    Motion Detector
    213 Posts 38 Posters 584.3k Views 39 Watching
    • in_a_daysI
      in_a_days @jdahli1
      @jdahli1
      Unfortunately, I’m pretty new too!
      To update - my mirror would still freeze (though it might take a couple hours) even after the changes I suggested. For me, the last error before the crash ALWAYS comes from the system status module (same exact ENOMEM error from the @trividar post). With the sys stat module disabled, I seem to be crash free. May not be the same thing you’re experiencing.
      I also removed Watchdog after reading a bit more about it’s purpose.
      If you are able to copy the log file from your most recent crash, someone smarter than me may be able to help.
      M 1 Reply Last reply
        mydiva @in_a_days
        @in_a_days how did you disabled sys stat module? and what is that? by the way I have the same thing happen like @trividar
        in_a_daysI 1 Reply Last reply
        • in_a_daysI
          in_a_days @mydiva
          @mydiva
          The system stat module I’m referring to is this one.
          https://github.com/BenRoe/MMM-SystemStats
          It would have to be specifically installed by the user. But looking at the screenshot from @trividar, there are a couple different modules throwing up errors. These couple lines show the modules that appear to be crashing the system:
          You can see mmm-systemtemperature and MMM-DHT22 producing error events. I would start by commenting out these modules. Just add a
          before and a
          after the section of your config.js file that loads these modules. If that eliminates the crashing you can be confident it is these modules causing the problem, and you can either try to fix them or look for alternatives.
          EDIT: The common theme between my error and the error posted here is the ENOMEM code, and the fact that all these modules are measuring system temperature. MMM-SystemStats, mmm-systemtemperature, and MMM-DHT22 are all reading temperatures. I would be willing to bet there’s a bug or memory leak somewhere in the code that is pulling or logging temperature info. I’m not convinced any of these particular errors are related to the Motion Detector module.
          • in_a_daysI
            in_a_days
            Well… so much for that theory lol. I just got the ENOMEM error from Motion Detector.
              danielis
              I had the same issue.
              For me was the solution to increase the capture interval time from 100ms to 1000ms.
              With the default value of 100ms the overall systemload is to high and one of the two electron processes will use after some time around 85% of the memory. At that value the system slows down extremely and the memory swap process will take all cpu ressources while trying to free up physical memory.
              And then anything can happen … (white screen, unresponsive, ENOMEM exceptions, …)
              Go to motiondetector.js and search for this code part:
              DiffCamEngine.init(
              video: video,
              motionCanvas: canvas,
              Add the following line to change the default capture interval time of 100ms to 1000ms:
              DiffCamEngine.init(
              video: video,
              captureIntervalTime: 1000,
              Observe the two electron processes and they will not reach memory values higher than 30%.
              J T in_a_daysI 3 Replies Last reply
              Reply Quote 2
                jdahli1 @danielis
                @danielis Fingers crossed, this appears to be working! The mirror has turned on and off a dozen times now with no processor or RAM issues.
                • T
                  trividar @danielis
                  @danielis woooow its working now since one hour!! thank you!!!
                  • in_a_daysI
                    in_a_days @danielis
                    Same here. Great work and many thanks @danielis!
                    • slametpsS
                      slametps
                      Is this module work along with MMM-Facial-Recognition using the same camera?
                      regards,
                      Slamet PS
                        danielis
                        Not working here. Only either one or the other.
                        But paviro said he will include a motion detection to the facial recognition module at some time.
                        I will try to do it also. Will report if I have success
                        • O
                          oscarkindberg
                          Hi!
                          I’m trying to get this to work, have a USB cam attached to the RPI3 and installed the .js.
                          But when I add the code:
                          module: ’motiondetector’,
                          config:
                          Am I missing something? Because it only give me errors… :(
                          (new to this)
                          • in_a_daysI
                            in_a_days @oscarkindberg
                            @oscarkindberg Try this instead:
                                                module: 'motiondetector',
                                                        timeout: 300000 // time in milliseconds for to switch off the display after last movement is detected.
                            This is set for a 5 minute delay. Modify the timeout value if you want a longer or shorter delay before your screen turns off.
                            O 1 Reply Last reply
                            • O
                              oscarkindberg @in_a_days
                              @in_a_days Hit! Works now, BUT next issue.
                              After 5-6 min the screens goes white, can’t find anything in the code that would cause that.
                              D 1 Reply Last reply
                                phoenixrising
                                I apologize if this a very noob question but I am having trouble getting the motion detector module running. I have clone the files to the module folder. I have modified the config file but maybe I dont have it correct. Could some one show me how the config file be modified to get the module running. Any other pointers? Thank you,
                                  danielis @oscarkindberg
                                  @oscarkindberg try hdmi_blanking=1in /boot/config.txt
                                    danielis @phoenixrising
                                    @phoenixrising look at the last reply of in_a_days.
                                    If that is not working post your config.js here.
                                    • O
                                      oscarkindberg @danielis
                                      @danielis Where do I fint that? I’ve searched all the .js files in the module and config.
                                        @oscarkindberg it is the file config.txt in the folder /boot/
                                        type ‘sudo nano /boot/config.txt’ without ’
                                        add as last line:
                                        hdmi_blanking=1
                                        • O
                                          @danielis Actually got it to work now, changed to “updateInterval: 10000” from “updateInterval: 1000” and in diff-cam-engine.js I changed captureIntervalTime to 1000 instead of 100.
                                          Made it easier on the RBP3 i think.
                                          Downloaded MMM-SystemStats to keep check on sysload during config and it’s lookin’ good now.
                                          Thanks for the help! I’ll comeback with a picture of the mirror as soon as my mirrorglas arrives.
                                          P 1 Reply Last reply
                                            phoenixrising @oscarkindberg
                                            @oscarkindberg where is the updateinterval located?
                                            • 10
                                            • 11
                                            • 8 / 11
