    MMM-PIR-Sensor - White Screen
    90 Posts 24 Posters 147.5k Views 25 Watching
      jwhittaker
      I’m having nothing but trouble with this. I’ve tried all the tips on here but still get a white screen.
      @zichao92 What was the ugly way and how did you manage to get it working please?
      This is the error I get:
      > electron js/electron.js
      >Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      WARNING! Could not load config file. Starting with default configuration. Error found: Error: Could not locate the bindings file. Tried:
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node
       → /home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node
      App threw an error during load
          at bindings (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/bindings/bindings.js:88:9)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:116)
          at Module._compile (module.js:556:32)
          at Object.Module._extensions..js (module.js:565:10)
          at Module.load (module.js:473:32)
          at tryModuleLoad (module.js:432:12)
          at Function.Module._load (module.js:424:3)
          at Module.require (module.js:483:17)
          at require (internal/module.js:20:19)
          at Object.<anonymous> (/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/onoff/onoff.js:4:11)
      { Error: Could not locate the bindings file. Tried:
        tries:
         [ '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node',
           '/home/pi/MagicMirror/modules/default/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node' ] }
      Launching application.```
      Z 1 Reply Last reply Reply Quote 0
      • Z Offline
        zichao92 @jwhittaker
        Hi @jwhittaker ,
        Previously i had a working node_modules that Ive installed through npm install ( Cant rmb how i got it but i managed to create a back up copy of it). Subsequently when I tried to use npm install on a new raspberry pi, it didnt work as intended.
        What i did was instead of using npm install, I bypassed it by inserting the node_module that i previously salvaged and it worked for some reasons.
        • T Offline
          Them Russians
          @zichao92
          Random question for you:
          when i try to do an “npm install” in the “MMM-PIR-Sensor” folder, i get the following error:
          Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall /home/pi/MagicMirror/modules/MMM-PIR-Sensor
          electron-rebuild -e …/…/node_modules/electron-prebuilt
          An unhandled error occurred inside electron-rebuild
          Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
          Error: Unable to find electron-prebuilt’s version number, either install it or specify an explicit version
          at _callee$ (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
          at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:63:40)
          at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:337:22)
          at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/regenerator-runtime/runtime.js:96:21)
          at GeneratorFunctionPrototype.tryCatcher (/home/pi/node_modules/bluebird/js/release/util.js:16:23)
          at PromiseSpawn._promiseFulfilled (/home/pi/node_modules/bluebird/js/release/generators.js:97:49)
          at /home/pi/node_modules/bluebird/js/release/generators.js:201:15
          at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions…js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.runMain (module.js:604:10)
          at run (bootstrap_node.js:394:7)
          at startup (bootstrap_node.js:149:9)
          npm ERR! Linux 4.4.38-v7+
          npm ERR! argv “/usr/bin/nodejs” “/usr/bin/npm” "install"
          npm ERR! node v6.9.2
          npm ERR! npm v3.10.9
          npm ERR! code ELIFECYCLE
          npm ERR! Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall: electron-rebuild -e ../../node_modules/electron-prebuilt
          npm ERR! Exit status 255
          npm ERR!
          npm ERR! Failed at the Magic-Mirror-Module-PIR-Sensor@1.1.0 postinstall script ‘electron-rebuild -e …/…/node_modules/electron-prebuilt’.
          npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-PIR-Sensor package,
          npm ERR! not with npm itself.
          npm ERR! electron-rebuild -e …/…/node_modules/electron-prebuilt
          npm ERR! npm bugs Magic-Mirror-Module-PIR-Sensor
          npm ERR! Or if that isn’t available, you can get their info via:
          npm ERR! npm owner ls Magic-Mirror-Module-PIR-Sensor
          npm ERR! /home/pi/MagicMirror/modules/MMM-PIR-Sensor/npm-debug.logv
          Any idea what could cause this? I suspect my white screen is because the install failed.
