    calendar module - format today events with time
    8 Posts 4 Posters 1.7k Views 4 Watching
    • spitzlbergerjS Offline
      spitzlbergerj Project Sponsor Module Developer @sdetweil
      @sdetweil Thank you for the quick reply.
      IfI set
      urgency: 1
      then an appointment for today is displayed like this
      Test appointment                            in 4 hours
      but I would like to have the display
      Test appointment                              today, 17:00
      how can I achieve this?
      thanks
      Josef
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
      KamiSchamiK S 2 Replies Last reply Reply Quote 1
      • KamiSchamiK Offline
        KamiSchami @spitzlbergerj
        @spitzlbergerj , das nervt mich auch schon länger. Vielleicht gibt es ja eine Lösung. - …this has been bothering me for a long time. Maybe there is a solution.
        Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
          sdetweil @spitzlbergerj
          @spitzlbergerj according to the code
          showTimeToday must be false, and dateFornat must be ‘relative’, not absolute
          spitzlbergerjS 1 Reply Last reply Reply Quote 0
            @sdetweil Thanks again for your answer. But that unfortunately still does not do the whole job
            config:
            maxTitleLength: 21,
            wrapEvents: false,
            dateFormat: "ddd, D.MMM, HH:mm",
            fullDayEventDateFormat: "ddd, D.MMM",
            timeFormat: "relative",
            getRelative: 12,
            urgency: 1,
            showEnd: false,
            maximumEntries: 6,
            fade: false,
            hidePrivate: false,
            nextDaysRelative: true,
            sliceMultiDayEvents: false,
            showTimeToday: false,
            result:
            I actually just want the display like with timeformat: “absolute”. Only that with the current day simply “Today” is indicated and the same perhaps also with “Tomorrow”.
            desired result:
            Unfortunately I am too little experienced in coding the MagicMirror programs. Otherwise I would suggest a change for this, if the behavior is not achievable with the current settings.
            Could you, dear @sdetweil, do that? Thanks a lot
            Josef
            Regards
            Josef
              @spitzlbergerj no way without significant code changes… sorry
              you can ‘most’ of the way there with
                      getRelative: 1,
              1st is full day
              2nd is upcoming in 3 hours
                @sdetweil Thanks a lot for your help! I’ll try it in this way
                Regards
                Josef
