    [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons
    25 Posts 3 Posters 9.8k Views 2 Watching
    • wishmaster270W
      wishmaster270 Module Developer @Cr4z33
      @Cr4z33
      No problem.
      Simply add
      .vbn .groupWrapper {
        border-style: none;
        padding: 0px;
      to your custom.css
      Ps.: Try to never ever edit any files in the module directory (except mentioned in the documentation) as you will get problems with updates in the future otherwise!
      Cr4z33C 1 Reply Last reply
      • Cr4z33C
        Cr4z33 @wishmaster270
        @wishmaster270 exactly what I wanted thanks!
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          @Cr4z33
          If you still want to move the content to the left you can try something like the following in your custom.css:
            border-style: none;
            padding: 0px;
            margin-left: 20px;
          .vbn .groupsWrapper, .vbn .groupWrapper, .vbn .itemsWrapper, .vbn .valueWrapper {
            justify-content: left;
            align-items: unset;
          • BKeyportB
            BKeyport Module Developer @wishmaster270
            @wishmaster270
            Hey, Tom - Trying to use this module to decode the json output by my weatherstation - Like https://forum.magicmirror.builders/topic/17396/json-request-module
            What I’m getting from Command to notification module is:
            WEATHERLINK {"data":{"did":"001D0A71573B","ts":1675287003,"conditions":[{"lsid":434637,"data_structure_type":1,"txid":1,"temp": 47.4,"hum":52.8,"dew_point": 31.0,"wet_bulb": 38.4,"heat_index": 46.4,"wind_chill": 47.4,"thw_index": 46.4,"thsw_index":null,"wind_speed_last":2.00,"wind_dir_last":31,"wind_speed_avg_last_1_min":2.62,"wind_dir_scalar_avg_last_1_min":6,"wind_speed_avg_last_2_min":2.81,"wind_dir_scalar_avg_last_2_min":358,"wind_speed_hi_last_2_min":5.00,"wind_dir_at_hi_speed_last_2_min":340,"wind_speed_avg_last_10_min":1.43,"wind_dir_scalar_avg_last_10_min":36,"wind_speed_hi_last_10_min":5.00,"wind_dir_at_hi_speed_last_10_min":336,"rain_size":1,"rain_rate_last":0,"rain_rate_hi":0,"rainfall_last_15_min":0,"rain_rate_hi_last_15_min":0,"rainfall_last_60_min":0,"rainfall_last_24_hr":0,"rain_storm":0,"rain_storm_start_at":null,"solar_rad":null,"uv_index":null,"rx_state":0,"trans_battery_flag":0,"rainfall_daily":0,"rainfall_monthly":0,"rainfall_year":1750,"rain_storm_last":4,"rain_storm_last_start_at":1674798601,"rain_storm_last_end_at":1675000860},{"lsid":434634,"data_structure_type":4,"temp_in": 79.4,"hum_in":20.5,"dew_point_in": 35.5,"heat_index_in": 77.4},{"lsid":434633,"data_structure_type":3,"bar_sea_level":30.125,"bar_trend":-0.013,"bar_absolute":29.660}]},"error":null}
            yes, the weather station dumps a mess. :)
            my current config for the values by notification is just the basics, but should be grabbing the “hum” value for testing:
            			module: "MMM-ValuesByNotification",
            			header: "Module-1",
            				groups: [
            						items: [
            								notification: "WEATHERLINK",
            								itemTitle: "Item-1",
            								values: [
            										valueTitle: "Value-1",
            										jsonpath: "hum",
            I get initally “NA” as a value, then it flips to “Undefined”
            Any clue on what I’m doing wrong, or is the feed from the weather station needing more of a massage to be useful?
            thanks!
            • wishmaster270W
              wishmaster270 Module Developer @BKeyport
              @BKeyport Hi,
              i formatted your output to understand the JSON structure you are using:
                  "data": {
                      "did": "001D0A71573B",
                      "ts": 1675287003,
                      "conditions": [
                              "lsid": 434637,
                              "data_structure_type": 1,
                              "txid": 1,
                              "temp": 47.4,
                              "hum": 52.8,
                              "dew_point": 31.0,
                              "wet_bulb": 38.4,
                              "heat_index": 46.4,
                              "wind_chill": 47.4,
                              "thw_index": 46.4,
                              "thsw_index": null,
                              "wind_speed_last": 2.00,
                              "wind_dir_last": 31,
                              "wind_speed_avg_last_1_min": 2.62,
                              "wind_dir_scalar_avg_last_1_min": 6,
                              "wind_speed_avg_last_2_min": 2.81,
                              "wind_dir_scalar_avg_last_2_min": 358,
                              "wind_speed_hi_last_2_min": 5.00,
                              "wind_dir_at_hi_speed_last_2_min": 340,
                              "wind_speed_avg_last_10_min": 1.43,
                              "wind_dir_scalar_avg_last_10_min": 36,
                              "wind_speed_hi_last_10_min": 5.00,
                              "wind_dir_at_hi_speed_last_10_min": 336,
                              "rain_size": 1,
                              "rain_rate_last": 0,
                              "rain_rate_hi": 0,
                              "rainfall_last_15_min": 0,
                              "rain_rate_hi_last_15_min": 0,
                              "rainfall_last_60_min": 0,
                              "rainfall_last_24_hr": 0,
                              "rain_storm": 0,
                              "rain_storm_start_at": null,
                              "solar_rad": null,
                              "uv_index": null,
                              "rx_state": 0,
                              "trans_battery_flag": 0,
                              "rainfall_daily": 0,
                              "rainfall_monthly": 0,
                              "rainfall_year": 1750,
                              "rain_storm_last": 4,
                              "rain_storm_last_start_at": 1674798601,
                              "rain_storm_last_end_at": 1675000860
                              "lsid": 434634,
                              "data_structure_type": 4,
                              "temp_in": 79.4,
                              "hum_in": 20.5,
                              "lsid": 434633,
                              "data_structure_type": 3,
                              "bar_sea_level": 30.125,
                              "bar_trend": -0.013,
                              "bar_absolute": 29.660
                  "error": null
              The hum value is part of the first element with index 0 of the conditions object which is part of the data object.
