    Installing on Xubuntu 18.04.6 LTS
    13 Posts 3 Posters 3.4k Views 3 Watching
      sdetweil @rukytech
      @rukytech use my install script.
      see
      R 2 Replies Last reply
        rukytech @sdetweil
        @sdetweil many thanks for the quick reply, i shall try it out today and report with results
          rukytech @sdetweil
          @sdetweil i installed raspberrypiOS on the laptop(making it a rpi basically) and i tried the manual installation but again i had errors. I assume i keep getting the node and npm versions wrong. I popped in ur script and worked like a charm. Thank you again. Now, everytime i close the magic mirror app, it automatically restarts, i assume its by dessign from the last part of the script. Is there a way to disbale it temporarily until im done setting it up?
          Also does this script work with any linux distro? Like puppy?
          S 2 Replies Last reply
            sdetweil @rukytech
            @rukytech you said yes to pm2, SO… its JOB is to start and keep mm running…
            SO,
            alt-spacebar,n to minimize MM
            ctrl-alt-t to open a terminal window
            pm2 status to see what being managed
            pm2 stop MagicMirror
            or
            pm2 stop the number of the line (0 probably)
            or
            pm2 stop all
            pm2 --help for all the other thing pm2 can do
              sdetweil @rukytech
              @rukytech said in Installing on Xubuntu 18.04.6 LTS:
              should work with any linux distro… tested with a bunch
              haven’t tried puppy
              R 1 Reply Last reply
                rukytech @sdetweil
                @sdetweil sweet! thanks
                  sdetweil @rukytech
                  @rukytech try it out, let me know… if troubles, email me the ~/install.log same userid at gmail
                    pato
                    Hello everyone,
                    I’m Patrick from France. I’m also trying to install MagicMirror on an old 32 bit computer. Like Rukytech, I’ve installed Raspberry pi OS and tried the sdetweil script installation. Unfortunately, I get a 404 error apparently, when installing node.js.
                    I get the following message:
                    curl: (22) The requested URL returned error: 404
                    Error: download preflight failed for ‘20.9.0’ (https://nodejs.org/dist/v20.9.0
                    /node-v20.9.0- Linux-x86. tar. xz)
                    And indeed, it seems that the file node-v20.9.0- Linux-x86. tar. xz no longer exists.
                    Thanks in advance if anyone has an idea. I hope it’s not a problem to have resurrected this old topic.
                      sdetweil @pato
                      @pato too old, sorry
                      P 1 Reply Last reply
                        pato @sdetweil
                        @sdetweil Too bad, I’m 2 years late . Thanks anyway for the quick reply. I’ll try to find a solution.
                          sdetweil @pato
                          @pato i have s chromebook w ubuntu16.04
                          and too small disk to upgrade
                          it was my traveling dev machine
                            sdetweil @pato
                            @pato yeh,. last time x86 nodejs was distributed was version 8, in 2019
                            node-v8.17.0-linux-x86.tar.gz                      17-Dec-2019 06:30            18294008
                            node-v8.17.0-linux-x86.tar.xz
