotiCommands = [
              commandId: "POWERMETER",
              notiID: "POWERMETER_VALUES",
          module.exports = { mqttHook,  mqttNotiCommands};
          config.js:
          			module: "MMM-ValuesByNotification",
                                          updateInterval: 60,
                                          reuseCount: 5,
          				groups: [
          						items: [
          								notification: "POWERMETER_VALUES",
          								itemTitle: "Power",
          								values: [
          										valueUnit: "W",
          										jsonpath: "power",
          Will look like:
          You may want to configure the updateInterval and/or reuseCount to your needs.
          • Cr4z33C
            @wishmaster270 thank you it worked at first try!
            Now I can go on with some aesthetic changes like icons, etc. :D
            • wishmaster270W
              @Cr4z33
              Just tested a view things.
              If you like you can use font awesome icon instead of the title:
                                              updateInterval: 60,
                                              reuseCount: 5,
              				groups: [
              						items: [
              								//itemTitle: "Power",
              								values: [
              										classes: "power",
              										valueIcon: "fa fa-bolt",
              										valueUnit: "W",
              										jsonpath: "power",
              custom.css:
              .vbn .valueIcon.power {
                color: orange;
              • Cr4z33C
                @wishmaster270 thanks I applied that instead.
                Anyway to add some offset to the module to be aligned with the other modules on the left?
                • wishmaster270W
                  @Cr4z33
                  sorry i do not understand exactly what you mean
                  Cr4z33C 2 Replies Last reply
                  • Cr4z33C
                    @wishmaster270 I wanted to move your module way more to the left so to align it with my other modules (Google Assistant, clock and Spotify).
                    However nevermind as I opted to have your module on top instead. ;)
                    • Cr4z33C
                      @wishmaster270 sorry for bothering you again… :grinning_face_with_sweat:
                      What if I want no border?
                      Would I have to edit the module’s CSS or can I just add something to custom.css?
                      • wishmaster270W
                        @Cr4z33
                        No problem.
                        Simply add
                        .vbn .groupWrapper {
                          border-style: none;
                          padding: 0px;
                        to your custom.css
                        Ps.: Try to never ever edit any files in the module directory (except mentioned in the documentation) as you will get problems with updates in the future otherwise!
                        • Cr4z33C
                          @wishmaster270 exactly what I wanted thanks!
                          • wishmaster270W
                            @Cr4z33
                            If you still want to move the content to the left you can try something like the following in your custom.css:
                              border-style: none;
                              padding: 0px;
                              margin-left: 20px;
                            .vbn .groupsWrapper, .vbn .groupWrapper, .vbn .itemsWrapper, .vbn .valueWrapper {
                              justify-content: left;
                              align-items: unset;
                            • BKeyportB
                              BKeyport Module Developer @wishmaster270
                              @wishmaster270
                              Hey, Tom - Trying to use this module to decode the json output by my weatherstation - Like https://forum.magicmirror.builders/topic/17396/json-request-module
                              What I’m getting from Command to notification module is:
                              WEATHERLINK {"data":{"did":"001D0A71573B","ts":1675287003,"conditions":[{"lsid":434637,"data_structure_type":1,"txid":1,"temp": 47.4,"hum":52.8,"dew_point": 31.0,"wet_bulb": 38.4,"heat_index": 46.4,"wind_chill": 47.4,"thw_index": 46.4,"thsw_index":null,"wind_speed_last":2.00,"wind_dir_last":31,"wind_speed_avg_last_1_min":2.62,"wind_dir_scalar_avg_last_1_min":6,"wind_speed_avg_last_2_min":2.81,"wind_dir_scalar_avg_last_2_min":358,"wind_speed_hi_last_2_min":5.00,"wind_dir_at_hi_speed_last_2_min":340,"wind_speed_avg_last_10_min":1.43,"wind_dir_scalar_avg_last_10_min":36,"wind_speed_hi_last_10_min":5.00,"wind_dir_at_hi_speed_last_10_min":336,"rain_size":1,"rain_rate_last":0,"rain_rate_hi":0,"rainfall_last_15_min":0,"rain_rate_hi_last_15_min":0,"rainfall_last_60_min":0,"rainfall_last_24_hr":0,"rain_storm":0,"rain_storm_start_at":null,"solar_rad":null,"uv_index":null,"rx_state":0,"trans_battery_flag":0,"rainfall_daily":0,"rainfall_monthly":0,"rainfall_year":1750,"rain_storm_last":4,"rain_storm_last_start_at":1674798601,"rain_storm_last_end_at":1675000860},{"lsid":434634,"data_structure_type":4,"temp_in": 79.4,"hum_in":20.5,"dew_point_in": 35.5,"heat_index_in": 77.4},{"lsid":434633,"data_structure_type":3,"bar_sea_level":30.125,"bar_trend":-0.013,"bar_absolute":29.660}]},"error":null}
