    PSA: DarkSky shuts down Jan 1st. expect broken weather
    14 Posts 7 Posters 7.2k Views 7 Watching
    • 0 Offline
      01ZerosOnes01
      Well just to let you know I have 2 magicmirrors using MMM-DarkSkyRadar and both are now showing nothing. It is 11:45 pm CST new years eve.
      • 0 Offline
        01ZerosOnes01
        Does anyone know of another module that displays radar?
        TIA
        mattkabM 1 Reply Last reply Reply Quote 0
        • mattkabM Offline
          mattkab @01ZerosOnes01
          @01ZerosOnes01 It doesn’t look as nice as the screenshot on the MMM-DarkSkyRadar github, but I’ve been using MMM-RAIN-MAP, and it’s been working well.
          Current screenshot:
          0 1 Reply Last reply Reply Quote 1
          • 0 Offline
            01ZerosOnes01 @mattkab
            @mattkab Thanks for the suggestion. I’ll give it a try.
            • bheplerB Offline
              bhepler Module Developer @FlatPepsi
              @FlatPepsi - To be fair, DarkSky has been pushing that date back every so often. I think originally it was going to terminate on 1 December 2022.
              • wishmaster270W Offline
                wishmaster270 Module Developer @bhepler
                Found an article that there is a developer who is providing a replacement api for darksky which is called Pirate Weather.
                If i read correctly it should be a plugin-in replacement for Darksky and only the URLs in the modules need to be changed as the same data structures are used.
                As i do not use any Darksky modules i did not test it but i found it interesting and it might be worth looking at it.
                karsten13K FlatPepsiF 2 Replies Last reply Reply Quote 0
                • karsten13K Offline
                  karsten13 @wishmaster270
                  @wishmaster270 said in PSA: DarkSky shuts down Jan 1st. expect broken weather:
                  can you open an issue on github for this?
                  The darksky api is already removed on develop but it should be discussed if we use this replacement instead.
                    wishmaster270 Module Developer @karsten13
                    @karsten13
                    and done: Issue
                    • FlatPepsiF Offline
                      FlatPepsi @wishmaster270
                      Also worth noting that OpenWeatherMap has an API that is really close in format. They have a guide on migrating:
                      https://openweathermap.org/darksky-openweather-3
                        karsten13 @FlatPepsi
                        @FlatPepsi
                        openweathermap is already a provider of the default weather module.
                        Pirate Weather will come as replacement for Dark Sky with next mm release.
