    MMM-Flights
    52 Posts 9 Posters 32.6k Views 9 Watching
    • K Offline
      KI6UVE @sdetweil
        sdetweil @KI6UVE
        @KI6UVE no, just restart mm
        • K Offline
          KI6UVE @karsten13
          @karsten13
          Is there a way to configure the flight data output to make the units Imperial instead of metric?
          • karsten13K Offline
            karsten13 @KI6UVE
            @KI6UVE
            no, but should not be a big thing to implement this.
            I see the m for the height and km/h for speed, so what are the correct imperial units?
            ft for m?
            mph for km/h?
            • K Offline
              KI6UVE @karsten13
              @karsten13
              Yes, ft and mph
              Thanks!!
                karsten13 @KI6UVE
                @KI6UVE
                new version is released with new config option units, see https://gitlab.com/khassel/MMM-Flights/-/blob/master/MMM-Flights.js#L41
                update instructions for the module: https://gitlab.com/khassel/MMM-Flights#update-to-new-versions
                • K Offline
                  KI6UVE @karsten13
                  @karsten13
                  Awesome!! vielen Dank
                  • L Offline
                    lif
                    I have MMM-Flights working well except mapFixedArea: true, seems to be ignored.
                    The map changes width depending upon the ac in the area.
                    Also the map shows even with no traffic and showMap: “ifTraffic”,
                    Any ideas or thoughts?
                    S karsten13K 2 Replies Last reply Reply Quote 0
                      sdetweil @lif
                      @lif can u show the config for this module
                        karsten13 @lif
                        @lif said in MMM-Flights:
                        yes, the map changes width because of the length of the flight data in the table below, the area inside the map does not change. You can test this with setting mapFontColor: "red", so you see the area points.
                        But I have to rethink this behavior or provide an option for a fixed width.
                        will look into this, I did a rewrite of the module so maybe this was lost …
                        • L Offline
                          lif @sdetweil
                          @sdetweil said in MMM-Flights:
                          module code
                           * @file MMM-Flights.js
                           * @author Karsten Hassel
                           * @license MIT
                           * @see  https://gitlab.com/khassel/MMM-Flights
                          Module.register("MMM-Flights", {
                            defaults: {
                              provider: "flightradar24",
                              instanceId: "FR", // needs to be set to different values if you run more than 1 instance of this module
                              // // example for ADSBexchange:
                              // provider: "ADSBexchange",
                              // providerApiKey: "your-api-key",
                              // providerUrl: "https://adsbx-flight-sim-traffic.p.rapidapi.com/api/aircraft/json",
                              // // example for opensky:
                              // provider: "opensky",
                              // providerApiKey: "user:password", //optional, without limited requests
                              // providerUrl: "https://opensky-network.org/api/states/all",
                              unknown: "?", // string used if no data available
                              title: "Flights Above Us",
                              logoTitle: "fas fa-plane",
                              logoUp: "fas fa-plane-departure",
                              logoDown: "fas fa-plane-arrival",
                              logoTo: "fas fa-arrow-right",
                              // area defined by a bounding box of WGS84 coordinates (la=latitude, lo=longitude):
                              laMin: 49.85,
                              laMax: 50.25,
                              loMin: 7.8,
                              loMax: 9.3,
                              showGrounded: false, // show grounded airplanes
                              showMap: "ifTraffic", // "always", "never", "ifTraffic"
                              noFlightsMessage: "Currently no flights in chosen area ...", // message shown if no data available
                              mapUrl: "https://{a-d}.basemaps.cartocdn.com/light_all/{z}/{x}/{y}.png", // you can bring your own map
                          //    mapAttributions:      '',
                              mapHeight: "300px",
                              mapFixedArea: true, // if set, the defined area is shown, if not the area is calculated from the plane locations
                              mapPosition: "bottom", // "top" or "bottom"
                              // some params to define styles in map:
                              mapFont: "40% sans-serif",
                              mapPadding: [1, 5, 0, 7],
                              mapFontColor: "white",
                              mapBackgroundColor: "black",
                              mapCurrentFlightColor: "#9c294f",
                              mapBackgroundOpacity: 0.9,
                              mapPlanePngSrc: "modules/MMM-Flights/data/plane.png",
                              mapPlanePngScale: 0.07,
                              mapPlaneTextOffset: 4,
                              useMockData: false, // if set, test data is used
                              updateInterval: 2 * 60 * 1000, // every 2 minutes
                              units: "imperial", // metric uses m and km/h, imperial uses ft and mph
                          Config.js
                                module: "MMM-Flights",
                                position: "center",
                                  laMin: 45.80,
                                  laMax: 46.0081,
                                  loMin: 0.4674,
                                  loMax: 1.207,
                          Hope this helps
                          Regards
                          • L Offline
                            lif @karsten13
                            @karsten13 said in MMM-Flights:
                            Ah, OK, I’ll change the font size down a bit.
                            Yes, it did work before I applied an update this morning
                            Thanks for your help.
                              sdetweil @lif
                              @lif please NEVER edit the source file. unless you KNOW what you are getting yourself into.
                              all config should go in config.js
                              everything in the defaults section can be overridden in config.js
                              also on forum posts use the code block wrapper for all code and config.
                              paste text into message editor
                              select pasted text
                              hit button </>
                                karsten13 @lif
                                should be fixed now with latest version …
                                • L Offline
                                  lif @sdetweil
                                  When the {module}.js file has lines which state something like
                                  'units: “imperial”, // metric uses m and km/h, imperial uses ft and mph,
                                  I assume that it can be changed in the {module}.js file.
                                  Some modules list all the options in the example that goes into the config.js file, MMM-Flights (and many others) don’t.
                                  select pasted text
                                  hit button </>
                                  OK, sorry.
                                  • L Offline
                                    lif @karsten13
                                    Sorry, still the same after (I think) installing the latest version
                                      karsten13 @lif
                                      @lif
                                      was talking about showMap: "ifTraffic", and this works on my side, tested it again
                                      • L Offline
                                        lif @karsten13
                                        @lif
                                        Yes
                                          sdetweil @lif
                                          no.
                                          in config.js
                                          the design is config js is used to override the values set in the modulename.js defaults section
                                          lacking documentation is a different probem.
                                          if you find properties in the defaults section you can override them in config.js
                                            @lif I have a module that presents a form for config customization, built on the fly based on the modules you have installed now
                                            it uses the values from defaults
                                            https://github.com/sdetweil/MMM-Config
                                            in places where there could be choices, the author can augment the definition to make it more usable and understandable.
                                            not every module works some need help.
                                            if the module is old or the author chooses not to provide an improved definition, I can ship one created by a user, with my module to make the user experience better.
                                            • 2 / 3
