    Installing on Xubuntu 18.04.6 LTS
    13 Posts 3 Posters 2.6k Views 3 Watching
      rukytech
      hi there,
      please forgive me if im posting in the wrong place, im new to linux and life. My first install was on a rpi3 which went without a hitch. I want to use an old acer 5672wlmi 32 bit laptop with Xubuntu 18.04.6 LTS to run magic mirror.
      i chose xubuntu because of its low requirements and that version is the last to support 32 bit machines.
      After install, it spat out some errrors about node.js and npm. From what i gathered, ithe versions that shipped with OS were too low and so after some googling i managed to manually install newest versions of the 2 from unofficial builds. i keep getting this error,(see attached) please help me i ve spent so much time and effort on this, i really want it to work! Any help or direction appreciated.
      BTW im open to using other lightweight 32bit linux if it will run MM.
        sdetweil @pato
        @pato too old, sorry
          sdetweil @rukytech
          @rukytech use my install script.
          see
            rukytech @sdetweil
            @sdetweil many thanks for the quick reply, i shall try it out today and report with results
              rukytech @sdetweil
              @sdetweil i installed raspberrypiOS on the laptop(making it a rpi basically) and i tried the manual installation but again i had errors. I assume i keep getting the node and npm versions wrong. I popped in ur script and worked like a charm. Thank you again. Now, everytime i close the magic mirror app, it automatically restarts, i assume its by dessign from the last part of the script. Is there a way to disbale it temporarily until im done setting it up?
              Also does this script work with any linux distro? Like puppy?
              S 2 Replies Last reply Reply Quote 1
                sdetweil @rukytech
                @rukytech you said yes to pm2, SO… its JOB is to start and keep mm running…
                SO,
                alt-spacebar,n to minimize MM
                ctrl-alt-t to open a terminal window
                pm2 status to see what being managed
                pm2 stop MagicMirror
                or
                pm2 stop the number of the line (0 probably)
                or
                pm2 stop all
                pm2 --help for all the other thing pm2 can do
                  sdetweil @rukytech
                  @rukytech said in Installing on Xubuntu 18.04.6 LTS:
                  should work with any linux distro… tested with a bunch
                  haven’t tried puppy
                    rukytech @sdetweil
                    @sdetweil sweet! thanks
                      sdetweil @rukytech
                      @rukytech try it out, let me know… if troubles, email me the ~/install.log same userid at gmail
                        pato
                        Hello everyone,
                        I’m Patrick from France. I’m also trying to install MagicMirror on an old 32 bit computer. Like Rukytech, I’ve installed Raspberry pi OS and tried the sdetweil script installation. Unfortunately, I get a 404 error apparently, when installing node.js.
                        I get the following message:
                        curl: (22) The requested URL returned error: 404
                        Error: download preflight failed for ‘20.9.0’ (https://nodejs.org/dist/v20.9.0
                        /node-v20.9.0- Linux-x86. tar. xz)
                        And indeed, it seems that the file node-v20.9.0- Linux-x86. tar. xz no longer exists.
                        Thanks in advance if anyone has an idea. I hope it’s not a problem to have resurrected this old topic.
                          sdetweil @pato
