    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 151.1k Views 25 Watching
      Medo
      Also had the “white screen” problem. I installed a complete new Raspian (with PIXEL), a new MagicMirror - including node.js in version 7.3.0
      As soon as i tried to get the MMM-Pir-Sensor working, it failed (with an white screen). Heres, how i solved my problem.
      At first: Theres no need to downgrade the node (i tried this too, and had no luck)
      I figured out, that my problem was an MMM-PIR-Sensor installation error i did not recognized at the beginning. When i tried “npm install” i got something like this (an error):
      "gyp WARN EACCES user “root” does not have permission to access the dev dir “/root/.node-gyp/5.12.0”
      I figured out, that there are two ways of solving this:
      1. CHOWN the directory the install procedure tries to install
      2. use “npm install --unsafe-perm”
      Im aware that option two is not the “elegant” way, but it solved my problem (and i did not have to change directory permissions).
      I removed all files and git the files again (like described some lines above from banglee) and then just use “npm install --unsafe-perm”
      The “–unsafe-perm” option was the key to my problem…
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        zichao92 @Medo
        Hi @Medo ,
        I have gotten the white screen problem as well and my raspberry pi configuration is similar to yours ( running on PIXEL with the latest nodejs).
        However, upon using option 2 from your solution. I have obtained this error :
        npm ERR! Linux 4.4.38-v7+
        npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install" "--unsafe-perm"
        npm ERR! node v7.3.0
        npm ERR! npm  v3.10.10
        npm ERR! code ELIFECYCLE
        npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: `electron-rebuild -e        ../../node_modules/electron-prebuilt`
        npm ERR! Exit status 255
        npm ERR!
        npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script '        electron-rebuild -e ../../node_modules/electron-prebuilt'.
        npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-P        IR-Sensor package,
        npm ERR! not with npm itself.
        npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
        npm ERR!     npm bugs Magic-Mirror-Module-PIR-Sensor
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls Magic-Mirror-Module-PIR-Sensor
        npm ERR!     /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.log
        Does anyone have solution to this?
          Medo @zichao92
          @zichao92
          First things that come to my mind:
          • maybe a “sudo” is missing? Like sudo npm install --unsafe-perm?
          • are you executing this from the MMM-PIR-Sensor directory ?
          Z C 2 Replies Last reply Reply Quote 0
          • Z Offline
            zichao92 @Medo
            Hi @Medo, Thanks for the reply.
            1.) I tried this method and it gives an output of the following error.
            pi@raspi:~/MagicMirror/modules/MMM-PIR-Sensor $ sudo npm install --unsafe-perm
            npm WARN prefer global npm@3.10.10 should be installed with -g
            > epoll@0.1.20 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
              CXX(target) Release/obj.target/epoll/src/epoll.o
              SOLINK_MODULE(target) Release/obj.target/epoll.node
              COPY Release/epoll.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build'
            > nslog@3.0.0 install /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog
            > node-gyp rebuild
            make: Entering directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog/build'
              CXX(target) Release/obj.target/nslog/src/main.o
              CXX(target) Release/obj.target/nslog/src/nslog_linux.o
              SOLINK_MODULE(target) Release/obj.target/nslog.node
              COPY Release/nslog.node
            make: Leaving directory '/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/nslog/build'
            > Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
            Unable to find electron-prebuilt's version number, either install it or specify an explicit version
            npm ERR!
            npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
            npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
            1. Yea it’s in the file directory ( MagicMirror/modules/MMM-PIR_Sensor )
              Medo @zichao92
              @zichao92
              What i also did, was a complete reinstall of the PIR-Sensor
              I followed the steps, “Banglee” described some lines above:
              ok so lets go step by step:
              cd ~/MagicMirror/modules/
              now we will remove the PIR folder:
              rm -rf MMM-PIR-Sensor
              and from here, we’re going to reinstall the MMM-PIR-Sensor modul:
              git clone https://github.com/paviro/MMM-PIR-Sensor.git
              cd MMM-PIR-Sensor
              run the following cmd here:
              npm install and wait, this can take a few minutes.
              Now you’ll have to add pi to gpio
              sudo useradd -g pi gpio
              and reboot your Raspi:
              sudo reboot
              Sorry, no further ideas so far (maybe you can open a PIR-Sensor troubleshooting thread)?
              • Z Offline
                zichao92 @Medo
                Hi @Medo ,
                I managed to get it working in an ugly way. Doesnt matter, it works. Thanks for your help!
                  jwhittaker
                  I’m having nothing but trouble with this. I’ve tried all the tips on here but still get a white screen.
                  @zichao92 What was the ugly way and how did you manage to get it working please?
                  This is the error I get:
                  > electron js/electron.js
                  >Starting MagicMirror: v2.1.0
                  Loading config ...
                  Loading module helpers ...
                  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Could not locate the bindings file. Tried:
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node
                   → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node
                  App threw an error during load
                      at bindings (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/bindings/bindings.js:88:9)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:116)
                      at Module._compile (module.js:556:32)
                      at Object.Module._extensions..js (module.js:565:10)
                      at Module.load (module.js:473:32)
                      at tryModuleLoad (module.js:432:12)
                      at Function.Module._load (module.js:424:3)
                      at Module.require (module.js:483:17)
                      at require (internal/module.js:20:19)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/onoff/onoff.js:4:11)
                  { Error: Could not locate the bindings file. Tried:
                    tries:
                     [ '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node',
                       '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node' ] }
                  Launching application.```
                  • Z Offline
                    zichao92 @jwhittaker
                    Hi @jwhittaker ,
                    Previously i had a working node_modules that Ive installed through npm install ( Cant rmb how i got it but i managed to create a back up copy of it). Subsequently when I tried to use npm install on a new raspberry pi, it didnt work as intended.