          I have tried removing the “MMM-PIR-Folder” from my directory and running the clone command from github again to start fresh, but still face this issue.
            bungee09
            Similar problem to @Them-Russians when running npm install. Then after starting MM using pm2 I get a white screen. Checking the pm2 error logs I see the following error with a module version mismatch: “Expected 50, got 49”.
             0|mm       | App threw an error during load
             0|mm       | Error: Module version mismatch. Expected 50, got 49.
             0|mm       |     at Error (native)
             0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
             0|mm       |     at Object.Module._extensions..node (module.js:583:18)
             0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
             0|mm       |     at Module.load (module.js:473:32)
             0|mm       |     at tryModuleLoad (module.js:432:12)
             0|mm       |     at Function.Module._load (module.js:424:3)
             0|mm       |     at Module.require (module.js:483:17)
             0|mm       |     at require (internal/module.js:20:19)
             0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:76:44)
            Tried @James solution using npm rebuild but changed the version parameter to 50. Still no luck.
              npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=50
            Any help would be much appreciated before I reformat my sd card and start from scratch.
            • yawnsY Offline
              yawns Moderator @bungee09
              @bungee09
              npm list and look for electron to find the right version. Then rerun the rebuild command with replaced version number
                bungee09 @yawns
                @yawns
                Works a treat. Thanks!
                • T Offline
                  Them Russians @bungee09
                  @bungee09 Did you get the npm install to work on the “MMM-PIR-Sensor” directory? Or did you just run the npm list to get the version of electron and then run npm rebuild --runtime=electron --target=1.3.4 --disturl=https://atom.io/download/atom-shell --abi=50 with the right version?
                  Which directory were you in when you ran the rebuild?
                  Sorry - i’m at work now, so dont have the Pi with me, but have been having issues with this for a week now, so i’m really hoping that this works for me :)
                    bungee09 @Them Russians
                    @Them-Russians - I feel your frustration! I spent a good few hours debugging this after installing and testing my PIR sensor. This is what eventually worked for me:
                    I ran all the commands in the MMM-PIR-Sensor Directory.
                     cd ~/MagicMirror/modules/MMM-PIR-Sensor
                     npm list
                    I found the electron version number to be “1.4.3” so updated target to 1.4.3. Also, updated abi to 50 in the following command as this was the expected value from the error message in pm2 logs.
                     npm rebuild --runtime=electron --target=1.4.3 --disturl=https://atom.io/download/atom-shell --abi=50
                    As soon as the rebuild was complete…
                     cd
                     pm2 restart mm
                    … to restart MagicMirror in pm2.
                    I also found this link which described the same fix.
                    Good luck!
                    • T Offline
                      @bungee09 Did your rebuild work successfuly? I got an error saying that i needed to have the latest versions of node.js and npm installed.
                      I believe I have node version 6.9.4. Is that what you were using?
                      After all this, i thought maybe i jacked up something, so i cleared out and reformatted the micro SD card. I reinstalled NOOBS and then got the Magic Mirror. Created the config.js file and ran the mirror without issue. Immediately after that, i cloned the PIR module and tried to run an “npm install” which failed, and so did the rebuild :(
                        @Them-Russians The rebuild was successful for me using exactly the method I described above. I don’t have my pi with me currently but I only installed node for the first time last week so I definitely don’t have an old version. I can check the exact version number when I get home for you.
                          @Them-Russians
                          BTW? Did you install node in the main MagicMirror directory first before installing dependencies in the MMM-PIR-Sensor directory?
                           npm install
                          • T Offline
                            @bungee09 I did not do that install in the Magic Mirror folder. I ran the “curl” command from the github site for the MagicMirror, set up config.js, and then immediately got the PIR module.
                            Do you think i could run the npm install on the MagicMirror folder now, and try again with the rebuild, or would i have to clear my SD card and reinstall everything and start from scratch?
                            yawnsY B 2 Replies Last reply Reply Quote 0
                            • yawnsY Offline
                              yawns Moderator @Them Russians
                              @Them-Russians said in MMM-PIR-Sensor - White Screen:
                              Yes, running npm install now will work and it is required.
