    Help with MMM-EmbedURL
    28 Posts 3 Posters 11.5k Views 3 Watching
    • T
      TK421_VT @wishmaster270
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @TK421_VT
        @TK421_VT Sorry for the late response. I will need to set up a identical environment to debug the problem. I will try to figure things out in the next days.
        wishmaster270W T 2 Replies Last reply
        • wishmaster270W
          wishmaster270 Module Developer @wishmaster270
          @TK421_VT
          I setup a new environment today and tested your configuration. There are a few issues with it i did not see cause you did not use the code signs to paste your configuration in the forum.
          Please use the
          YOUR CONFIGURATION
          which results in
          YOUR CONFIGURATION
          next time.
          First thing is that you set the basicElementType and embedElementType in the wrong level. They need to be set as child object of config.
          The second problem is that you use a wrong time of double quotes. It looks like your editor uses a wired type of encoding.
          is not the same as
          With the following config everything works well:
          /* Magic Mirror Config Sample
           * By Michael Teeuw https://michaelteeuw.nl
           * MIT Licensed.
           * see https://docs.magicmirror.builders/getting-started/configuration.html#general
           * and https://docs.magicmirror.builders/modules/configuration.html
          let config = {
          	electronOptions: {
          		webPreferences: {
          			webSecurity: false,
          			webviewTag: true,
          		fullscreen: true,
          		alwaysOnTop: false
          	// ignoreXOriginHeader: true,
          	// ignoreContentSecurityPolicy: true,
          	address: "192.168.1.1", // Address to listen on, can be:
          	port: 8080,
          	basePath: "/", // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
          	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "10.18.8.0/24"], // Set [] to allow all IP addresses
          	useHttps: false, // Support HTTPS or not, default "false" will use HTTP
          	httpsPrivateKey: "", // HTTPS private key path, only require when useHttps is true
          	httpsCertificate: "", // HTTPS Certificate path, only require when useHttps is true
          	language: "de",
          	locale: "de-DE",
          	timeFormat: 24,
          	units: "metric",
          			module: "clock",
          			position: "top_center",
          			module: "MMM-EmbedURL",
          			header: "Current Weather",
          				embedElementType: "webview",
          				basicElementType: "div",
          				updateInterval: 120,
          				attributes: [
          					"frameborder=0",
          				embed: [
          					“https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash”
          			module: "MMM-Touch",
          			position: "bottom_center",
          				debug: true,
          				useDisplay: false,
          				defaultMode: "default",
          				gestureCommands: {
          					default: {
          						TAP_1: (commander) => {
          							commander.sendNotification("USER_PRESENCE", true);
          						PRESS_1: (commander) => {
          							commander.sendNotification("SCREEN_TOGGLE", { forced: true });
          						SWIPE_UP_1: (commander) => {
          							commander.sendNotification("SCREEN_ON", { forced: true });
          						SWIPE_DOWN_1: (commander) => {
          							commander.sendNotification("SCREEN_OFF", { forced: true });
          						SWIPE_LEFT_1: (commander) => {
          							commander.sendNotification("PROFILE_INCREMENT_HORIZONTAL", null);
          						SWIPE_RIGHT_1: (commander) => {
          							commander.sendNotification("PROFILE_DECREMENT_HORIZONTAL", null);
          if (typeof module !== "undefined") {
          	module.exports = config;
          S T 2 Replies Last reply
            sdetweil @wishmaster270
            @wishmaster270 the bad " is because of the no code wrapper
            see this
            "something"
            vs this
            “something”
            copy/paste of the second will cause bad config message
            @TK421_VT to use the code wrapper
            paste your text in the message editor, select it all
            the hit the button above the edit that looks like </>
            note the code wrapper tag MUST start and end on a blank line…
            • T
              @wishmaster270 Moving basicElementType & embedElementTpe into the correct location seemed to work.
              Is there any way to make the window Wider or Longer? Or is it this size because of the region it is set in?
              T wishmaster270W 2 Replies Last reply
              • T
                TK421_VT @TK421_VT
                YOUR CONFIGURATION
                /* MagicMirror² Config Sample
                 * MIT Licensed.
                 * see https://docs.magicmirror.builders/configuration/introduction.html
                let config = {
                  electronOptions: {
                    webPreferences: {
                      webviewTag: true,
                	address: "192.168.1.40", 	// Address to listen on, can be:
                	port: 8080,
                	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                	ipWhitelist: ["192.168.1.40", "127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                	language: "en",
                	locale: "en-US",
                	timeFormat: 12,
                	units: "english",
                			module: "clock",
                			timeFormat: "12",
                			displaySeconds: "false",
                			showPeriod: "true"
                    module: "MMM-Bring",
                    position: "bottom_bar",
                       email: 'xxxxxx@xxxx.com',
                       password: 'xxxxxx',
                       updateInterval: 1, // in Minutes
                       listName: "Costco", // optional
                       showListName: false,
                       activeItemColor: "#EE524F",
                       latestItemColor: "#4FABA2",
                       showLatestItems: false,
                       maxItems: 0,
                       maxLatestItems: 0,
                       locale: "en-US",
                       useKeyboard: false,
                       customTitle: "Costco List", // optional
                       listDropdown: false
                		module: "MMM-CalendarWeek",
                		position: "middle_center",	// This can be any of the regions. Best results in bottom region.
                	colored: true,
                	coloredSymbolOnly: false,
                	maximumNumberOfDays: 21,
                	maximumDaysPerLine: 7,
                	wrapEvents: true,
                	showEndDate: true,
                			url: 'https://calendar.google.com/calendar/ical/xxxxxxgmail.com/public/basic.ics',
                			symbol: 'calendar',
                			auth: {
                			    user: 'xxxxxxxx',
                			    pass: 'xxxxxxxx',
                			    method: 'basic'
                    attributes: [
                        "frameborder=0",
                      embed: [
                        "https://www.wunderground.com/dashboard/pws/KVTCAMBR4?cm_ven=localwx_pwsdash"
                • T
                  @wishmaster270 No worries on the late reply, the holidays are a busy time!
                    sdetweil @TK421_VT
                    @TK421_VT note that I edited your post to add code wrapper around your config.js content
                    you placed it around the words 'your configuration ', which was supposed to mean the content of the config.js on you MagicMirror installation
                    • wishmaster270W
                      @TK421_VT
                      I took your whole config, copied to my mirror and only changed the ip address to my needs. Everything is working fine here. It takes a second to fetch the information of the weather but it is displayed as it should.
                      The only thing i think is left that can cause the problems is that not electron is used to display the mirror.
                      Edit:
                      Did not see that it is working now. Please read my other post about sizing instead
                      • wishmaster270W
                        @TK421_VT
                        Hi and sorry,
                        i did not see that it is working now. Yes you can adjust the size (as suggested in the documentation) by adding a few lines to your custom.css file:
                        .MMM-EmbedURL .embed .embeded {
                            width: 800px;
                            height: 400px;
                        T 1 Reply Last reply
                        • T
                          @wishmaster270 Ok, this sounds great, but one more dumb question, where is the custom.css file?
                          Please forgive all my dumb questions and bad posts; this forum is new to me, and I am not a coder by trade, I am more of a hardware guy.
                          • T
                            TK421_VT
                            I see this in the Readme, but It doesn’t mean much to me:
                              sdetweil @TK421_VT
                              @TK421_VT custom.css is an optional file u can create in the css folder.
                              if you use my install script I create it for you
