    MMM-Flights
    53 Posts 9 Posters 34.0k Views 9 Watching
    • L
      lif @sdetweil
      @sdetweil said in MMM-Flights:
      @lif can u show the config for this module
      module code
       * @file MMM-Flights.js
       * @author Karsten Hassel
       * @license MIT
       * @see  https://gitlab.com/khassel/MMM-Flights
      Module.register("MMM-Flights", {
        defaults: {
          provider: "flightradar24",
          instanceId: "FR", // needs to be set to different values if you run more than 1 instance of this module
          // // example for ADSBexchange:
          // provider: "ADSBexchange",
          // providerApiKey: "your-api-key",
          // providerUrl: "https://adsbx-flight-sim-traffic.p.rapidapi.com/api/aircraft/json",
          // // example for opensky:
          // provider: "opensky",
          // providerApiKey: "user:password", //optional, without limited requests
          // providerUrl: "https://opensky-network.org/api/states/all",
          unknown: "?", // string used if no data available
          title: "Flights Above Us",
          logoTitle: "fas fa-plane",
          logoUp: "fas fa-plane-departure",
          logoDown: "fas fa-plane-arrival",
          logoTo: "fas fa-arrow-right",
          // area defined by a bounding box of WGS84 coordinates (la=latitude, lo=longitude):
          laMin: 49.85,
          laMax: 50.25,
          loMin: 7.8,
          loMax: 9.3,
          showGrounded: false, // show grounded airplanes
          showMap: "ifTraffic", // "always", "never", "ifTraffic"
          noFlightsMessage: "Currently no flights in chosen area ...", // message shown if no data available
          mapUrl: "https://{a-d}.basemaps.cartocdn.com/light_all/{z}/{x}/{y}.png", // you can bring your own map
      //    mapAttributions:      '',
          mapHeight: "300px",
          mapFixedArea: true, // if set, the defined area is shown, if not the area is calculated from the plane locations
          mapPosition: "bottom", // "top" or "bottom"
          // some params to define styles in map:
          mapFont: "40% sans-serif",
          mapPadding: [1, 5, 0, 7],
          mapFontColor: "white",
          mapBackgroundColor: "black",
          mapCurrentFlightColor: "#9c294f",
          mapBackgroundOpacity: 0.9,
          mapPlanePngSrc: "modules/MMM-Flights/data/plane.png",
          mapPlanePngScale: 0.07,
          mapPlaneTextOffset: 4,
          useMockData: false, // if set, test data is used
          updateInterval: 2 * 60 * 1000, // every 2 minutes
          units: "imperial", // metric uses m and km/h, imperial uses ft and mph
      Config.js
            module: "MMM-Flights",
            position: "center",
              laMin: 45.80,
              laMax: 46.0081,
              loMin: 0.4674,
              loMax: 1.207,
      Hope this helps
      Regards
      • L
        lif @karsten13
        @karsten13 said in MMM-Flights:
        @lif said in MMM-Flights:
        The map changes width depending upon the ac in the area.
        yes, the map changes width because of the length of the flight data in the table below, the area inside the map does not change. You can test this with setting mapFontColor: "red", so you see the area points.
        Ah, OK, I’ll change the font size down a bit.
        But I have to rethink this behavior or provide an option for a fixed width.
        Also the map shows even with no traffic and showMap: “ifTraffic”,
        will look into this, I did a rewrite of the module so maybe this was lost …
        Yes, it did work before I applied an update this morning
        Thanks for your help.
        karsten13K 1 Reply Last reply
          sdetweil @lif
          @lif please NEVER edit the source file. unless you KNOW what you are getting yourself into.
          all config should go in config.js
          everything in the defaults section can be overridden in config.js
          also on forum posts use the code block wrapper for all code and config.
          paste text into message editor
          select pasted text
          hit button </>
          L 1 Reply Last reply
          • karsten13K
            karsten13 @lif
            should be fixed now with latest version …
            • L
              lif @sdetweil
              When the {module}.js file has lines which state something like
              'units: “imperial”, // metric uses m and km/h, imperial uses ft and mph,
              I assume that it can be changed in the {module}.js file.
              Some modules list all the options in the example that goes into the config.js file, MMM-Flights (and many others) don’t.
              select pasted text
              hit button </>
              OK, sorry.