                                @Them-Russians
                                npm install in the main MM directory. Then npm install in the PIR sensor directory to install dependencies. If it fails then npm rebuild as above using the correct electron version number and abi.
                                • T Offline
                                  @bungee09 The main MagicMirror directory, or the module directory within MagicMirror?
                                    @Them-Russians In the main directory
                                     cd ~/MagicMirror/
                                     npm install && npm start
                                    • T Offline
                                      @bungee09 @yawns When i ran the “npm install” in the MM directory, i got this error:
                                      npm warn grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed
                                      I googled the error and it looks like it shouldnt be an issue, but when i tried doing an install in the PIR directory (it failed), so did the rebuild with the updated electron version number (mine was 1.5.6).
                                      I got the same error when trying to run the rebuild
                                      Failed at the epoll@0.1.20 install script ‘node-gyp rebuild’
                                      Sorry for all the posts on here, but do you have any thoughts? I update node.js and npm to the most recent versions, so i dont think that what is broken for me :(
                                      When i try to run the mirror, here is the error i get before the white screen:
                                      magicmirror@2.1.0 start /home/pi/MagicMirror
                                      electron js/electron.js “dev”
                                      Loading config …
                                      Loading module helpers …
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node
                                      → /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node
                                      at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:88:9)
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/epoll.js:1:116)
                                      at Object.Module._extensions…js (module.js:565:10)
                                      at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/onoff/onoff.js:4:11)
                                      Whoops! There was an uncaught exception…
                                      tries:
                                      [ ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Debug/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/Release/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Debug/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Debug/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/out/Release/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/Release/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/build/default/epoll.node’,
                                      ‘/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/epoll/compiled/6.5.0/linux/arm/epoll.node’ ] }
                                      • bheplerB Offline
                                        bhepler Module Developer @Them Russians
                                        @Them-Russians
                                        Don’t worry about this one. The log file format is [process] [debug level] [error message]. In this case, “warn” is the level of severity of the message. If it said “err” then it would require your attention.
                                        I suspect your nodejs version is out of date. Try running this command: nodejs -v and then npm -v. It should spit out the version of node and NPM you’re using. Personally, I’m on v7.4.0 and v4.0.5 respectively. If you’re running a few versions behind, you may wish to run these commands from your home folder:
                                        curl -sL https://deb.nodesource.com/setup_7x | sudo -E bash -
                                        sudo apt-get install -y nodejs
                                        sudo npm install -g npm
                                        And yes, you may have to run that last command twice. For some reason, NPM sometimes requires a double-tap to update itself. Thank you, StackExchange.
                                        Run nodejs -v again and verify that your node version is up to snuff.
                                        • T Offline
                                          Them Russians @bhepler
                                          @bhepler
                                          Hey there, thank you for the suggestion. updated both nodejs and npm to 7.4.0 and 4.0.5.
                                          I think removed the MMM-PIR-Sensor folder, grabbed it again from github, and then tried to run npm install on it, and the install failed again.
                                          at tryCatch (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
                                          at Generator.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
                                          at Generator.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
                                          at Generator.tryCatcher (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/util.js:16:23)
                                          at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
                                          at /home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bluebird/js/release/generators.js:201:15
                                          at Object. (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
                                          at Module._compile (module.js:571:32)
                                          at Object.Module._extensions…js (module.js:580:10)
                                          at Module.load (module.js:488:32)
                                          at tryModuleLoad (module.js:447:12)
                                          at Function.Module._load (module.js:439:3)
                                          at Module.runMain (module.js:605:10)
                                          at run (bootstrap_node.js:420:7)
                                          at startup (bootstrap_node.js:139:9)
                                          I tried running the rebuild with my electron version number (1.5.7) but still no luck. Any thoughts on what else I could try? I am drawing a blank here, unfortunately.
                                          O B J 3 Replies Last reply Reply Quote 0
                                          • O Offline
                                            ostfilinchen @Them Russians
                                            @Them-Russians i also thought i have a higher electron-version. but i tried
                                            and it worked for me.
                                            • 4 / 5
