    Title of two modules in one line
    10 Posts 3 Posters 1.9k Views 3 Watching
    • wishmaster270W Offline
      wishmaster270 Module Developer @codac
      @codac Hi, i think the problem is caused of the CSS settings of MMM-DWD-WarnWeather.
      I already forked the module and tried to change some things. Currently i do not have time to make a proper pull request to get the changes merged to the original module but i will do this in the future.
      If you want to give it a try you can use my fork and following settings in your custom.css:
      .MMM-DWD-WarnWeather .wrapper {
        display: flex;
        flex-direction: column;
        align-items: flex-start;
        width: 320px;
        gap: 5px;
      .MMM-DWD-WarnWeather .warning {
        width: 100%;
        display: flex;
        flex-direction: row;
        gap: 10px;
        margin-bottom: 0px;
      .MMM-DWD-WarnWeather .status {
        margin-top: 0px;
      .MMM-DWD-WarnWeather .description {
        padding-left: 0px;
        margin-left: 0px;
      .MMM-DWD-WarnWeather .small-icon{
        float: unset;
        zoom: unset;
        -moz-transform: unset;
        -moz-transform-origin: unset;
        width: 46px;
        height: 46px;
        position: relative;
        codac @wishmaster270
        @wishmaster270 said in Title of two modules in one line:
        display: flex;
        width: 320px;
        gap: 5px;
        width: 100%;
        display: flex;
        gap: 10px;
        margin-bottom: 0px;
        margin-top: 0px;
        padding-left: 0px;
        margin-left: 0px;
        float: unset;
        zoom: unset;
        width: 46px;
        height: 46px;
        position: relative;
        Hi Tom, this totally worked out and fixed the issue.
        Do you have one more hint about shifting the text/icon more to the right?
        wishmaster270W 1 Reply Last reply Reply Quote 1
          @codac Hi and perfect.
          You can try replacing
          with
          align-items: flex-end;
            @wishmaster270 I did change it the way you suggested, but it wont change anything unfortunately.
              @codac Hi,
              i setup a quick dev environment to test the possibilities. You are right. Please keep the align-items option set to flex-start.
              There are different ways to move the warnings to the right. Depending what you want it to be you can either set:
              1: Reduce the module width
                width: 280px;
              Which will look like
              Screenshot 1
              2: Only the description to the right
                width: 100%;
                text-align: right;
              Screenshot 2
              3: Or you can move the warnings totally to the right
                justify-content:flex-end;
              Which looks like
              Screenshot 3
                @wishmaster270 I prefer the third version. I’ve tried a couple of combinations but none of them led to the requested result.
                What am I missing?
                From my understanding I would suggest this CSS code (which doesnt work this way):
                  display: flex;
                  width: 320px;
                  gap: 5px;
                  margin-top: 0px;
                  padding-left: 0px;
                  margin-left: 0px;
                  float: unset;
                  zoom: unset;
                  width: 46px;
                  height: 46px;
                  position: relative;
                  @codac
                  sorry for my unprecise description. I meant adding the the justify-content: flex-end; additionally. The whole CSS settings need to look like the following:
                    display: flex;
                    width: 320px;
                    gap: 5px;
                    width: 100%;
                    display: flex;
                    gap: 10px;
                    margin-bottom: 0px;
                    width: 100%;
                    text-align: right;
                    margin-top: 0px;
                    padding-left: 0px;
                    margin-left: 0px;
                    float: unset;
                    zoom: unset;
                    width: 46px;
                    height: 46px;
                    position: relative;