              • L
                lif @karsten13
                Sorry, still the same after (I think) installing the latest version
                • karsten13K
                  karsten13 @lif
                  @lif
                  was talking about showMap: "ifTraffic", and this works on my side, tested it again
                  • L
                    lif @karsten13
                    @lif
                    Yes
                      sdetweil @lif
                      no.
                      in config.js
                      the design is config js is used to override the values set in the modulename.js defaults section
                      lacking documentation is a different probem.
                      if you find properties in the defaults section you can override them in config.js
                        @lif I have a module that presents a form for config customization, built on the fly based on the modules you have installed now
                        it uses the values from defaults
                        https://github.com/sdetweil/MMM-Config
                        in places where there could be choices, the author can augment the definition to make it more usable and understandable.
                        not every module works some need help.
                        if the module is old or the author chooses not to provide an improved definition, I can ship one created by a user, with my module to make the user experience better.
                        • L
                          lif @sdetweil
                          Nice advert :-) but I’ve never been able to cut and paste, in some cases , 20 - 30 lines of options from the module config file to config.js using a command line editor if the author doesn’t give all the options in the default config.js example on Git Hub.
                            sdetweil @lif
                            @lif it’s a fun challenge.
                            the downside of changing the modulename.js file is, when an update comes, git pull will fail. and YOU have to figure it out.
                            everything takes work. I’m just trying to help you learn the best practice so you don’t get smashed later on.
                              stashu
                              Hi! Thank you for the module, it is my favorite on my MM, as I live on the flight path to KIAD, so lots of activity.
                              I am wondering if there is a way I can hide the horizontal line which is under the ‘Flights’ label. When there are no flights, the line is still visible, and I would love if I were able to hide it somehow. I’m happy to add something to custom.css, but I am unsure how to do so. Thanks!
                              S karsten13K 2 Replies Last reply
                                sdetweil @stashu
                                @stashu So, there is indeed custom.css entry you can use the hide the separator on the header…
                                BUT I want to teach you how to find these things yourself… so you won’t be dependant on waiting for someone
                                see the second link in my signature below, it will show you how to use the developers window elements tab and locate the element that is displaying the thing you want to modify/hide…
                                in the upper right window you can try different styles on the selected element to see its behavior and once you’ve found it, you can copy paste those styles into custom.css
                                and put the selector wrapper around it.
                                the selector chain is shown on the bottom of the elements window , for example here on another element
                                  stashu @sdetweil
                                  @sdetweil thanks for the quick reply and the pointer to finding the element. I’m not in web stuff, so it’s a bit more of a mystery to me than I wish it were. Anyway, I found it, and the following custom.css entry works to remove the header:
                                  .MMM-Flights .module-header {
                                  	border-bottom: 0px; /* removes line */
                                  	font-size: 0px; /* removes 'Flights' and logo (?) */
                                  Not sure if that’s an elegant way, but it works :) . I’m not clear on why the 0 font size removes the logo, but it does.
                                  Thanks again!
                                    sdetweil @stashu
                                    @stashu all good… sorry for the firehose treatment… lol
                                    anyhow to hide an element is actually easier
                                    selector {
                                       display:none;
                                    • karsten13K
                                      karsten13 @stashu
                                      @stashu said in MMM-Flights:
                                      I updated the module, if you now set title and logoTitle to empty strings no header and no line is diplayed anymore.
                                      • W
                                        wswenson
                                        I would like to see a configuration option to filter out non-commercial flights. I played around with this code segment and think it could be done with some minor logic added for a configuration option of onlyCommercial (or something like that). I live in an area where there is a high concentration of private planes as well, and generally I am mostly interested in the commercial flights.
                                        I tried to open an issue in Gitlabs, but wants me to create an account and pay for membership and such.
                                        Thanks for the module!
                                         async makeFlightArray(configPayload) {
                                              let flights = [];
                                              const prov = configPayload.provider.toLowerCase();
                                              if (this.providers.includes(prov)) {
                                                await require(`./provider/${prov}`).getData(
                                                  configPayload,
                                                  flights,
                                                  this.airports,
                                                  this.airlines,
                                                  this.planes,
                                                  this.setFlightData,
                                                  this.fetchUrl
                                              } else {
                                                Log.error(
                                                  `${this.name}: Unknown provider  + ${configPayload.provider}`
                                        	  // Filter out flights with empty airline
                                              flights = flights.filter((flight) => flight.airline && flight.airline.trim() !== "");
                                        	  console.log(flights);
                                              return flights;
                                        • karsten13K
                                          karsten13 @wswenson
                                          @wswenson said in MMM-Flights:
                                          they are free see https://about.gitlab.com/pricing/
                                          will look into the filter stuff …
                                          • karsten13K
                                            karsten13 @wswenson
                                            now implemented with this commit
                                            Thanks for the suggestion!
                                            W 1 Reply Last reply
                                            • 2 / 3
