    PSA: DarkSky shuts down Jan 1st. expect broken weather
    14 Posts 7 Posters 12.5k Views 7 Watching
    • FlatPepsiF Offline
      FlatPepsi
      So DarkSky, and its weather API will be shutting down on 1/1/2023. Expect a large number of weather modules to break and stop updating.
      There are a number of alternative weather modules out here. I have one, lots of folks have been hard at work updating others. Please be ready to direct folks coming to the forums with broken modules issues to the right answer.
      See also: https://www.theverge.com/2022/12/30/23532275/dark-sky-app-stop-working-january-1st-alternatives
      • S sdetweil pinned this topic on
        sdetweil @FlatPepsi
        @FlatPepsi I pinned your post to the top of troubleshooting… thanks
        FlatPepsiF 1 Reply Last reply Reply Quote 0
          FlatPepsi @sdetweil
          Just learned that apps using DarkSky end on 1/1/23, but the API is actually on until March 31, 2023
          https://blog.darksky.net/
          So I’m about 3 months early…
          S B 2 Replies Last reply Reply Quote 1
            sdetweil @FlatPepsi
            @FlatPepsi still good info
            • 0 Offline
              01ZerosOnes01
              Well just to let you know I have 2 magicmirrors using MMM-DarkSkyRadar and both are now showing nothing. It is 11:45 pm CST new years eve.
              • 0 Offline
                01ZerosOnes01
                Does anyone know of another module that displays radar?
                TIA
                mattkabM 1 Reply Last reply Reply Quote 0
                • mattkabM Offline
                  mattkab @01ZerosOnes01
                  @01ZerosOnes01 It doesn’t look as nice as the screenshot on the MMM-DarkSkyRadar github, but I’ve been using MMM-RAIN-MAP, and it’s been working well.
                  Current screenshot:
                  0 1 Reply Last reply Reply Quote 1
                  • 0 Offline
                    01ZerosOnes01 @mattkab
                    @mattkab Thanks for the suggestion. I’ll give it a try.
                      bhepler Module Developer @FlatPepsi
                      @FlatPepsi - To be fair, DarkSky has been pushing that date back every so often. I think originally it was going to terminate on 1 December 2022.
                      • wishmaster270W Offline
                        wishmaster270 Module Developer @bhepler
                        Found an article that there is a developer who is providing a replacement api for darksky which is called Pirate Weather.
                        If i read correctly it should be a plugin-in replacement for Darksky and only the URLs in the modules need to be changed as the same data structures are used.
                        As i do not use any Darksky modules i did not test it but i found it interesting and it might be worth looking at it.
                        karsten13K FlatPepsiF 2 Replies Last reply Reply Quote 0
                        • karsten13K Offline
                          karsten13 @wishmaster270
                          @wishmaster270 said in PSA: DarkSky shuts down Jan 1st. expect broken weather:
                          can you open an issue on github for this?
                          The darksky api is already removed on develop but it should be discussed if we use this replacement instead.
                            wishmaster270 Module Developer @karsten13
                            @karsten13
                            and done: Issue
                              FlatPepsi @wishmaster270
                              Also worth noting that OpenWeatherMap has an API that is really close in format. They have a guide on migrating:
                              https://openweathermap.org/darksky-openweather-3
                                karsten13 @FlatPepsi
                                @FlatPepsi
                                openweathermap is already a provider of the default weather module.
                                Pirate Weather will come as replacement for Dark Sky with next mm release.
