    MMM-SynologySurveillance
    34 Posts 5 Posters 25.9k Views 5 Watching
      digied
      What version of the module are you using? You can find the version in the package.json file.
      It is:
      “name”: “MMM-SynologySurveillance”,
      “version”: “0.1.1”,
      “description”: “”,
      “main”: “MMM-SynologySurveillance.js”,
      “dependencies”: {
      “syno”: “^1.0.0”
      What version of MagicMirror are you using?
      “name”: “magicmirror”,
      “version”: “2.22.0”,
      How did you install the module?
      Just following instructions:
      cd ~/MagicMirror/modules
      git clone https://github.com/Tom-Hirschberger/MMM-SynologySurveillance.git
      cd MMM-SynologySurveillance
      npm install.  this one I had to do using sudo npm install
      What version of Synology DSM are you using?
      7.1.1-42962 update 2
      It is a DS218
      What version of Synology Surveillance are you using?
      9.0.2-10061
      This is the log for npm start run:
      pi@raspberrypi:~/MagicMirror/config $ npm start run
      magicmirror@2.22.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js run
      [15.01.2023 10:41.20.823] [LOG] Starting MagicMirror: v2.22.0
      [15.01.2023 10:41.20.831] [LOG] Loading config …
      [15.01.2023 10:41.20.838] [LOG] Loading module helpers …
      [15.01.2023 10:41.20.840] [LOG] No helper found for module: alert.
      [15.01.2023 10:41.20.859] [LOG] Initializing new module helper …
      [15.01.2023 10:41.20.860] [LOG] Module helper loaded: updatenotification
      [15.01.2023 10:41.20.862] [LOG] No helper found for module: clock.
      [15.01.2023 10:41.20.863] [LOG] No helper found for module: MMM-connection-status.
      [15.01.2023 10:41.21.281] [LOG] Initializing new module helper …
      [15.01.2023 10:41.21.283] [LOG] Module helper loaded: MMM-SynologySurveillance
      [15.01.2023 10:41.21.535] [LOG] Initializing new module helper …
      [15.01.2023 10:41.21.537] [LOG] Module helper loaded: calendar
      [15.01.2023 10:41.21.618] [LOG] Initializing new module helper …
      [15.01.2023 10:41.21.620] [LOG] Module helper loaded: MMM-Formula1
      [15.01.2023 10:41.21.622] [LOG] No helper found for module: weather.
      [15.01.2023 10:41.21.623] [LOG] No helper found for module: MMM-Buienradar.
      [15.01.2023 10:41.21.948] [LOG] Initializing new module helper …
      [15.01.2023 10:41.21.949] [LOG] Module helper loaded: MMM-SolarEdgeLite
      [15.01.2023 10:41.22.301] [LOG] Initializing new module helper …
      [15.01.2023 10:41.22.302] [LOG] Module helper loaded: MMM-SystemStats
      [15.01.2023 10:41.22.326] [LOG] Initializing new module helper …
      [15.01.2023 10:41.22.326] [LOG] Module helper loaded: newsfeed
      [15.01.2023 10:41.22.327] [LOG] All module helpers loaded.
      [15.01.2023 10:41.22.435] [LOG] Starting server on port 8080 …
      [15.01.2023 10:41.22.677] [LOG] Server started …
      [15.01.2023 10:41.22.679] [LOG] Connecting socket for: updatenotification
      [15.01.2023 10:41.22.679] [LOG] Starting module helper: updatenotification
      [15.01.2023 10:41.22.680] [LOG] Connecting socket for: MMM-SynologySurveillance
      [15.01.2023 10:41.22.682] [LOG] Connecting socket for: calendar
      [15.01.2023 10:41.22.683] [LOG] Starting node helper for: calendar
      [15.01.2023 10:41.22.684] [LOG] Connecting socket for: MMM-Formula1
      [15.01.2023 10:41.22.685] [LOG] Starting module: MMM-Formula1
      [15.01.2023 10:41.22.685] [LOG] Connecting socket for: MMM-SolarEdgeLite
      [15.01.2023 10:41.22.686] [LOG] Starting module helper: MMM-SolarEdgeLite
      [15.01.2023 10:41.22.686] [LOG] Connecting socket for: MMM-SystemStats
      [15.01.2023 10:41.22.687] [LOG] Connecting socket for: newsfeed
      [15.01.2023 10:41.22.688] [LOG] Starting node helper for: newsfeed
      [15.01.2023 10:41.22.689] [LOG] Sockets connected & modules started …
      [15.01.2023 10:41.22.714] [LOG] Launching application.