                              yes, the weather station dumps a mess. :)
                              my current config for the values by notification is just the basics, but should be grabbing the “hum” value for testing:
                              			header: "Module-1",
                              				groups: [
                              						items: [
                              								notification: "WEATHERLINK",
                              								itemTitle: "Item-1",
                              								values: [
                              										valueTitle: "Value-1",
                              										jsonpath: "hum",
                              I get initally “NA” as a value, then it flips to “Undefined”
                              Any clue on what I’m doing wrong, or is the feed from the weather station needing more of a massage to be useful?
                              thanks!
                              • wishmaster270W
                                wishmaster270 Module Developer @BKeyport
                                @BKeyport Hi,
                                i formatted your output to understand the JSON structure you are using:
                                    "data": {
                                        "did": "001D0A71573B",
                                        "ts": 1675287003,
                                        "conditions": [
                                                "lsid": 434637,
                                                "data_structure_type": 1,
                                                "txid": 1,
                                                "temp": 47.4,
                                                "hum": 52.8,
                                                "dew_point": 31.0,
                                                "wet_bulb": 38.4,
                                                "heat_index": 46.4,
                                                "wind_chill": 47.4,
                                                "thw_index": 46.4,
                                                "thsw_index": null,
                                                "wind_speed_last": 2.00,
                                                "wind_dir_last": 31,
                                                "wind_speed_avg_last_1_min": 2.62,
                                                "wind_dir_scalar_avg_last_1_min": 6,
                                                "wind_speed_avg_last_2_min": 2.81,
                                                "wind_dir_scalar_avg_last_2_min": 358,
                                                "wind_speed_hi_last_2_min": 5.00,
                                                "wind_dir_at_hi_speed_last_2_min": 340,
                                                "wind_speed_avg_last_10_min": 1.43,
                                                "wind_dir_scalar_avg_last_10_min": 36,
                                                "wind_speed_hi_last_10_min": 5.00,
                                                "wind_dir_at_hi_speed_last_10_min": 336,
                                                "rain_size": 1,
                                                "rain_rate_last": 0,
                                                "rain_rate_hi": 0,
                                                "rainfall_last_15_min": 0,
                                                "rain_rate_hi_last_15_min": 0,
                                                "rainfall_last_60_min": 0,
                                                "rainfall_last_24_hr": 0,
                                                "rain_storm": 0,
                                                "rain_storm_start_at": null,
                                                "solar_rad": null,
                                                "uv_index": null,
                                                "rx_state": 0,
                                                "trans_battery_flag": 0,
                                                "rainfall_daily": 0,
                                                "rainfall_monthly": 0,
                                                "rainfall_year": 1750,
                                                "rain_storm_last": 4,
                                                "rain_storm_last_start_at": 1674798601,
                                                "rain_storm_last_end_at": 1675000860
                                                "lsid": 434634,
                                                "data_structure_type": 4,
                                                "temp_in": 79.4,
                                                "hum_in": 20.5,
                                                "lsid": 434633,
                                                "data_structure_type": 3,
                                                "bar_sea_level": 30.125,
                                                "bar_trend": -0.013,
                                                "bar_absolute": 29.660
                                    "error": null
                                The hum value is part of the first element with index 0 of the conditions object which is part of the data object.