              This results in a more advanced jsonpath…
              			header: "Module-1",
              				groups: [
              						items: [
              								values: [
              										jsonpath: "data.conditions[0].hum",
              This config works out of the box ;-)
              Edit:
              If the order of the elements of conditions varies you can use
              jsonpath: "data.conditions..hum"
              This one selects the hum value of any element of conditions.
              BKeyportB 1 Reply Last reply
              • BKeyportB
                @wishmaster270 Brilliant. Thank you. JSON is still quite the mystery to me sometimes. :)
                • BKeyportB
                  One last thing - where in the CSS do I adjust the font size for the module? I want it to use the MM “Large” font, as it’s on a wall display across from my desk. Can’t seem to find it.
                  • wishmaster270W
                    @BKeyport
                    Hi, great that it works now.
                    There are two different ways of how to change the font-size.
                    Either by using the classes option and add large to the element you want the font-size to be changed. i.e.:
                    			header: "Module-1",
                    				groups: [
                    						items: [
                    								values: [
                    										classes: "large",
                    										jsonpath: "data.conditions..hum",
                    The main problem with this solution is that the font-size of the valueTitle and the value itself is changed.
                    Or you can use custom.css to do the job:
                    .MMM-ValuesByNotification .vbn .groupTitle,
                    .MMM-ValuesByNotification .vbn .itemTitle,
                    .MMM-ValuesByNotification .vbn .value,
                    .MMM-ValuesByNotification .vbn .valueTitle {
                      font-size: var(--font-size-large);
                      line-height: 1;
                    In this example the font-size of all titles and the value is changed. I use the font-size-large CSS variable of the main.css for this job.
                    • BKeyportB
                      Thanks again, man. :)
                      I might not have to work up my own module to get the notifications. 🤣
                      Reply Quote -1
                      • BKeyportB
                        I’m using the example scripts in CommandToNotification using a BME280. I’m trying to keep the temperature in F to two digits, as the script or BME module is producing LONG temperature values. (76.0000000000000000000000001)
                        Using the configuration below, I’m not getting any rounding on output. The “valueFormat” is directly from your README.md.
                        			module: "MMM-ValuesByNotification", // https://github.com/Tom-Hirschberger/MMM-ValuesByNotification
                        			position: "top_bar",
                        				animationSpeed: 0,
                        				updateInterval: 15,
                        				groups: [
                        						items: [
                        								values: [
                        										valueTitle: "Closet",
                        										valueUnit: "°F",
                        										jsonpath: "data.conditions[1].temp_in",
                        										naValue: "0",
                        						items: [
                        								notification: "TEMPROOM",
                        								itemTitle: "Room",
                        								values: [
                        										valueTitle: "Temp",
                        										valueUnit: "°F",
                        										naValue: "0",
                        										valueFormat: "Number(${value}).toFixed(2)",
                        										jsonpath: "temperature_f",
                        wishmaster270W 2 Replies Last reply
                        • wishmaster270W
                          @BKeyport
                          that’s definitly a bug. It is related to the problem you described in the issue on github.
                          I found a fix already but i need a moment to solve it proper.
                          As a quickfix you can change line 299 in MMM-ValuesByNotification.js from
                          						value = value.replace(/(?:\r\n|\r|\n)/g, newlineReplacement)
                          to
                          						value = String(value).replace(/(?:\r\n|\r|\n)/g, newlineReplacement)
                          • wishmaster270W
                            @BKeyport
                            Just released version 0.0.8 of the module which should fix both issues
                            • BKeyportB
                              @wishmaster270 Submitted a pull - please tell me what you think… I didn’t update the documentation however. I figured you could handle that, as I’m a horrible documentation writer.
                              • wishmaster270W
                                @BKeyport Hi, and thanks for the contribution. I only had a view moments to look at the changes.
                                Currently the changes do not look very critical and I will be happy to merge them.
                                I only want to make sure there is no more universal way (especially for the space) feature.
                                Documentation is one of my favourites (Not). But it should no big deal to add it.
                                I will try to do a deeper look the code the next days and will merge as fast as I can.