      MESA-LOADER: failed to retrieve device information
      MESA-LOADER: failed to open kms_swrast: /usr/lib/dri/kms_swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
      failed to load driver: kms_swrast
      MESA-LOADER: failed to open swrast: /usr/lib/dri/swrast_dri.so: kan gedeeld objectbestand niet openen: Toegang geweigerd (search paths /usr/lib/aarch64-linux-gnu/dri:$${ORIGIN}/dri:/usr/lib/dri)
      failed to load swrast driver
      [15.01.2023 10:41.26.401] [LOG] MMM-SynologySurveillance: Received notification CONFIG
      [15.01.2023 10:41.26.402] [LOG] MMM-SynologySurveillance: Received notification INIT_DS
      [15.01.2023 10:41.26.405] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
      [15.01.2023 10:41.26.410] [ERROR] Whoops! There was an uncaught exception…
      [15.01.2023 10:41.26.418] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
      at Class.getStreamUrls (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:72:19)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:324:12)
      at Socket. (/home/pi/MagicMirror/js/node_helper.js:108:11)
      at Socket.emit (node:events:513:28)
      at Socket.emitUntyped (/home/pi/MagicMirror/node_modules/socket.io/dist/typed-events.js:69:22)
      at /home/pi/MagicMirror/node_modules/socket.io/dist/socket.js:614:39
      at process.processTicksAndRejections (node:internal/process/task_queues:78:11)
      [15.01.2023 10:41.26.420] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [15.01.2023 10:41.26.421] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [15.01.2023 10:41.26.476] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
      [15.01.2023 10:41.26.544] [LOG] Create new calendarfetcher for url: http://p103-caldav.icloud.com/published/2/Njc3ODUzOTEzNjc3ODUzOQyRiARRL2CkxgtBVQDZXfBmcEh4jRSjf1NpTv-kmUkeab9A4t6LtTrrc3BUTsPoy9oS4yCg4f5Rnt5FlMRu6Oo - Interval: 300000
      [15.01.2023 10:41.26.574] [LOG] Create new calendarfetcher for url: http://p62-caldav.icloud.com/published/2/MzE2ODIwNDE4MzE2ODIwNJD9RGBryCg63_2az9y7tWOTHmUDf_W0Y3YkBa1tdgnP7AW7ihN1TLzhWzBnHSok2S9kxwdK6IkOT1I55L8cvuE - Interval: 300000
      [15.01.2023 10:41.26.579] [LOG] Create new calendarfetcher for url: http://racingnews365.nl/ics/download/calendar-formula-2022.ics?all - Interval: 300000
      [15.01.2023 10:41.26.583] [LOG] Create new calendarfetcher for url: https://wasteapi.ximmio.com/api/CallIcal?cn=Gemeente Almere&x=53d8db94-7945-42fd-9742-9bbc71dbe4c1&ty=null&ua=65222&sd=2021-12-21&ed=2025-01-09&path=https://wasteapi.ximmio.com&ln=nl&nt=1130 - Interval: 300000
      [15.01.2023 10:41.26.743] [LOG] Create new newsfetcher for url: http://feeds.nos.nl/nosnieuws - Interval: 300000
      [15.01.2023 10:41.26.748] [LOG] Create new newsfetcher for url: https://nl.motorsport.com/rss/f1/news/ - Interval: 300000
      [15.01.2023 10:41.26.752] [LOG] MMM-Formula1 received a notification: CONFIG
      [15.01.2023 10:41.26.772] [LOG] MMM-Formula1 is fetching the race schedule for the current season
      [15.01.2023 10:41.26.797] [LOG] MMM-Formula1 is fetching DRIVER standings for the current season
      [15.01.2023 10:41.26.802] [INFO] Checking git for module: MMM-connection-status
      [15.01.2023 10:41.26.855] [INFO] Checking git for module: MMM-SynologySurveillance
      [15.01.2023 10:41.26.918] [INFO] Checking git for module: MMM-Formula1
      [15.01.2023 10:41.27.030] [INFO] Checking git for module: MMM-Buienradar
      [15.01.2023 10:41.27.139] [LOG] MMM-Formula1 is returning DRIVER standings for the current season
      [15.01.2023 10:41.27.154] [INFO] Checking git for module: MMM-SolarEdgeLite
      [15.01.2023 10:41.27.215] [INFO] Newsfeed-Fetcher: reloadInterval set to ttl=6000000 for url https://nl.motorsport.com/rss/f1/news/
      [15.01.2023 10:41.27.289] [INFO] Checking git for module: MMM-SystemStats
      [15.01.2023 10:41.27.556] [INFO] Checking git for module: default
      [15.01.2023 10:41.28.370] [INFO] Calendar-Fetcher: Broadcasting 0 events.
