MMM-Flights
@lif I have a module that presents a form for config customization, built on the fly based on the modules you have installed now
it uses the values from defaults
https://github.com/sdetweil/MMM-Config
in places where there could be choices, the author can augment the definition to make it more usable and understandable.
not every module works some need help.
if the module is old or the author chooses not to provide an improved definition, I can ship one created by a user, with my module to make the user experience better. -
@sdetweil said in MMM-Flights:
if the module is old or the author chooses not to provide an improved definition, I can ship one created by a user, with my module to make the user experience better.Nice advert :-) but I’ve never been able to cut and paste, in some cases , 20 - 30 lines of options from the module config file to config.js using a command line editor if the author doesn’t give all the options in the default config.js example on Git Hub.
@lif it’s a fun challenge.
the downside of changing the modulename.js file is, when an update comes, git pull will fail. and YOU have to figure it out.
everything takes work. I’m just trying to help you learn the best practice so you don’t get smashed later on.
Hi! Thank you for the module, it is my favorite on my MM, as I live on the flight path to KIAD, so lots of activity.
I am wondering if there is a way I can hide the horizontal line which is under the ‘Flights’ label. When there are no flights, the line is still visible, and I would love if I were able to hide it somehow. I’m happy to add something to custom.css, but I am unsure how to do so. Thanks!
@stashu So, there is indeed custom.css entry you can use the hide the separator on the header…
BUT I want to teach you how to find these things yourself… so you won’t be dependant on waiting for someone
see the second link in my signature below, it will show you how to use the developers window elements tab and locate the element that is displaying the thing you want to modify/hide…
in the upper right window you can try different styles on the selected element to see its behavior and once you’ve found it, you can copy paste those styles into custom.css
and put the selector wrapper around it.the selector chain is shown on the bottom of the elements window , for example here on another element
@sdetweil thanks for the quick reply and the pointer to finding the element. I’m not in web stuff, so it’s a bit more of a mystery to me than I wish it were. Anyway, I found it, and the following custom.css entry works to remove the header:
.MMM-Flights .module-header { border-bottom: 0px; /* removes line */ font-size: 0px; /* removes 'Flights' and logo (?) */ }Not sure if that’s an elegant way, but it works :) . I’m not clear on why the 0 font size removes the logo, but it does.
Thanks again!
@stashu all good… sorry for the firehose treatment… lol
anyhow to hide an element is actually easier
selector { display:none; } -
@stashu said in MMM-Flights:
I updated the module, if you now set
titleandlogoTitleto empty strings no header and no line is diplayed anymore. -
I would like to see a configuration option to filter out non-commercial flights. I played around with this code segment and think it could be done with some minor logic added for a configuration option of onlyCommercial (or something like that). I live in an area where there is a high concentration of private planes as well, and generally I am mostly interested in the commercial flights.
I tried to open an issue in Gitlabs, but wants me to create an account and pay for membership and such.
Thanks for the module!
async makeFlightArray(configPayload) { let flights = []; const prov = configPayload.provider.toLowerCase(); if (this.providers.includes(prov)) { await require(`./provider/${prov}`).getData( configPayload, flights, this.airports, this.airlines, this.planes, this.setFlightData, this.fetchUrl ); } else { Log.error( `${this.name}: Unknown provider + ${configPayload.provider}` ); } // Filter out flights with empty airline flights = flights.filter((flight) => flight.airline && flight.airline.trim() !== ""); console.log(flights); return flights; },
@wswenson said in MMM-Flights:
they are free see https://about.gitlab.com/pricing/
will look into the filter stuff …
now implemented with this commit
Thanks for the suggestion!
@karsten13 Very nice and thank you!
Hi there,
Thanks for this great module!
Is it still working for other people? I can’t get flights to display on the map, eventhough they are definately there.I’ve tried to change the provider from FR24 to readsb, but neither seems to work.
Am I overlooking something here? Thanks for the help.{ module: "MMM-Flights", position: "top_left", config: { laMin: 51.6, laMax: 51.0, loMin: 5.2, loMax: 6.2, provider: "readsb", providerUrl: "https://api.airplanes.live/v2/point" }, }, -
works with both providers if you switch the content of your
laMin/laMaxvalues … -
@karsten13 Oh damn, that was pretty stupid. Thanks for your sharp eye!
It works now indeed!!is it possible to locate the list of flights on the right of the map, so I can utilize landscape mode better?
Hello, can anyone tell me if there is a way to limit the number of results this returns?
Phil -
This feature doesn’t exist at the moment. However, I’ve noticed myself that during peak times, the list can get so long that it scrolls off the bottom of the screen.
The question is how to implement such a filter. One idea would be a
maxPlanesproperty that displays only the n aircraft closest to your own position (both on the map and in the list). But perhaps you have a better suggestion? -
Meanwhile you can add
maxFlights: 0, // restrict number of shown flights (0 means show all)to the config.
