    electron-rebuild problems with MagicMirror 2.22.0
    53 Posts 5 Posters 28.5k Views 6 Watching
    • karsten13K
      karsten13 @sdetweil
      @sdetweil said in electron-rebuild problems with MagicMirror 2.22.0:
      his was x86_64…
      he wrote “I use a fully patched Raspberry OS Bullseye 32Bit.” so I think this is arm32v7
      but I built on buster and bullseye on pi4 also … MM version 2.22
      but his didn’t execute the postinstall script
      strange
        sdetweil @karsten13
        @karsten13 yeh, his says
        kristjan@debian:~/Infomonitor/MagicMirror/modules/MMM-Buttons$ uname -r
        5.10.0-20-amd64
        so not 32 bit.
        @KristjanESPERANTO
        can you go to the MMM-Buttons folder and do
        ./postinstall
        • karsten13K
          karsten13 @sdetweil
          his was x86_64… (edit: i see his is amd64, oops, tldr;l!)…
          I will see if I can get a vm on my new amd64 chromebook… had it til I powered off…
          so not 32 bit.
          he wrote 32 bit
          x86_64=amd64: No Raspian OS
          arm32v7=arm=aarch32: Raspian OS 32-bit
          arm64v8=arm64=aarch64: Raspian OS 64-bit
            sdetweil @karsten13
            @karsten13 yeh, haven’t tested on arm64 on pi for a while.
            but its still an npm problem if it doesn’t run the postinstall
            flashing image now
            worked fine
            pi@raspberrypi:~/MagicMirror/modules $ uname -a
            Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
            pi@raspberrypi:~/MagicMirror/modules $ node -v
            v16.19.0
            pi@raspberrypi:~/MagicMirror/modules $ npm -v
            8.19.3
            pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/sdetweil/MMM-Buttons.git
            Cloning into 'MMM-Buttons'...
            remote: Enumerating objects: 56, done.
            remote: Counting objects: 100% (4/4), done.
            remote: Compressing objects: 100% (4/4), done.
            remote: Total 56 (delta 0), reused 2 (delta 0), pack-reused 52
            Receiving objects: 100% (56/56), 11.86 KiB | 3.95 MiB/s, done.
            Resolving deltas: 100% (25/25), done.
            pi@raspberrypi:~/MagicMirror/modules $ cd MMM-Buttons/
            pi@raspberrypi:~/MagicMirror/modules/MMM-Buttons $ npm install --omit=dev --no-audit --no-fund
            > Magic-Mirror-Module-Buttons@1.0.0 postinstall
            > ./postinstall
            /home/pi/MagicMirror/modules/MMM-Buttons
            ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
            ⠸ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
            ⠧ Building module: epoll, Completed: 0  COPY Release/epoll.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build'
            ✔ Rebuild Complete
            added 6 packages in 2m
            wishmaster270W 1 Reply Last reply
            • wishmaster270W
              wishmaster270 Module Developer @sdetweil
              @sdetweil Sorry, had no Internet connection for a few hours.
              The version of my GPIO module in the development branch uses the postinstall script and there is where the error happens.
              It is a Raspberry 4 in my case with 32bit Bullseye.
              It is
              npm 9.2.0
              node 16.19.0
              arch armv7l
              in my case.
                sdetweil @wishmaster270
                @wishmaster270 hm, I modified your module and it works fine… will check your branch
                I just copy the postinstall script and change package.json
                intel x86-64 ok
                base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ git checkout development
                branch 'development' set up to track 'origin/development'.
                Switched to a new branch 'development'
                (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ls
                examples  LICENSE  MMM-GPIO-Notifications.js  node_helper.js  package.json  postinstall  README.md
                (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ nano package.json
                (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ npm install --omit=dev --no-audit --no-fund
                > MMM-GPIO-Notifications@0.0.6 postinstall
                > ./postinstall
                /home/sam/MagicMirror/modules/MMM-GPIO-Notifications
                ⠧ Building module: epoll, Completed: 0make: Entering directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ⠇ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                make: Leaving directory '/home/sam/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ✔ Rebuild Complete
                added 6 packages in 10s
                pi 64 aarch64 ok
                (base) sam@sams:~/MagicMirror/modules/MMM-GPIO-Notifications$ ssh pi@192.168.2.44
                pi@192.168.2.44's password:
                The programs included with the Debian GNU/Linux system are free software;
                the exact distribution terms for each program are described in the
                individual files in /usr/share/doc/*/copyright.
                Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                permitted by applicable law.
                Last login: Fri Jan  6 14:10:59 2023 from 192.168.2.106
                pi@raspberrypi:~ $ pm2 stop all
                [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                [PM2] [MagicMirror](0) ✓
                │ id │ name               │ mode     │ ↺    │ status    │ cpu      │ memory   │
                │ 0  │ MagicMirror        │ fork     │ 0    │ stopped   │ 0%       │ 0b       │
                pi@raspberrypi:~ $ cd MagicMirror/modules
                pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                Cloning into 'MMM-GPIO-Notifications'...
                remote: Enumerating objects: 159, done.
                remote: Counting objects: 100% (42/42), done.
                remote: Compressing objects: 100% (34/34), done.
                remote: Total 159 (delta 17), reused 22 (delta 8), pack-reused 117
                Receiving objects: 100% (159/159), 744.45 KiB | 3.48 MiB/s, done.
                Resolving deltas: 100% (74/74), done.
                pi@raspberrypi:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                Branch 'development' set up to track remote branch 'development' from 'origin'.
                pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                > ./postinstall
                ⠋ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ⠹ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                ⠦ Building module: epoll, Completed: 0  COPY Release/epoll.node
                make: Leaving directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ✔ Rebuild Complete
                added 6 packages in 15s
                pi@raspberrypi:~/MagicMirror/modules/MMM-GPIO-Notifications $ exit
                pi 32bit buster ok
                pi@raspberrypi42:~ $ cd MagicMirror/modules/
                pi@raspberrypi42:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                Receiving objects: 100% (159/159), 744.45 KiB | 73.00 KiB/s, done.
                pi@raspberrypi42:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout develoment
                error: pathspec 'develoment' did not match any file(s) known to git
                pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                > ./postinstall
                ⠙ Building module: epoll, Completed: 0make: Entering directory '/home/pi/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ⠙ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                ⠼ Building module: epoll, Completed: 0  COPY Release/epoll.node
                ✔ Rebuild Complete
                added 6 packages in 14s
                pi@raspberrypi42:~/MagicMirror/modules/MMM-GPIO-Notifications $ lsb_release -a
                No LSB modules are available.
                Distributor ID:	Raspbian
                Description:	Raspbian GNU/Linux 10 (buster)
                Release:	10
                Codename:	buster
                32 bit bullseye, ok
                fribble@raspberrypi4:~ $ cd MagicMirror/modules/
                fribble@raspberrypi4:~/MagicMirror/modules $ lsb_release -a
                Description:	Raspbian GNU/Linux 11 (bullseye)
                Release:	11
                Codename:	bullseye
                fribble@raspberrypi4:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications.git
                Receiving objects: 100% (159/159), 744.45 KiB | 3.26 MiB/s, done.
                fribble@raspberrypi4:~/MagicMirror/modules $ cd MMM-GPIO-Notifications/
                fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ git checkout development
                fribble@raspberrypi4:~/MagicMirror/modules/MMM-GPIO-Notifications $ npm install --omit=dev --no-audit --no-fund
                > ./postinstall
                ⠸ Building module: epoll, Completed: 0make: Entering directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ⠴ Building module: epoll, Completed: 0  SOLINK_MODULE(target) Release/obj.target/epoll.node
                ⠏ Building module: epoll, Completed: 0  COPY Release/epoll.node
                make: Leaving directory '/home/fribble/MagicMirror/modules/MMM-GPIO-Notifications/node_modules/epoll/build'
                ✔ Rebuild Complete
                added 6 packages in 21s
                  @wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
                  kApiSystemPointerSize == kApiInt64Size,
                  this looks like a compile header mismatch
                  make sure u delete the electron-rebuild if its in your module folder
                  AND the one in MagicMirror/node_modules in case there is a downlevel version,
                  OR change the postinstall to always install it. vs checking if present and running the installed version…
                  • wishmaster270W
                    Today i started a new approach and removed the “node_modules” folder of MagicMirror before the update to make sure no other electron-rebuild packages are installed.