      [15.01.2023 10:41.28.463] [INFO] Newsfeed-Fetcher: Broadcasting 50 items.
      [15.01.2023 10:41.28.820] [INFO] Calendar-Fetcher: Broadcasting 26 events.
      [15.01.2023 10:41.28.947] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
      [15.01.2023 10:41.29.181] [INFO] Calendar-Fetcher: Broadcasting 32 events.
      [15.01.2023 10:41.29.350] [INFO] Calendar-Fetcher: Broadcasting 18 events.
      [15.01.2023 10:41.30.356] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
      [15.01.2023 10:41.30.359] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
      [15.01.2023 10:41.30.362] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
      [15.01.2023 10:41.30.390] [INFO] Calendar-Fetcher: Broadcasting 10 events.
      [512768:0115/104146.877630:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
      [512768:0115/104205.526070:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
      [512768:0115/104223.429194:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
      [15.01.2023 10:42.25.641] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
      [15.01.2023 10:42.25.642] [LOG] MMM-SynologySurveillance: Refreshing the urls!
      [15.01.2023 10:42.25.642] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
      [15.01.2023 10:42.25.644] [ERROR] Whoops! There was an uncaught exception…
      [15.01.2023 10:42.25.645] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
      at Class.socketNotificationReceived (/home/pi/MagicMirror/modules/MMM-SynologySurveillance/node_helper.js:327:12)
      [15.01.2023 10:42.25.645] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [15.01.2023 10:42.25.646] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [15.01.2023 10:43.25.645] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
      [15.01.2023 10:43.25.646] [LOG] MMM-SynologySurveillance: Refreshing the urls!
      [15.01.2023 10:43.25.646] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
      [15.01.2023 10:43.25.650] [ERROR] Whoops! There was an uncaught exception…
      [15.01.2023 10:43.25.652] [ERROR] TypeError: Cannot read properties of undefined (reading ‘listCameras’)
      [15.01.2023 10:43.25.653] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [15.01.2023 10:43.25.653] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @digied
        @digied
        There two things i do not understand…
        • Did you modify your package.json? The original one of the module contains “syno”: “latest” as a dependency. Which will install version 2.2.0 currently. But the part of your package.json contains “syno”: “^1.0.0” which will install the latest 1.x version. I did not use any 1.X version in my module and do not know if the surveillance part did already exist in this old version. Please use the original version of the package.json. No need to make any changes to it.
        • Why did you need to use sudo for npm install? Only files in the module folder get modified by npm install of this module. There is no need to use sudo in a regular installation. Installing things with sudo may break things and it is not sure that the version of npm of the current user is used. Please do not use sudo for npm install. And never install with npm -g global option.
        D 2 Replies Last reply
          digied @wishmaster270
          @wishmaster270 Hi! Strange thing about the version. So I just did this again:
          pi@raspberrypi:~/MagicMirror/modules $ cat MMM-SynologySurveillance/package.json
          “version”: “0.1.1”,
          “description”: “”,
          “dependencies”: {
          “syno”: “^1.0.0”
          “scripts”: {
          “test”: “echo "Error: no test specified" && exit 1”
          “repository”: {
          “type”: “git”,
          “url”: “git@github.com:Tom-Hirschberger/MMM-SynologySurveillance.git”
          “author”: “Thomas Hirschberger”,
          “license”: “MIT”,
          “bugs”: {
          “url”: “https://github.com/Tom-Hirschberger/MMM-SynologySurveillance/issues”
          “homepage”: “https://github.com/Tom-Hirschberger/MMM-SynologySurveillance/#readme”
          pi@raspberrypi:~/MagicMirror/modules $ sudo rm -r MMM-SynologySurveillance/
          pi@raspberrypi:~/MagicMirror/modules $ ls
          default MMM-connection-status MMM-Formula1 MMM-MercedesMe MMM-RTSPStream MMM-SolarEdgeLite MMM-SystemStats
          MMM-Buienradar MMM-F1 MMM-IPCam MMM-OpenWeatherForecast MMM-SolarEdge MMM-SpeedTest MMM-Worldclock
          pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/Tom-Hirschberger/MMM-SynologySurveillance.git
          Cloning into ‘MMM-SynologySurveillance’…
          remote: Enumerating objects: 298, done.
