    MMM-Flights
    51 Posts 8 Posters 28.0k Views 8 Watching
      sdetweil @KI6UVE
      @KI6UVE no, just restart mm
      • K Offline
        KI6UVE @karsten13
        @karsten13
        Is there a way to configure the flight data output to make the units Imperial instead of metric?
        • karsten13K Offline
          karsten13 @KI6UVE
          @KI6UVE
          no, but should not be a big thing to implement this.
          I see the m for the height and km/h for speed, so what are the correct imperial units?
          ft for m?
          mph for km/h?
          • K Offline
            KI6UVE @karsten13
            @karsten13
            Yes, ft and mph
            Thanks!!
              karsten13 @KI6UVE
              @KI6UVE
              new version is released with new config option units, see https://gitlab.com/khassel/MMM-Flights/-/blob/master/MMM-Flights.js#L41
              update instructions for the module: https://gitlab.com/khassel/MMM-Flights#update-to-new-versions
              • K Offline
                KI6UVE @karsten13
                @karsten13
                Awesome!! vielen Dank
                • L Offline
                  lif
                  I have MMM-Flights working well except mapFixedArea: true, seems to be ignored.
                  The map changes width depending upon the ac in the area.
                  Also the map shows even with no traffic and showMap: “ifTraffic”,
                  Any ideas or thoughts?
                  S karsten13K 2 Replies Last reply Reply Quote 0
                    sdetweil @lif
                    @lif can u show the config for this module
                      karsten13 @lif
                      @lif said in MMM-Flights:
                      yes, the map changes width because of the length of the flight data in the table below, the area inside the map does not change. You can test this with setting mapFontColor: "red", so you see the area points.
                      But I have to rethink this behavior or provide an option for a fixed width.
                      will look into this, I did a rewrite of the module so maybe this was lost …
                      • L Offline
                        lif @sdetweil
                        @sdetweil said in MMM-Flights:
                        module code
                         * @file MMM-Flights.js
                         * @author Karsten Hassel
                         * @license MIT
                         * @see  https://gitlab.com/khassel/MMM-Flights
                        Module.register("MMM-Flights", {
                          defaults: {
                            provider: "flightradar24",
                            instanceId: "FR", // needs to be set to different values if you run more than 1 instance of this module
                            // // example for ADSBexchange:
                            // provider: "ADSBexchange",
                            // providerApiKey: "your-api-key",
                            // providerUrl: "https://adsbx-flight-sim-traffic.p.rapidapi.com/api/aircraft/json",
                            // // example for opensky:
                            // provider: "opensky",
                            // providerApiKey: "user:password", //optional, without limited requests
                            // providerUrl: "https://opensky-network.org/api/states/all",
                            unknown: "?", // string used if no data available
                            title: "Flights Above Us",
                            logoTitle: "fas fa-plane",
                            logoUp: "fas fa-plane-departure",
                            logoDown: "fas fa-plane-arrival",
                            logoTo: "fas fa-arrow-right",
                            // area defined by a bounding box of WGS84 coordinates (la=latitude, lo=longitude):
                            laMin: 49.85,
                            laMax: 50.25,
                            loMin: 7.8,
                            loMax: 9.3,
                            showGrounded: false, // show grounded airplanes
                            showMap: "ifTraffic", // "always", "never", "ifTraffic"
                            noFlightsMessage: "Currently no flights in chosen area ...", // message shown if no data available
                            mapUrl: "https://{a-d}.basemaps.cartocdn.com/light_all/{z}/{x}/{y}.png", // you can bring your own map
                        //    mapAttributions:      '',
                            mapHeight: "300px",
                            mapFixedArea: true, // if set, the defined area is shown, if not the area is calculated from the plane locations
                            mapPosition: "bottom", // "top" or "bottom"
                            // some params to define styles in map:
                            mapFont: "40% sans-serif",
                            mapPadding: [1, 5, 0, 7],
                            mapFontColor: "white",
                            mapBackgroundColor: "black",
                            mapCurrentFlightColor: "#9c294f",
                            mapBackgroundOpacity: 0.9,
                            mapPlanePngSrc: "modules/MMM-Flights/data/plane.png",
                            mapPlanePngScale: 0.07,
                            mapPlaneTextOffset: 4,
                            useMockData: false, // if set, test data is used
                            updateInterval: 2 * 60 * 1000, // every 2 minutes
                            units: "imperial", // metric uses m and km/h, imperial uses ft and mph
                        Config.js
                              module: "MMM-Flights",
                              position: "center",
                                laMin: 45.80,
                                laMax: 46.0081,
                                loMin: 0.4674,
                                loMax: 1.207,
                        Hope this helps
                        Regards
                        • L Offline
                          lif @karsten13
                          @karsten13 said in MMM-Flights:
                          Ah, OK, I’ll change the font size down a bit.
                          Yes, it did work before I applied an update this morning
                          Thanks for your help.
                            sdetweil @lif
                            @lif please NEVER edit the source file. unless you KNOW what you are getting yourself into.
                            all config should go in config.js
                            everything in the defaults section can be overridden in config.js
                            also on forum posts use the code block wrapper for all code and config.
                            paste text into message editor
                            select pasted text
                            hit button </>
                              karsten13 @lif
                              should be fixed now with latest version …
                              • L Offline
                                lif @sdetweil
                                When the {module}.js file has lines which state something like
                                'units: “imperial”, // metric uses m and km/h, imperial uses ft and mph,
                                I assume that it can be changed in the {module}.js file.
                                Some modules list all the options in the example that goes into the config.js file, MMM-Flights (and many others) don’t.
                                select pasted text
                                hit button </>
                                OK, sorry.
                                • L Offline
                                  lif @karsten13
                                  Sorry, still the same after (I think) installing the latest version
                                    karsten13 @lif
                                    @lif
                                    was talking about showMap: "ifTraffic", and this works on my side, tested it again
                                    • L Offline
                                      lif @karsten13
                                      @lif
                                      Yes
                                        sdetweil @lif
                                        no.
                                        in config.js
                                        the design is config js is used to override the values set in the modulename.js defaults section
                                        lacking documentation is a different probem.
                                        if you find properties in the defaults section you can override them in config.js
                                          @lif I have a module that presents a form for config customization, built on the fly based on the modules you have installed now
                                          it uses the values from defaults
                                          https://github.com/sdetweil/MMM-Config
                                          in places where there could be choices, the author can augment the definition to make it more usable and understandable.
                                          not every module works some need help.
                                          if the module is old or the author chooses not to provide an improved definition, I can ship one created by a user, with my module to make the user experience better.
                                          • L Offline
                                            lif @sdetweil
                                            Nice advert :-) but I’ve never been able to cut and paste, in some cases , 20 - 30 lines of options from the module config file to config.js using a command line editor if the author doesn’t give all the options in the default config.js example on Git Hub.
                                            • 2 / 3
