    Hide a module by default
    11 Posts 3 Posters 4.2k Views 3 Watching
      sdetweil @rudiau
      @rudiau there is a new setting in config.js
      after module:
      hidden: true,
        sdetweil @rudiau
        @rudiau said in Hide a module by default:
        if(notification === “ALL_MODULES_STARTED”)
        this.hidden=true;
        also, it would be
        this.hide()
        it will do all the work and call your suspend() function
          sdetweil @rudiau
          @rudiau also, the code wrapper things have to be on their own line
          paste you text
          select it
          and hit the button above that looks like this
            rudiau
            Thanks for the quick response Sam.
            Still no good.
            Posted below are the config.js and helloworld .js(part of), is that what you meant by the ‘this.hide()’ placement.
            BTW on your code you posted on May 30, 2020, 6:07 AM
            there is a fullstop after the closing curly bracket, should that be a comma or nothing ie just a closing bracket.
            Thanks for the code posting tip, much easier.
            (closing bracket query)
            notificationReceived: function(notification, payload, source){
               // this comes before the first call to getDom()
               if(notification === "ALL_MODULES_STARTED")
                  this.hidden=true;
                module: "helloworld",
                hidden: true,
                position: "middle_center", // This can be any of the regions.
                  text: "Hello world!",
            (this.hide query)
             notificationReceived: function (notification, payload, source) {
               //if(notification === "ALL_MODULES_STARTED")
                  //this.hidden=true;
                    this.hide()
            S BKeyportB 2 Replies Last reply
              sdetweil @rudiau
              @rudiau ok, full-stop? you mean semi-colon?
              not required in js unless everything is on the same line
              as for hidden, I am an idiot, see the doc
              BKeyportB 1 Reply Last reply
                rudiau
                hiddenOnStartup
                Perfect.
                Thank you Sam.
                • BKeyportB
                  @sdetweil “fullstop” is the period. In your original, it looks like there was a comma. :)
                    sdetweil @BKeyport
                    @BKeyport ok, I don’t see where you are referencing
                    • BKeyportB
                      BKeyport Module Developer @rudiau
                      @sdetweil:
                      >       this.hidden=true;
                      Looks it was all his actually. The last line of that code has the fullstop after a closing curly bracket.
                        sdetweil @BKeyport
                        @BKeyport ah, I see the question… never heard a period called that
