    More then one Grafana Chart
    3 Posts 2 Posters 808 Views 2 Watching
      michaelJoosten
      Hey there,
      is it possible to show more then one Grafana Chart on the MM.
      (preferably on another page)
      Mikel
      • wishmaster270W Offline
        wishmaster270 Module Developer @michaelJoosten
        @michaelJoosten
        I tried some things with Grafana the last days and developed a module called MMM-EmbedURL.
        It is able to display multiple Grafana panels in Iframes or Webviews. No matter what type of panel it can be displayed (Chart, Gauge, etc.).
        BUT: You will need to configure Grafana to allow anonymous access to the panels you like to embed. I added a HowTo of a possible Grafana configuration.
        All anonymous access will be mapped to one organization. If you configure two different organizations you can decide which panels should be visible without login and which ones require authentication.
        The module supports multi-instance. You can add it with different configuration to different positions.
        Edit: Depending of which module you use to realize the pages you may need to copy the module cause i.e. MMM-pages uses the module name as identifier. MMM-ProfileSwitcher instead uses “classes”.
          michaelJoosten @wishmaster270
          @wishmaster270
          Thank you very much - i will try this