          remote: Counting objects: 100% (103/103), done.
          remote: Compressing objects: 100% (84/84), done.
          remote: Total 298 (delta 38), reused 42 (delta 19), pack-reused 195
          Receiving objects: 100% (298/298), 1.27 MiB | 15.34 MiB/s, done.
          Resolving deltas: 100% (184/184), done.
          default MMM-connection-status MMM-Formula1 MMM-MercedesMe MMM-RTSPStream MMM-SolarEdgeLite MMM-SynologySurveillance MMM-Worldclock
          MMM-Buienradar MMM-F1 MMM-IPCam MMM-OpenWeatherForecast MMM-SolarEdge MMM-SpeedTest MMM-SystemStats
          “version”: “0.1.1”,
          “description”: “”,
          “dependencies”: {
          “syno”: “latest”
          “devDependencies”: {},
          “scripts”: {
          “repository”: {
          “type”: “git”,
          “license”: “MIT”,
          “bugs”: {
          So now I see also the sync: latest.
          Thus I did the npm install again, but it seems I don’t have enough access for it:
          pi@raspberrypi:~/MagicMirror/modules $ cd MMM-SynologySurveillance/
          pi@raspberrypi:~/MagicMirror/modules/MMM-SynologySurveillance $ cat package.json
          “version”: “0.1.1”,
          “description”: “”,
          “dependencies”: {
          “syno”: “latest”
          “scripts”: {
          “repository”: {
          “type”: “git”,
          “license”: “MIT”,
          “bugs”: {
          Still good, so now I run the npm install:
          pi@raspberrypi:~/MagicMirror/modules/MMM-SynologySurveillance $ npm install
          npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
          added 76 packages, and audited 77 packages in 7s
          2 packages are looking for funding
          run npm fund for details
          2 high severity vulnerabilities
          To address all issues (including breaking changes), run:
          npm audit fix --force
          Run npm audit for details.
          Ok, this time no errors… Let me start MM:
          pi@raspberrypi:~/MagicMirror $ npm start run
          [16.01.2023 16:49.50.904] [LOG] Starting MagicMirror: v2.22.0
          [16.01.2023 16:49.50.911] [LOG] Loading config …
          [16.01.2023 16:49.50.922] [LOG] Loading module helpers …
          [16.01.2023 16:49.50.925] [LOG] No helper found for module: alert.
          [16.01.2023 16:49.50.943] [LOG] Initializing new module helper …
          [16.01.2023 16:49.50.944] [LOG] Module helper loaded: updatenotification
          [16.01.2023 16:49.50.946] [LOG] No helper found for module: clock.
          [16.01.2023 16:49.50.947] [LOG] No helper found for module: MMM-connection-status.
          [16.01.2023 16:49.51.366] [LOG] Initializing new module helper …
          [16.01.2023 16:49.51.368] [LOG] Module helper loaded: MMM-SynologySurveillance
          [16.01.2023 16:49.51.618] [LOG] Initializing new module helper …
          [16.01.2023 16:49.51.620] [LOG] Module helper loaded: calendar
          [16.01.2023 16:49.51.691] [LOG] Initializing new module helper …
          [16.01.2023 16:49.51.693] [LOG] Module helper loaded: MMM-Formula1
          [16.01.2023 16:49.51.694] [LOG] No helper found for module: weather.
          [16.01.2023 16:49.51.695] [LOG] No helper found for module: MMM-Buienradar.
