    [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons
    25 Posts 3 Posters 7.6k Views 2 Watching
    • Cr4z33C Offline
      Cr4z33 @wishmaster270
      @wishmaster270 said in [MMM-ValuesByNotification] Display the payloads of notifications with titles and icons:
      Does your powermeter send the data via MQTT already?
      Yes
      Do you have the MMM-MQTTbridge module configured to connect to your MQTT broker, subscribe for the topic(s) and send the data via notification?
      Nope, but I will set it up as soon as I finish posting this reply! :thumbs_up_light_skin_tone:
      How does the data look like? Is it plain text or is it a JSON object?
      I’ve got Zigbee2MQTT running in a Docker and if I look at its logs it shows lines like
      Zigbee2MQTT:info  2022-10-04 15:45:08: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":645,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
      Zigbee2MQTT:info  2022-10-04 15:45:10: MQTT publish: topic 'zigbee2mqtt/BTicino F20T60A', payload '{"device":{"applicationVersion":0,"dateCode":" \u000020180829\u0000\u0000\u0000\u0000\u0000","friendlyName":"BTicino F20T60A","hardwareVersion":1,"ieeeAddr":"0x000474000089a3e4","manufacturerID":4129,"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000","model":"412015","networkAddress":16238,"powerSource":"Mains (single phase)","softwareBuildID":"016\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000 \u0002\u0000\u0001\u0000 \u0002\u0000\u0002\u0000!\u0012\u0000\u0000\u0000\u0000  \u0003\u0000\u0010\u0002\u0001\u0004\u0000\u0018\u0002\u0000  !","stackVersion":64,"type":"Router","zclVersion":2},"linkquality":90,"power":610,"power_alarm":null,"power_alarm_active":true,"power_alarm_active_value":2}'
      If it is JSON how is the data structured and which values do you want to display?
      I want to display the power value.
      • wishmaster270W Offline
        wishmaster270 Module Developer @Cr4z33
        @Cr4z33
        Should be no problem:
        MMM-MQTTbridge/dict/mqttDictionary.js:
        var mqttHook = [
            mqttTopic: "zigbee2mqtt/BTicino F20T60A",
            mqttPayload: [
                payloadValue: "",
                mqttNotiCmd: ["POWERMETER"],
                mqttPayload: ""
        var mqttNotiCommands = [
            commandId: "POWERMETER",
            notiID: "POWERMETER_VALUES",
        module.exports = { mqttHook,  mqttNotiCommands};
        config.js:
        			module: "MMM-ValuesByNotification",
                                        updateInterval: 60,
                                        reuseCount: 5,
        				groups: [
        						items: [
        								notification: "POWERMETER_VALUES",
        								itemTitle: "Power",
        								values: [
        										valueUnit: "W",
        										jsonpath: "power",
        Will look like:
        You may want to configure the updateInterval and/or reuseCount to your needs.
        Cr4z33C 1 Reply Last reply Reply Quote 1
        • Cr4z33C Offline
          @wishmaster270 thank you it worked at first try!
          Now I can go on with some aesthetic changes like icons, etc. :D
            @Cr4z33
            Just tested a view things.
            If you like you can use font awesome icon instead of the title:
                                            updateInterval: 60,
                                            reuseCount: 5,
            				groups: [
            						items: [
            								//itemTitle: "Power",
            								values: [
            										classes: "power",
            										valueIcon: "fa fa-bolt",
            										valueUnit: "W",
            										jsonpath: "power",
            custom.css:
            .vbn .valueIcon.power {
              color: orange;
            • Cr4z33C Offline
              @wishmaster270 thanks I applied that instead.
              Anyway to add some offset to the module to be aligned with the other modules on the left?
                @Cr4z33
                sorry i do not understand exactly what you mean
                Cr4z33C 2 Replies Last reply Reply Quote 0
                • Cr4z33C Offline
                  @wishmaster270 I wanted to move your module way more to the left so to align it with my other modules (Google Assistant, clock and Spotify).
                  However nevermind as I opted to have your module on top instead. ;)
                  • Cr4z33C Offline
                    @wishmaster270 sorry for bothering you again… :grinning_face_with_sweat:
                    What if I want no border?
                    Would I have to edit the module’s CSS or can I just add something to custom.css?
                      @Cr4z33
                      No problem.
                      Simply add
                      .vbn .groupWrapper {
                        border-style: none;
                        padding: 0px;
                      to your custom.css
                      Ps.: Try to never ever edit any files in the module directory (except mentioned in the documentation) as you will get problems with updates in the future otherwise!
                      • Cr4z33C Offline
                        @wishmaster270 exactly what I wanted thanks!
