    calendar module - format today events with time
    8 Posts 4 Posters 2.3k Views 4 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer
      I would like to format the calendar events of today and tomorrow relatively with time. All other events should be formatted in the form “ddd, D.MMM, HH:mm”.
      In the new version there is a new config option showTimeToday with which I should be able to do this. But I don’t get along with it and need help.
      The events should be displayed like this for example:
      appointment-1                 Heute, 18:00
      appointment-2                Morgen, 14:00
      appointment-3            Mo, 30.Okt, 09:00
      my config is
      		header: "Nächste Termine ",
      			fetchInterval: 600000, // 10 Minuten
      					/* Kalender Paula */
      					symbol: "female",
      					url: "....ics"
      					/* Kalender Sepp */
      					symbol: "male",
      					url: "....ics"
      			maxTitleLength: 21,
      			wrapEvents: false,
      			dateFormat: "ddd, D.MMM, HH:mm",
      			fullDayEventDateFormat: "ddd, D.MMM",
      			timeFormat: "absolute",
      			getRelative: 12,
      			urgency: 0,
      			showEnd: false,
      			maximumEntries: 6,
      			fade: false,
      			hidePrivate: false,
      			nextDaysRelative: true,
      			sliceMultiDayEvents: false,
      			showTimeToday: true,
      Many thanks for any help.
      Many greetings
      Sepp
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
        sdetweil @spitzlbergerj
        @spitzlbergerj generally in absolute mode, urgency (days NOT HOURS) is used to create a window of time to still show relative timed events
        but you have it set to 0
        			getRelative: 12,
        			urgency: 0,
        showTimeToday does the reverse…
        in relative mode forces today’s events to NOT be relative. only for today, no other time window
        get relative is used in relative mode for AN hour based time window
        spitzlbergerjS 1 Reply Last reply Reply Quote 0
          spitzlbergerj Project Sponsor Module Developer @sdetweil
          @sdetweil Thank you for the quick reply.
          IfI set
          urgency: 1
          then an appointment for today is displayed like this
          Test appointment                            in 4 hours
          but I would like to have the display
          Test appointment                              today, 17:00
          how can I achieve this?
          thanks
          Josef
          Regards
          Josef
          KamiSchamiK S 2 Replies Last reply Reply Quote 1
          • KamiSchamiK Offline
            KamiSchami @spitzlbergerj
            @spitzlbergerj , das nervt mich auch schon länger. Vielleicht gibt es ja eine Lösung. - …this has been bothering me for a long time. Maybe there is a solution.
            Real programmers never work 9 to 5. If they are around at 9 AM, it’s because they were up all night.
              @spitzlbergerj according to the code
              showTimeToday must be false, and dateFornat must be ‘relative’, not absolute
                @sdetweil Thanks again for your answer. But that unfortunately still does not do the whole job
                config:
                maxTitleLength: 21,
                wrapEvents: false,
                timeFormat: "relative",
                getRelative: 12,
                urgency: 1,
                showEnd: false,
                maximumEntries: 6,
                fade: false,
                hidePrivate: false,
                showTimeToday: false,
                result:
                I actually just want the display like with timeformat: “absolute”. Only that with the current day simply “Today” is indicated and the same perhaps also with “Tomorrow”.
                desired result:
                Unfortunately I am too little experienced in coding the MagicMirror programs. Otherwise I would suggest a change for this, if the behavior is not achievable with the current settings.
                Could you, dear @sdetweil, do that? Thanks a lot
                Josef
                Regards
                Josef
                  @spitzlbergerj no way without significant code changes… sorry
                  you can ‘most’ of the way there with
                          getRelative: 1,
                  1st is full day
                  2nd is upcoming in 3 hours
                    @sdetweil Thanks a lot for your help! I’ll try it in this way
                    Regards
                    Josef
