    Installing on Xubuntu 18.04.6 LTS
    13 Posts 3 Posters 3.4k Views 3 Watching
      rukytech @sdetweil
      @sdetweil many thanks for the quick reply, i shall try it out today and report with results
        rukytech @sdetweil
        @sdetweil i installed raspberrypiOS on the laptop(making it a rpi basically) and i tried the manual installation but again i had errors. I assume i keep getting the node and npm versions wrong. I popped in ur script and worked like a charm. Thank you again. Now, everytime i close the magic mirror app, it automatically restarts, i assume its by dessign from the last part of the script. Is there a way to disbale it temporarily until im done setting it up?
        Also does this script work with any linux distro? Like puppy?
        S 2 Replies Last reply
          sdetweil @rukytech
          @rukytech you said yes to pm2, SO… its JOB is to start and keep mm running…
          SO,
          alt-spacebar,n to minimize MM
          ctrl-alt-t to open a terminal window
          pm2 status to see what being managed
          pm2 stop MagicMirror
          or
          pm2 stop the number of the line (0 probably)
          or
          pm2 stop all
          pm2 --help for all the other thing pm2 can do
            sdetweil @rukytech
            @rukytech said in Installing on Xubuntu 18.04.6 LTS:
            should work with any linux distro… tested with a bunch
            haven’t tried puppy
            R 1 Reply Last reply
              rukytech @sdetweil
              @sdetweil sweet! thanks
                sdetweil @rukytech
                @rukytech try it out, let me know… if troubles, email me the ~/install.log same userid at gmail
                  pato
                  Hello everyone,
                  I’m Patrick from France. I’m also trying to install MagicMirror on an old 32 bit computer. Like Rukytech, I’ve installed Raspberry pi OS and tried the sdetweil script installation. Unfortunately, I get a 404 error apparently, when installing node.js.
                  I get the following message:
                  curl: (22) The requested URL returned error: 404
                  Error: download preflight failed for ‘20.9.0’ (https://nodejs.org/dist/v20.9.0
                  /node-v20.9.0- Linux-x86. tar. xz)
                  And indeed, it seems that the file node-v20.9.0- Linux-x86. tar. xz no longer exists.
                  Thanks in advance if anyone has an idea. I hope it’s not a problem to have resurrected this old topic.
                    sdetweil @pato
                    @pato too old, sorry
                    P 1 Reply Last reply
                      pato @sdetweil
                      @sdetweil Too bad, I’m 2 years late . Thanks anyway for the quick reply. I’ll try to find a solution.
                        sdetweil @pato
                        @pato i have s chromebook w ubuntu16.04
                        and too small disk to upgrade
                        it was my traveling dev machine
                          sdetweil @pato
                          @pato yeh,. last time x86 nodejs was distributed was version 8, in 2019
                          node-v8.17.0-linux-x86.tar.gz                      17-Dec-2019 06:30            18294008
                          node-v8.17.0-linux-x86.tar.xz