                                This results in a more advanced jsonpath…
                                			header: "Module-1",
                                				groups: [
                                						items: [
                                								values: [
                                										jsonpath: "data.conditions[0].hum",
                                This config works out of the box ;-)
                                Edit:
                                If the order of the elements of conditions varies you can use
                                jsonpath: "data.conditions..hum"
                                This one selects the hum value of any element of conditions.
                                BKeyportB 1 Reply Last reply
                                • BKeyportB
                                  @wishmaster270 Brilliant. Thank you. JSON is still quite the mystery to me sometimes. :)
                                  • BKeyportB
                                    One last thing - where in the CSS do I adjust the font size for the module? I want it to use the MM “Large” font, as it’s on a wall display across from my desk. Can’t seem to find it.
                                    • wishmaster270W
                                      @BKeyport
                                      Hi, great that it works now.
                                      There are two different ways of how to change the font-size.
                                      Either by using the classes option and add large to the element you want the font-size to be changed. i.e.:
                                      			header: "Module-1",
                                      				groups: [
                                      						items: [
                                      								values: [
                                      										classes: "large",
                                      										jsonpath: "data.conditions..hum",
                                      The main problem with this solution is that the font-size of the valueTitle and the value itself is changed.
                                      Or you can use custom.css to do the job:
                                      .MMM-ValuesByNotification .vbn .groupTitle,
                                      .MMM-ValuesByNotification .vbn .itemTitle,
                                      .MMM-ValuesByNotification .vbn .value,
                                      .MMM-ValuesByNotification .vbn .valueTitle {
                                        font-size: var(--font-size-large);
                                        line-height: 1;
                                      In this example the font-size of all titles and the value is changed. I use the font-size-large CSS variable of the main.css for this job.
                                      • BKeyportB
                                        Thanks again, man. :)
                                        I might not have to work up my own module to get the notifications. 🤣
                                        Reply Quote -1
                                        • BKeyportB
                                          I’m using the example scripts in CommandToNotification using a BME280. I’m trying to keep the temperature in F to two digits, as the script or BME module is producing LONG temperature values. (76.0000000000000000000000001)
                                          Using the configuration below, I’m not getting any rounding on output. The “valueFormat” is directly from your README.md.
                                          			module: "MMM-ValuesByNotification", // https://github.com/Tom-Hirschberger/MMM-ValuesByNotification
                                          			position: "top_bar",
                                          				animationSpeed: 0,
                                          				updateInterval: 15,
                                          				groups: [
                                          						items: [
                                          								values: [
                                          										valueTitle: "Closet",
                                          										valueUnit: "°F",
                                          										jsonpath: "data.conditions[1].temp_in",
                                          										naValue: "0",
                                          						items: [
                                          								notification: "TEMPROOM",
                                          								itemTitle: "Room",
                                          								values: [
                                          										valueTitle: "Temp",
                                          										valueUnit: "°F",
                                          										naValue: "0",
                                          										valueFormat: "Number(${value}).toFixed(2)",
                                          										jsonpath: "temperature_f",
                                          wishmaster270W 2 Replies Last reply
                                          • wishmaster270W
                                            @BKeyport
                                            that’s definitly a bug. It is related to the problem you described in the issue on github.
                                            I found a fix already but i need a moment to solve it proper.
                                            As a quickfix you can change line 299 in MMM-ValuesByNotification.js from
                                            						value = value.replace(/(?:\r\n|\r|\n)/g, newlineReplacement)
                                            to
                                            						value = String(value).replace(/(?:\r\n|\r|\n)/g, newlineReplacement)