          [16.01.2023 16:49.52.016] [LOG] Initializing new module helper …
          [16.01.2023 16:49.52.016] [LOG] Module helper loaded: MMM-SolarEdgeLite
          [16.01.2023 16:49.52.362] [LOG] Initializing new module helper …
          [16.01.2023 16:49.52.363] [LOG] Module helper loaded: MMM-SystemStats
          [16.01.2023 16:49.52.387] [LOG] Initializing new module helper …
          [16.01.2023 16:49.52.387] [LOG] Module helper loaded: newsfeed
          [16.01.2023 16:49.52.388] [LOG] All module helpers loaded.
          [16.01.2023 16:49.52.495] [LOG] Starting server on port 8080 …
          [16.01.2023 16:49.52.734] [LOG] Server started …
          [16.01.2023 16:49.52.736] [LOG] Connecting socket for: updatenotification
          [16.01.2023 16:49.52.737] [LOG] Starting module helper: updatenotification
          [16.01.2023 16:49.52.738] [LOG] Connecting socket for: MMM-SynologySurveillance
          [16.01.2023 16:49.52.739] [LOG] Connecting socket for: calendar
          [16.01.2023 16:49.52.740] [LOG] Starting node helper for: calendar
          [16.01.2023 16:49.52.740] [LOG] Connecting socket for: MMM-Formula1
          [16.01.2023 16:49.52.741] [LOG] Starting module: MMM-Formula1
          [16.01.2023 16:49.52.742] [LOG] Connecting socket for: MMM-SolarEdgeLite
          [16.01.2023 16:49.52.742] [LOG] Starting module helper: MMM-SolarEdgeLite
          [16.01.2023 16:49.52.744] [LOG] Connecting socket for: MMM-SystemStats
          [16.01.2023 16:49.52.744] [LOG] Connecting socket for: newsfeed
          [16.01.2023 16:49.52.745] [LOG] Starting node helper for: newsfeed
          [16.01.2023 16:49.52.746] [LOG] Sockets connected & modules started …
          [16.01.2023 16:49.52.819] [LOG] Launching application.
          [16.01.2023 16:49.56.198] [LOG] MMM-SynologySurveillance: Received notification CONFIG
          [16.01.2023 16:49.56.200] [LOG] MMM-SynologySurveillance: Received notification INIT_DS
          [16.01.2023 16:49.56.202] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
          [50739:0116/164958.846579:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
          [16.01.2023 16:49.59.003] [LOG] Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/nl.dutch%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
          [16.01.2023 16:49.59.045] [LOG] Create new calendarfetcher for url: http://p103-caldav.icloud.com/published/2/Njc3ODUzOTEzNjc3ODUzOQyRiARRL2CkxgtBVQDZXfBmcEh4jRSjf1NpTv-kmUkeab9A4t6LtTrrc3BUTsPoy9oS4yCg4f5Rnt5FlMRu6Oo - Interval: 300000
          [16.01.2023 16:49.59.056] [LOG] Create new calendarfetcher for url: http://p62-caldav.icloud.com/published/2/MzE2ODIwNDE4MzE2ODIwNJD9RGBryCg63_2az9y7tWOTHmUDf_W0Y3YkBa1tdgnP7AW7ihN1TLzhWzBnHSok2S9kxwdK6IkOT1I55L8cvuE - Interval: 300000
          [16.01.2023 16:49.59.065] [LOG] Create new calendarfetcher for url: http://racingnews365.nl/ics/download/calendar-formula-2022.ics?all - Interval: 300000
          [16.01.2023 16:49.59.070] [LOG] Create new calendarfetcher for url: https://wasteapi.ximmio.com/api/CallIcal?cn=Gemeente Almere&x=53d8db94-7945-42fd-9742-9bbc71dbe4c1&ty=null&ua=65222&sd=2021-12-21&ed=2025-01-09&path=https://wasteapi.ximmio.com&ln=nl&nt=1130 - Interval: 300000
          [16.01.2023 16:49.59.285] [LOG] Create new newsfetcher for url: http://feeds.nos.nl/nosnieuws - Interval: 300000
          [16.01.2023 16:49.59.291] [LOG] Create new newsfetcher for url: https://nl.motorsport.com/rss/f1/news/ - Interval: 300000
          [16.01.2023 16:49.59.294] [LOG] MMM-Formula1 received a notification: CONFIG
          [16.01.2023 16:49.59.315] [LOG] MMM-Formula1 is fetching the race schedule for the current season
          [16.01.2023 16:49.59.342] [LOG] MMM-Formula1 is fetching DRIVER standings for the current season
          [16.01.2023 16:49.59.347] [INFO] Checking git for module: MMM-connection-status
          [16.01.2023 16:49.59.390] [INFO] Checking git for module: MMM-SynologySurveillance
          [16.01.2023 16:49.59.467] [INFO] Checking git for module: MMM-Formula1
          [16.01.2023 16:49.59.554] [INFO] Checking git for module: MMM-Buienradar
          [16.01.2023 16:49.59.594] [INFO] Newsfeed-Fetcher: reloadInterval set to ttl=6000000 for url https://nl.motorsport.com/rss/f1/news/
          [16.01.2023 16:49.59.698] [LOG] MMM-Formula1 is returning DRIVER standings for the current season
          [16.01.2023 16:49.59.704] [INFO] Checking git for module: MMM-SolarEdgeLite
          [16.01.2023 16:49.59.781] [INFO] Checking git for module: MMM-SystemStats
          [16.01.2023 16:49.59.923] [INFO] Checking git for module: default
          [16.01.2023 16:49.59.982] [INFO] Newsfeed-Fetcher: Broadcasting 50 items.
