    MMM-Flights
    52 Posts 9 Posters 32.6k Views 9 Watching
    • K
      KI6UVE @sdetweil
      • K
        KI6UVE @sdetweil
          sdetweil @KI6UVE
          @KI6UVE turn off using the gpu
          set environment variable
          export ELECTRON_DISABLE_GPU=1
          in the script used to launch mm…
          if using my install script and pm2,.
          that file is MagicMirror/installers/mm.sh
          • K
            KI6UVE @sdetweil
              sdetweil @KI6UVE
              @KI6UVE no, just restart mm
              • K
                KI6UVE @karsten13
                @karsten13
                Is there a way to configure the flight data output to make the units Imperial instead of metric?
                • karsten13K
                  karsten13 @KI6UVE
                  @KI6UVE
                  no, but should not be a big thing to implement this.
                  I see the m for the height and km/h for speed, so what are the correct imperial units?
                  ft for m?
                  mph for km/h?
                  • K
                    KI6UVE @karsten13
                    @karsten13
                    Yes, ft and mph
                    Thanks!!
                    • karsten13K
                      karsten13 @KI6UVE
                      @KI6UVE
                      new version is released with new config option units, see https://gitlab.com/khassel/MMM-Flights/-/blob/master/MMM-Flights.js#L41
                      update instructions for the module: https://gitlab.com/khassel/MMM-Flights#update-to-new-versions
                      • K
                        KI6UVE @karsten13
                        @karsten13
                        Awesome!! vielen Dank
                        • L
                          lif
                          I have MMM-Flights working well except mapFixedArea: true, seems to be ignored.
                          The map changes width depending upon the ac in the area.
                          Also the map shows even with no traffic and showMap: “ifTraffic”,
                          Any ideas or thoughts?
                          S karsten13K 2 Replies Last reply Reply Quote 0
                            sdetweil @lif
                            @lif can u show the config for this module
                            • karsten13K
                              karsten13 @lif
                              @lif said in MMM-Flights:
                              yes, the map changes width because of the length of the flight data in the table below, the area inside the map does not change. You can test this with setting mapFontColor: "red", so you see the area points.
                              But I have to rethink this behavior or provide an option for a fixed width.
                              will look into this, I did a rewrite of the module so maybe this was lost …
                              • L
                                lif @sdetweil
                                @sdetweil said in MMM-Flights:
                                module code
                                 * @file MMM-Flights.js
                                 * @author Karsten Hassel
                                 * @license MIT
                                 * @see  https://gitlab.com/khassel/MMM-Flights
                                Module.register("MMM-Flights", {
                                  defaults: {
                                    provider: "flightradar24",
                                    instanceId: "FR", // needs to be set to different values if you run more than 1 instance of this module
                                    // // example for ADSBexchange:
                                    // provider: "ADSBexchange",
                                    // providerApiKey: "your-api-key",
                                    // providerUrl: "https://adsbx-flight-sim-traffic.p.rapidapi.com/api/aircraft/json",
                                    // // example for opensky:
                                    // provider: "opensky",
                                    // providerApiKey: "user:password", //optional, without limited requests
                                    // providerUrl: "https://opensky-network.org/api/states/all",
                                    unknown: "?", // string used if no data available
                                    title: "Flights Above Us",
                                    logoTitle: "fas fa-plane",
                                    logoUp: "fas fa-plane-departure",
                                    logoDown: "fas fa-plane-arrival",
                                    logoTo: "fas fa-arrow-right",
                                    // area defined by a bounding box of WGS84 coordinates (la=latitude, lo=longitude):
                                    laMin: 49.85,
                                    laMax: 50.25,
                                    loMin: 7.8,
                                    loMax: 9.3,
                                    showGrounded: false, // show grounded airplanes
                                    showMap: "ifTraffic", // "always", "never", "ifTraffic"
                                    noFlightsMessage: "Currently no flights in chosen area ...", // message shown if no data available
                                    mapUrl: "https://{a-d}.basemaps.cartocdn.com/light_all/{z}/{x}/{y}.png", // you can bring your own map
                                //    mapAttributions:      '',
                                    mapHeight: "300px",
                                    mapFixedArea: true, // if set, the defined area is shown, if not the area is calculated from the plane locations
                                    mapPosition: "bottom", // "top" or "bottom"
                                    // some params to define styles in map:
                                    mapFont: "40% sans-serif",
                                    mapPadding: [1, 5, 0, 7],
                                    mapFontColor: "white",
                                    mapBackgroundColor: "black",
                                    mapCurrentFlightColor: "#9c294f",
                                    mapBackgroundOpacity: 0.9,
                                    mapPlanePngSrc: "modules/MMM-Flights/data/plane.png",
                                    mapPlanePngScale: 0.07,
                                    mapPlaneTextOffset: 4,
                                    useMockData: false, // if set, test data is used
                                    updateInterval: 2 * 60 * 1000, // every 2 minutes
                                    units: "imperial", // metric uses m and km/h, imperial uses ft and mph
                                Config.js
                                      module: "MMM-Flights",
                                      position: "center",
                                        laMin: 45.80,
                                        laMax: 46.0081,
                                        loMin: 0.4674,
                                        loMax: 1.207,
                                Hope this helps
                                Regards
                                • L
                                  lif @karsten13
                                  @karsten13 said in MMM-Flights:
                                  Ah, OK, I’ll change the font size down a bit.
                                  Yes, it did work before I applied an update this morning
                                  Thanks for your help.
                                    sdetweil @lif
                                    @lif please NEVER edit the source file. unless you KNOW what you are getting yourself into.
                                    all config should go in config.js
                                    everything in the defaults section can be overridden in config.js
                                    also on forum posts use the code block wrapper for all code and config.
                                    paste text into message editor
                                    select pasted text
                                    hit button </>
                                    • karsten13K
                                      karsten13 @lif
                                      should be fixed now with latest version …
                                      • L
                                        lif @sdetweil
                                        When the {module}.js file has lines which state something like
                                        'units: “imperial”, // metric uses m and km/h, imperial uses ft and mph,
                                        I assume that it can be changed in the {module}.js file.
                                        Some modules list all the options in the example that goes into the config.js file, MMM-Flights (and many others) don’t.
                                        select pasted text
                                        hit button </>
                                        OK, sorry.
                                        • L
                                          lif @karsten13
                                          Sorry, still the same after (I think) installing the latest version
                                          • karsten13K
                                            karsten13 @lif
                                            @lif
                                            was talking about showMap: "ifTraffic", and this works on my side, tested it again
                                            • 2 / 3
