How to set Font in Alarm Clock
In alarm clock module in Title and Message in alarms config I would like to know how to adjust Bigger Font size and Color Font
Thanks for all helps -
if it is the MMM-AlarmClock that you are referring to then in custom.css add
.MMM-AlarmClock .small { font-color: #59F; font-size: 10px; } -
@broberg Thanks for your hint , I will try later
@broberg Sorry your hints is font header of AlarmClock . but I mean When alarmclock is working like photo post
@nobita the alarm clock sends a notification to the alert module which displays this, so you have to change the css for the alert module:
custom.css
.alert span.light { //Here you can change the title } .alert span.thin { //Here you can change the message } -
@strawberry-3.141 not work, thanks
@nobita ok it doesnt render in the module itself try
.ns-box-inner span.light -
@strawberry-3.141 said in How to set Font in Alarm Clock:
.ns-box-inner span.lightI installed the module just to test it, I also noticed the .ns-box-inner
but, something is overwritingfont-size, font-color
I’ve managed to change the color by using.ns-box-inner span.light {color: #00F;}
but changing that tofont-colorwill go back to the original colors. -
@strawberry-3.141 & @broberg I believe that default alert module has inline styles for alerts and notifications that would override any CSS that is set outside of it.
For example take a look at https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L39
if (message.title) { msg += "<span class='thin' style='line-height: 35px; font-size:24px' color='#4A4A4A'>" + message.title + "</span>"; } if (message.message){ if (msg != ""){ msg+= "<br />"; } msg += "<span class='light' style='font-size:28px;line-height: 30px;'>" + message.message + "</span>"; }and https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L81
if (params.title) { message += "<span class='light' style='line-height: 35px; font-size:30px' color='#4A4A4A'>" + params.title + "</span>" } if (params.message) { if (message != ""){ message += "<br />"; } message += "<span class='thin' style='font-size:22px;line-height: 30px;'>" + params.message + "</span>"; }I believe that most elegant way of fixing it is to move those styles into CSS file and have ability to override it in
custom.cssor other file. -
@morozgrafix thats correct, another possibility could be
!important