                    As i do have a second electron app running on my mirror (TeleFrame) is stopped this application and removed the “/home/pi/.electron-gyp” folder to make sure everything is clean before the update.
                    I then did the update with your script and the “npm install” step of my MMM-GPIO-Notifications module fails.
                    I cloned your “MMM-Buttons” module and tried to install only this module but i get the same compile error. I enabled the DEBUG flag. Maybe you see something i do not see but it looks like the correct electron-rebuild version is used:
                    pi@mirror-eg:~/MagicMirror/modules/MMM-Buttons $ npm install
                    > ./postinstall
                    ⠋ Searching dependency tree  electron-rebuild rebuilding with args: [Arguments] {
                      '0': {
                        buildPath: '/home/pi/MagicMirror/modules/MMM-Buttons',
                        electronVersion: '22.0.0',
                        arch: 'arm',
                        extraModules: [],
                        onlyModules: null,
                        force: undefined,
                        headerURL: undefined,
                        types: [ 'prod', 'optional' ],
                        mode: undefined,
                        debug: undefined,
                        prebuildTagPrefix: 'v',
                        forceABI: undefined,
                        useElectronClang: false,
                        disablePreGypCopy: false,
                        projectRootPath: '/home/pi/MagicMirror/modules/MMM-Buttons'
                    } +0ms
                      electron-rebuild rebuilding with args: /home/pi/MagicMirror/modules/MMM-Buttons 22.0.0 arm Set(0) {} false https://www.electronjs.org/headers [ 'prod', 'optional' ] false +8ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/onoff +0ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll +4ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/lodash.debounce +1ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/bindings +2ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/nan +1ms
                      electron-rebuild exploring /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/file-uri-to-path +1ms
                      electron-rebuild identified prod deps: Set(0) {
                      onoff: true,
                      epoll: true,
                      'lodash.debounce': true,
                      bindings: true,
                      nan: true,
                      'file-uri-to-path': true
                    } +1ms
                      electron-rebuild scanning: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules +5ms
                      electron-rebuild rebuilding epoll with args [
                      'node',
                      'node-gyp',
                      'rebuild',
                      '--runtime=electron',
                      '--target=22.0.0',
                      '--arch=arm',
                      '--dist-url=https://www.electronjs.org/headers',
                      '--build-from-source',
                      '--verbose'
                    ] +0ms
                    gyp verb command rebuild []
                    gyp verb command clean []
                    gyp verb clean removing "build" directory
                    ⠙ Building module: epoll, Completed: 0gyp verb command configure []
                    gyp verb download using dist-url https://www.electronjs.org/headers
                    gyp verb find Python Python is not set from command line or npm configuration
                    gyp verb find Python Python is not set from environment variable PYTHON
                    gyp verb find Python checking if "python3" can be used
                    gyp verb find Python - executing "python3" to get executable path
                    ⠹ Building module: epoll, Completed: 0gyp verb find Python - executable path is "/usr/bin/python3"
                    gyp verb find Python - executing "/usr/bin/python3" to get version
                    ⠸ Building module: epoll, Completed: 0gyp verb find Python - version is "3.7.3"
                    gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
                    gyp verb get node dir compiling against --target node version: 22.0.0
                    gyp verb command install [ '22.0.0' ]
                    gyp verb install input version string "22.0.0"