                    What i did was instead of using npm install, I bypassed it by inserting the node_module that i previously salvaged and it worked for some reasons.
                    • T Offline
                      Them Russians
                      @zichao92
                      Random question for you:
                      when i try to do an “npm install” in the “MMM-PIR-Sensor” folder, i get the following error:
                      electron-rebuild -e …/…/node_modules/electron-prebuilt
                      An unhandled error occurred inside electron-rebuild
                      Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                      Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
                      at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
                      at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
                      at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
                      at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
                      at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
                      at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
                      at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                      at Module._compile (module.js:570:32)
                      at Object.Module._extensions…js (module.js:579:10)
                      at Module.load (module.js:487:32)
                      at tryModuleLoad (module.js:446:12)
                      at Function.Module._load (module.js:438:3)
                      at Module.runMain (module.js:604:10)
                      at run (bootstrap_node.js:394:7)
                      at startup (bootstrap_node.js:149:9)
                      npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” "install"
                      npm ERR! node v6.9.2
                      npm ERR! npm v3.10.9
                      npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron-prebuilt
                      npm ERR!
                      npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
                      npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
                      npm ERR! Or if that isn’t available, you can get their info via:
                      npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.logv
                      Any idea what could cause this? I suspect my white screen is because the install failed.
                      I have tried removing the “MMM-PIR-Folder” from my directory and running the clone command from github again to start fresh, but still face this issue.
                        bungee09
                        Similar problem to @Them-Russians when running npm install. Then after starting MM using pm2 I get a white screen. Checking the pm2 error logs I see the following error with a module version mismatch: “Expected 50, got 49”.
                         0|mm       | App threw an error during load
                         0|mm       | Error: Module version mismatch. Expected 50, got 49.
                         0|mm       |     at Error (native)
                         0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                         0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                         0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                         0|mm       |     at Module.load (module.js:473:32)
                         0|mm       |     at tryModuleLoad (module.js:432:12)
                         0|mm       |     at Function.Module._load (module.js:424:3)
                         0|mm       |     at Module.require (module.js:483:17)
                         0|mm       |     at require (internal/module.js:20:19)
                         0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
                        Tried @James solution using npm rebuild but changed the version parameter to 50. Still no luck.
                          npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=50
                        Any help would be much appreciated before I reformat my sd card and start from scratch.
                        • Y Offline
                          yawns Moderator @bungee09
                          @bungee09
                          npm list and look for electron to find the right version. Then rerun the rebuild command with replaced version number
                            bungee09 @yawns
                            @yawns
                            Works a treat. Thanks!
                            • T Offline
                              Them Russians @bungee09
                              @bungee09 Did you get the npm install to work on the “MMM-PIR-Sensor” directory? Or did you just run the npm list to get the version of electron and then run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=50 with the right version?
                              Which directory were you in when you ran the rebuild?
                              Sorry - i’m at work now, so dont have the Pi with me, but have been having issues with this for a week now, so i’m really hoping that this works for me :)
                                bungee09 @Them Russians
                                @Them-Russians - I feel your frustration! I spent a good few hours debugging this after installing and testing my PIR sensor. This is what eventually worked for me:
                                I ran all the commands in the MMM-PIR-Sensor Directory.
                                 cd ~/MagicMirror/modules/MMM-PIR-Sensor
                                 npm list
                                I found the electron version number to be “1.4.3” so updated target to 1.4.3. Also, updated abi to 50 in the following command as this was the expected value from the error message in pm2 logs.
                                 npm rebuild --runtime=electron --target=1.4.3 --disturl=https://atom.io/download/atom-shell --abi=50
                                As soon as the rebuild was complete…
                                 cd
                                 pm2 restart mm
                                … to restart MagicMirror in pm2.
                                I also found this link which described the same fix.
                                Good luck!
                                • T Offline
                                  @bungee09 Did your rebuild work successfuly? I got an error saying that i needed to have the latest versions of node.js and npm installed.
                                  I believe I have node version 6.9.4. Is that what you were using?
                                  After all this, i thought maybe i jacked up something, so i cleared out and reformatted the micro SD card. I reinstalled NOOBS and then got the Magic Mirror. Created the config.js file and ran the mirror without issue. Immediately after that, i cloned the PIR module and tried to run an “npm install” which failed, and so did the rebuild :(
                                    @Them-Russians The rebuild was successful for me using exactly the method I described above. I don’t have my pi with me currently but I only installed node for the first time last week so I definitely don’t have an old version. I can check the exact version number when I get home for you.
                                      @Them-Russians
                                      BTW? Did you install node in the main MagicMirror directory first before installing dependencies in the MMM-PIR-Sensor directory?
                                       npm install
                                      • T Offline
                                        @bungee09 I did not do that install in the Magic Mirror folder. I ran the “curl” command from the github site for the MagicMirror, set up config.js, and then immediately got the PIR module.
                                        Do you think i could run the npm install on the MagicMirror folder now, and try again with the rebuild, or would i have to clear my SD card and reinstall everything and start from scratch?
                                        Y B 2 Replies Last reply Reply Quote 0
                                        • Y Offline
                                          yawns Moderator @Them Russians
                                          @Them-Russians said in MMM-PIR-Sensor - White Screen:
                                          Yes, running npm install now will work and it is required.
                                            @Them-Russians
                                            npm install in the main MM directory. Then npm install in the PIR sensor directory to install dependencies. If it fails then npm rebuild as above using the correct electron version number and abi.
                                            • 4 / 5