          [16.01.2023 16:50.00.666] [INFO] Calendar-Fetcher: Broadcasting 0 events.
          [16.01.2023 16:50.00.713] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
          [16.01.2023 16:50.01.085] [INFO] Calendar-Fetcher: Broadcasting 26 events.
          [16.01.2023 16:50.01.252] [INFO] Calendar-Fetcher: Broadcasting 31 events.
          [16.01.2023 16:50.01.389] [INFO] Newsfeed-Fetcher: Broadcasting 20 items.
          [16.01.2023 16:50.01.750] [INFO] Calendar-Fetcher: Broadcasting 18 events.
          [16.01.2023 16:50.02.554] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
          [16.01.2023 16:50.02.555] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
          [16.01.2023 16:50.02.556] [ERROR] Moment Timezone has no data for GMT+0200. See http://momentjs.com/timezone/docs/#/data-loading/.
          [16.01.2023 16:50.02.569] [INFO] Calendar-Fetcher: Broadcasting 10 events.
          [16.01.2023 16:50.02.884] [LOG] MMM-SynologySurveillance: {
          “dsIdx”: 0,
          “camStreams”: {
          “Generic_ONVIF-001”: “https://datanas//192.168.2.26:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Stream.VideoStreaming&version=1&method=Stream&format=mjpeg&cameraId=2&StmKey=“c0a94e2b77e2887405161edf7a32964b””
          [50702:0116/165002.966141:ERROR:cert_verify_proc_builtin.cc(670)] CertVerifyProcBuiltin for datanas failed:
          ----- Certificate i=0 (CN=synology,O=Synology Inc.,L=Taipel,C=TW) -----
          ERROR: No matching issuer found
          [50739:0116/165036.029773:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
          And this is what the MM is showing:
          Before I got the little cam showing, now it is this square. Any thoughts?
            @wishmaster270 btw, the cam itself is found:
            [16.01.2023 16:55.55.543] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
            [16.01.2023 16:55.55.544] [LOG] MMM-SynologySurveillance: Refreshing the urls!
            [16.01.2023 16:55.55.545] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
            [16.01.2023 16:55.57.908] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
            [16.01.2023 16:55.58.816] [LOG] MMM-SynologySurveillance: {
            “dsIdx”: 0,
            “camStreams”: {
            • wishmaster270W
              @digied That log looks totally different than the other one. What did you change?
                @wishmaster270 I changed nothing. I only fetched the module again as you can see. The latest module is now installed with npm install. So no sudo this time. Now what?
                  @wishmaster270 I see that my previous post wasn’t published. So I repeat it; I deleted the MMM-SynologySurveillance map and did the git clone again. This time I see the line syno:latest. So I did the npm install without the sudo and restarted MM. Now instead of the grey square with the cam, I get a grey square with some little square in it like this:
                  So now what?
                  S wishmaster270W 2 Replies Last reply
                    sdetweil @digied
                    @digied because users with reputation below 2, have all their posts reviewed.
                    it JUST showed up in the review queue, and I approved it…
                    please don’t double post… I DO have other things to do…
                    D 1 Reply Last reply
                    • wishmaster270W
                      @digied Hi,
                      it’s nearly perfect. Now the needed library and the access to the NAS works.