                    gyp verb install installing version: 22.0.0
                    gyp verb install --ensure was passed, so won't reinstall if already installed
                    ⠼ Building module: epoll, Completed: 0gyp verb install version is already installed, need to check "installVersion"
                    gyp verb got "installVersion" 9
                    gyp verb needs "installVersion" 9
                    gyp verb install version is good
                    gyp verb get node dir target node version installed: 22.0.0
                    gyp verb build dir attempting to create "build" dir: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build
                    gyp verb build dir "build" dir needed to be created? Yes
                    gyp verb python symlink creating symlink to "/usr/bin/python3" at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins/python3"
                    gyp verb build/config.gypi creating config file
                    gyp verb build/config.gypi writing out config file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi
                    gyp verb config.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/config.gypi
                    gyp verb common.gypi checking for gypi file: /home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/common.gypi
                    gyp verb gyp gyp format was not specified; forcing "make"
                    gyp info spawn /usr/bin/python3
                    gyp info spawn args [
                    gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/gyp/gyp_main.py',
                    gyp info spawn args   'binding.gyp',
                    gyp info spawn args   '-f',
                    gyp info spawn args   'make',
                    gyp info spawn args   '-I',
                    gyp info spawn args   '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/config.gypi',
                    gyp info spawn args   '/home/pi/MagicMirror/node_modules/node-gyp/addon.gypi',
                    gyp info spawn args   '/home/pi/.electron-gyp/22.0.0/include/node/common.gypi',
                    gyp info spawn args   '-Dlibrary=shared_library',
                    gyp info spawn args   '-Dvisibility=default',
                    gyp info spawn args   '-Dnode_root_dir=/home/pi/.electron-gyp/22.0.0',
                    gyp info spawn args   '-Dnode_gyp_dir=/home/pi/MagicMirror/node_modules/node-gyp',
                    gyp info spawn args   '-Dnode_lib_file=/home/pi/.electron-gyp/22.0.0/<(target_arch)/node.lib',
                    gyp info spawn args   '-Dmodule_root_dir=/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll',
                    gyp info spawn args   '-Dnode_engine=v8',
                    gyp info spawn args   '--depth=.',
                    gyp info spawn args   '--no-parallel',
                    gyp info spawn args   '--generator-output',
                    gyp info spawn args   'build',
                    gyp info spawn args   '-Goutput_dir=.'
                    gyp info spawn args ]
                    ⠙ Building module: epoll, Completed: 0gyp verb command build []
                    gyp verb build type Release
                    gyp verb architecture armv7l
                    gyp verb node dev dir /home/pi/.electron-gyp/22.0.0
                    gyp verb `which` succeeded for `make` /usr/bin/make
                    gyp verb bin symlinks adding symlinks (such as Python), at "/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build/node_gyp_bins", to PATH
                    gyp info spawn make
                    gyp info spawn args [ 'V=1', 'BUILDTYPE=Release', '-C', 'build' ]
                    make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird betreten
                      g++ -o Release/obj.target/epoll/src/epoll.o ../src/epoll.cc '-DNODE_GYP_MODULE_NAME=epoll' '-DUSING_UV_SHARED=1' '-DUSING_V8_SHARED=1' '-DV8_DEPRECATION_WARNINGS=1' '-DV8_DEPRECATION_WARNINGS' '-DV8_IMMINENT_DEPRECATION_WARNINGS' '-D_GLIBCXX_USE_CXX11_ABI=1' '-DELECTRON_ENSURE_CONFIG_GYPI' '-D_LARGEFILE_SOURCE' '-D_FILE_OFFSET_BITS=64' '-DUSING_ELECTRON_CONFIG_GYPI' '-DV8_COMPRESS_POINTERS' '-DV8_COMPRESS_POINTERS_IN_SHARED_CAGE' '-DV8_ENABLE_SANDBOX' '-DV8_31BIT_SMIS_ON_64BIT_ARCH' '-D__STDC_FORMAT_MACROS' '-DOPENSSL_NO_PINSHARED' '-DOPENSSL_THREADS' '-DOPENSSL_NO_ASM' '-DBUILDING_NODE_EXTENSION' -I/home/pi/.electron-gyp/22.0.0/include/node -I/home/pi/.electron-gyp/22.0.0/src -I/home/pi/.electron-gyp/22.0.0/deps/openssl/config -I/home/pi/.electron-gyp/22.0.0/deps/openssl/openssl/include -I/home/pi/.electron-gyp/22.0.0/deps/uv/include -I/home/pi/.electron-gyp/22.0.0/deps/zlib -I/home/pi/.electron-gyp/22.0.0/deps/v8/include -I../../nan  -fPIC -pthread -Wall -Wextra -Wno-unused-parameter -Wno-deprecated-declarations -Wno-cast-function-type -O3 -fno-omit-frame-pointer -fno-rtti -fno-exceptions -std=gnu++17 -MMD -MF ./Release/.deps/Release/obj.target/epoll/src/epoll.o.d.raw  -std=c++17 -c
