    Help with MMM-EmbedURL
    28 Posts 3 Posters 11.5k Views 3 Watching
    • T
      TK421_VT @TK421_VT
      YOUR CONFIGURATION
      /* MagicMirror² Config Sample
       * By Michael Teeuw https://michaelteeuw.nl
       * MIT Licensed.
       * see https://docs.magicmirror.builders/configuration/introduction.html
       * and https://docs.magicmirror.builders/modules/configuration.html
      let config = {
        electronOptions: {
          webPreferences: {
            webviewTag: true,
      	address: "192.168.1.40", 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["192.168.1.40", "127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
      	language: "en",
      	locale: "en-US",
      	timeFormat: 12,
      	units: "english",
      			module: "clock",
      			timeFormat: "12",
      			displaySeconds: "false",
      			showPeriod: "true"
          module: "MMM-Bring",
          position: "bottom_bar",
             email: 'xxxxxx@xxxx.com',
             password: 'xxxxxx',
             updateInterval: 1, // in Minutes
             listName: "Costco", // optional
             showListName: false,
             activeItemColor: "#EE524F",
             latestItemColor: "#4FABA2",
             showLatestItems: false,
             maxItems: 0,
             maxLatestItems: 0,
             locale: "en-US",
             useKeyboard: false,
             customTitle: "Costco List", // optional
             listDropdown: false
      		module: "MMM-CalendarWeek",
      		position: "middle_center",	// This can be any of the regions. Best results in bottom region.
      	colored: true,
      	coloredSymbolOnly: false,
      	maximumNumberOfDays: 21,
      	maximumDaysPerLine: 7,
      	wrapEvents: true,
      	showEndDate: true,
      			url: 'https://calendar.google.com/calendar/ical/xxxxxxgmail.com/public/basic.ics',
      			symbol: 'calendar',
      			auth: {
      			    user: 'xxxxxxxx',
      			    pass: 'xxxxxxxx',
      			    method: 'basic'
        module: "MMM-EmbedURL",
        header: "Current Weather",
          embedElementType: "webview",
          basicElementType: "div",
          updateInterval: 120,
          attributes: [
              "frameborder=0",
            embed: [
              "https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash"
      • T
        TK421_VT @wishmaster270
        @wishmaster270 No worries on the late reply, the holidays are a busy time!
        wishmaster270W 1 Reply Last reply
          sdetweil @TK421_VT
          @TK421_VT note that I edited your post to add code wrapper around your config.js content
          you placed it around the words 'your configuration ', which was supposed to mean the content of the config.js on you MagicMirror installation
          • wishmaster270W
            wishmaster270 Module Developer @TK421_VT
            @TK421_VT
            I took your whole config, copied to my mirror and only changed the ip address to my needs. Everything is working fine here. It takes a second to fetch the information of the weather but it is displayed as it should.
            The only thing i think is left that can cause the problems is that not electron is used to display the mirror.
            Edit:
            Did not see that it is working now. Please read my other post about sizing instead
            • wishmaster270W
              @TK421_VT
              Hi and sorry,
              i did not see that it is working now. Yes you can adjust the size (as suggested in the documentation) by adding a few lines to your custom.css file:
              .MMM-EmbedURL .embed .embeded {
                  width: 800px;
                  height: 400px;
              T 1 Reply Last reply
              • T
                @wishmaster270 Ok, this sounds great, but one more dumb question, where is the custom.css file?
                Please forgive all my dumb questions and bad posts; this forum is new to me, and I am not a coder by trade, I am more of a hardware guy.
                • T
                  TK421_VT
                  I see this in the Readme, but It doesn’t mean much to me:
                    sdetweil @TK421_VT
                    @TK421_VT custom.css is an optional file u can create in the css folder.
                    if you use my install script I create it for you