                      The output of your log shows that the fetched URL contains the hostname of your NAS AND the IP.
                      Maybe there is a bug in my replaceHostname function.
                      Your config contains a replaceHostPart set to true.
                      Can you set it to false please.
                      Edit: Now that I see all your posts things are clearer ;-)
                        digied @sdetweil
                        @sdetweil Sorry…
                          @wishmaster270 Great! I did see the certificate error so I changed the https/5001 into http/5000 in the config and now the log shows this:
                          [16.01.2023 20:49.14.962] [LOG] MMM-SynologySurveillance: {
                          “dsIdx”: 0,
                          “camStreams”: {
                          “Generic_ONVIF-001”: “http://datanas//192.168.2.26:5000/webapi/entry.cgi?api=SYNO.SurveillanceStation.Stream.VideoStreaming&version=1&method=Stream&format=mjpeg&cameraId=2&StmKey="6058a182182e0c518d126bbf69e2e350"”
                          [73749:0116/204923.065357:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                          [73749:0116/204930.176714:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 2 times!
                          [73749:0116/204930.183104:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 3 times!
                          [16.01.2023 20:50.05.716] [LOG] MMM-SynologySurveillance: Received notification REFRESH_URLS
                          [16.01.2023 20:50.05.718] [LOG] MMM-SynologySurveillance: Refreshing the urls!
                          [16.01.2023 20:50.05.719] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol http
                          [16.01.2023 20:50.08.721] [LOG] MMM-SynologySurveillance: Found cam Generic_ONVIF-001
                          [16.01.2023 20:50.09.721] [LOG] MMM-SynologySurveillance: {
                          “dsIdx”: 0,
                          “camStreams”: {
                          Now the certificate error is gone, but still no image from the cam.
                            @wishmaster270 Sorry, haven’t seen your change of the replaceHostname before. I now set it to false and now I can see the image, but very small at the moment. SO the stream is working now, I just have to get the image larger now. Thanks for your help!
                            • wishmaster270W
                              @digied Perfect. I will look into the module to check if I can accept self signed certificates and why the host part is not replaced correctly.
                              Edit:
                              You should be able to set the cam with by adding some CSS to the file MagicMirror/css/custom.css:
                              .MMM-SynologySurveillance .cam {
                                  width: 100%;
                                @wishmaster270 said in MMM-SynologySurveillance:
                                  width: 100%;
                                Yes, together with height: 100% as well the image is there. Thanks!
                                Reply Quote 2
                                • wishmaster270W
                                  @digied Just released a new version which fixes the host part replacement
                                    @wishmaster270 Installed the update and all is working fine now. Thanks for your help. :folded_hands_light_skin_tone:
                                    • wishmaster270W
                                      @digied Great to hear that. You are welcome.
                                        @wishmaster270 Suddenly, starting today, I see the grey square with the little cam in it. Didn’t change a thing!
                                        Log:
                                        [21.02.2023 17:25.05.039] [LOG] MMM-SynologySurveillance: Received notification CONFIG
                                        [21.02.2023 17:25.05.040] [LOG] MMM-SynologySurveillance: Received notification INIT_DS
                                        [21.02.2023 17:25.05.042] [LOG] MMM-SynologySurveillance: Updating information of DS with idx: 0 and protocol https
                                        [21.02.2023 17:25.07.730] [LOG] MMM-SynologySurveillance: Problem during fetch of cams of ds with idx: 0
                                        [21.02.2023 17:25.07.730] [LOG] MMM-SynologySurveillance: {
                                        “errno”: -3008,
                                        “code”: “ENOTFOUND”,
                                        “syscall”: “getaddrinfo”,
                                        “hostname”: “datanas”
                                        [21.02.2023 17:25.07.731] [LOG] Unknown error. Sending empty list of streams!
                                        [6591:0221/172507.750557:ERROR:gl_surface_presentation_helper.cc(260)] GetVSyncParametersIfAvailable() failed for 1 times!
                                        Can I do anything?
                                        • wishmaster270W
                                          @digied Hi,
                                          looks like a DNS problem to me. Your Mirror can not resolv the ip of “datanas”.
                                          Did there happen a update of your router maybe?
                                            @wishmaster270 No, the cam has died. Need to buy a new one.