                    ⠴ Building module: epoll, Completed: 0In file included from /home/pi/.electron-gyp/22.0.0/include/node/v8-local-handle.h:12,
                                     from /home/pi/.electron-gyp/22.0.0/include/node/v8-array-buffer.h:12,
                                     from /home/pi/.electron-gyp/22.0.0/include/node/v8.h:24,
                                     from ../src/epoll.cc:11:
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:62: warning: left shift count >= width of type [-Wshift-count-overflow]
                     constexpr size_t kPtrComprCageReservationSize = size_t{1} << 32;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:124:59: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:60: warning: left shift count >= width of type [-Wshift-count-overflow]
                     constexpr size_t kPtrComprCageBaseAlignment = size_t{1} << 32;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:125:57: error: right operand of shift expression ‘(1 << 32)’ is >= than the precision of the left operand [-fpermissive]
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:128:27: error: static assertion failed: Pointer compression can be enabled only for 64-bit architectures
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:186:38: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘1099511627776’ to ‘0’ [-Woverflow]
                     constexpr size_t kSandboxSize = 1ULL << kSandboxSizeLog2;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:204:50: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738368’ to ‘0’ [-Woverflow]
                     constexpr size_t kSandboxGuardRegionSize = 32ULL * GB;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:220:56: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘8589934592’ to ‘0’ [-Woverflow]
                     constexpr size_t kSandboxMinimumReservationSize = 8ULL * GB;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:230:60: warning: conversion from ‘long long unsigned int’ to ‘size_t’ {aka ‘unsigned int’} changes value from ‘34359738367’ to ‘4294967295’ [-Woverflow]
                     constexpr size_t kMaxSafeBufferSizeForSandbox = 32ULL * GB - 1;
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:231:44: error: static assertion failed: The maximum allowed buffer size must not be larger than the sandbox's guard regions
                     static_assert(kMaxSafeBufferSizeForSandbox <= kSandboxGuardRegionSize,
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:236:48: error: static assertion failed: The maximum size of a BoundedSize must be synchronized with the kMaxSafeBufferSizeForSandbox
                     static_assert(1ULL << (64 - kBoundedSizeShift) ==
                                       kMaxSafeBufferSizeForSandbox + 1,
                    /home/pi/.electron-gyp/22.0.0/include/node/v8-internal.h:260:56: error: static assertion failed: kExternalPointerTableReservationSize and kExternalPointerIndexShift don't match
                     static_assert((1 << (32 - kExternalPointerIndexShift)) == kMaxExternalPointers,
                    ⠴ Building module: epoll, Completed: 0make: *** [epoll.target.mk:129: Release/obj.target/epoll/src/epoll.o] Fehler 1
                    make: Verzeichnis „/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll/build“ wird verlassen
                    ✖ Rebuild Failed
                    An unhandled error occurred inside electron-rebuild
                    node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
                    For more information, rerun with the DEBUG environment variable set to "electron-rebuild".
                    Error: `make` failed with exit code: 2
                    Error: node-gyp failed to rebuild '/home/pi/MagicMirror/modules/MMM-Buttons/node_modules/epoll'.
