Solved electron-rebuild problems with MagicMirror 2.22.0
I have a docker installation running for development here on my notebook.
Everytime a module needs “npm install” I exec to the container and run the command in the container cause there will be called the correct npm and node version in the container and not the ones I currently use on my notebook.
In this case the directory structure is the same as with a locally installed MagicMirror and the postinstall script will work as excepted. -
@wishmaster270 said in electron-rebuild problems with MagicMirror 2.22.0:
yes, will work, but all the changes in the
node_modules
folder of mm are gone with the next restart of the container … -
@karsten13
In case of electron-rebuild this is no problem as it is only required during compile but not at runtime. -
o.k., but where are the compile results stored?
@karsten13
They are stored in thenode_modules
folder of the module which should be persistentEdit: Do not misunderstand me. In my opinion the best way to solve the electron-rebuild problems of a lot of modules would be to put “@electron/rebuild” as a dependency to “package.json” of MagicMirror.
@karsten13
folder of the module which should be persistentthats good, so the construction with installing
electron-rebuild
in mm folder has no side effects and works also in a docker setup. -
I don’t have a final opinion on that yet, but if so, we should put it under
optionalDependencies
aselectron
You are right. I think
would be a great solution. Module developers could then add a hint to runnpm ci
in the MagicMirror directory to their installations instructions.As the container it self is untouched it should be no problem. It only causes @electron/rebuild to be installed the next time the script is called.
@KristjanESPERANTO but if u look at electron/rebuild after install u call electron-rebuild
still has to be installed in the base node_modules folder…
older unmaintained modules are broken either way. why I had to fork MMM-Buttons.
@wishmaster270 optional is there so that IF electron is NOT installed, the install does not fail (needed on pi0w at least)
have nothing to do w cimy script ONLY installs prod, no dev. as 99.5% of users are users not mm developers. has nothing to do w module developers