                        at NodeGyp.rebuildModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-type/node-gyp.js:120:19)
                        at processTicksAndRejections (node:internal/process/task_queues:96:5)
                        at async ModuleRebuilder.rebuildNodeGypModule (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:98:9)
                        at async ModuleRebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/module-rebuilder.js:128:14)
                        at async Rebuilder.rebuildModuleAt (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:149:13)
                        at async Rebuilder.rebuild (/home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/rebuild.js:112:17)
                        at async /home/pi/MagicMirror/node_modules/electron-rebuild/lib/src/cli.js:158:9
                    npm ERR! code 255
                    npm ERR! path /home/pi/MagicMirror/modules/MMM-Buttons
                    npm ERR! command failed
                    npm ERR! command sh -c ./postinstall
                    npm ERR!     /home/pi/.npm/_logs/2023-01-07T11_55_30_111Z-debug-0.log
                    Edit: I will try to re-setup my mirror today to make sure no old things are messing up the installation but it will take a moment.
                    • wishmaster270W
                      wishmaster270 Module Developer @wishmaster270
                      New installation, new luck!
                      Everything works well now and i think if found the reason for the problems.
                      As i wrote earlier i am running TeleFrame on the same Pi with MagicMirror. This time i installed TeleFrame manually instead of with the installer as i saw that the automatic installer of Teleframe installs a global version of Electron and adds architecture settings to the “.profile” file of the user.
                        @wishmaster270 cool. thx for feedback
                        don’t know Teleframe.
                        KristjanESPERANTOK 1 Reply Last reply
                        • KristjanESPERANTOK
                          The problems on my machine are obviously of a different nature. I’ll investigate that later.
                          For the original issue it should be worth using @electron/rebuild instead of magicmirror-rebuild or electron-rebuild. I tested it in a virtual machine and it works great. Here is my solution which is less invasive:
                          https://github.com/Tom-Hirschberger/MMM-GPIO-Notifications/pull/7
                          What do you think?
                          S wishmaster270W 2 Replies Last reply
                            sdetweil @KristjanESPERANTO
                            @KristjanESPERANTO my postinstall script uses electron-rebuild
                            his development branch
                              Yes, but @electron/rebuild is the successor of electron-rebuild. And the “trick” in the postinstall script seems not necessary at all.
                              • wishmaster270W
                                wishmaster270 Module Developer @KristjanESPERANTO
                                @KristjanESPERANTO
                                Hi and thank you for contributing. I confirm that changing to magicmirror-rebuild did not make things batter but worse. I now followed the suggestion of @sdetweil and implemented his postinstall script. Things are working perfectly now and should work in future releases, too.
                                I merged the new changes to the master a few minutes ago and released version 0.0.7 of MMM-GPIO-Notifications. I will implement this approach in my other modules, too.
                                  KristjanESPERANTO Module Developer @wishmaster270
                                  @wishmaster270 OK, you’re welcome.
                                  Since the thread is also for other developers: I recommend considering my approach, as I consider the other approach (installing to a higher-level directory) to be more error-prone. But it’s a creative workaround.
                                  • wishmaster270W
                                    @KristjanESPERANTO
                                    The problem with installing it in the module directory is that we need to compile the library against the electron version installed in the MagicMirror project.
                                    If electron-rebuild is installed in the module directory it might fail to detect the right electron version (which was the cause of the rebuild problems in the past).
                                    So the right way is to install electron-rebuild in the same project as electron and call it from there.
                                    It might be worth to think about adding it as a dependency in the main project.
                                    KristjanESPERANTOK karsten13K 2 Replies Last reply
                                      @wishmaster270 Okay, thanks for the explanation! I haven’t been able to read that anywhere in such clear words and I haven’t dealt with the past problems. Then I withdraw my recommendation because I lack the overview.
                                        @KristjanESPERANTO ah I see
                                        haven’t heard of @electron/rebuild
                                        • karsten13K
                                          karsten13 @wishmaster270
                                          installing module stuff in the node_modules folder of mm is a hack and will not work out of the box with a docker setup because this folder is only in the container (you have to map it on the host to get changes there persistent)
                                          in this case may the best solution
                                          S 2 Replies Last reply
                                            sdetweil @karsten13
                                            @karsten13 yes, that’s what I think we come to but doesn’t help any existing broken modules
                                            • 2 / 3
