How to set Font in Alarm Clock
13 Posts 4 Posters 7.9k Views 3 Watching
  • N Offline
    nobita
    In alarm clock module in Title and Message in alarms config I would like to know how to adjust Bigger Font size and Color Font
    Thanks for all helps
      broberg Project Sponsor
      if it is the MMM-AlarmClock that you are referring to then in custom.css add
      .MMM-AlarmClock .small {
        font-color: #59F;
        font-size: 10px;
      N 2 Replies Last reply Jan 10, 2017, 6:42 AM Reply Quote 0
      • N Offline
        nobita @broberg
        @broberg Thanks for your hint , I will try later
        • N Offline
          nobita @broberg
          @broberg Sorry your hints is font header of AlarmClock . but I mean When alarmclock is working like photo post
          S 1 Reply Last reply Jan 10, 2017, 1:46 PM Reply Quote 0
            strawberry 3.141 Project Sponsor Module Developer @nobita
            @nobita the alarm clock sends a notification to the alert module which displays this, so you have to change the css for the alert module:
            custom.css
            .alert span.light {
              //Here you can change the title
            .alert span.thin {
              //Here you can change the message
            N 1 Reply Last reply Jan 10, 2017, 3:35 PM Reply Quote 1
            • N Offline
              nobita @strawberry 3.141
              @strawberry-3.141 not work, thanks
              S 1 Reply Last reply Jan 10, 2017, 4:18 PM Reply Quote 0
                @nobita ok it doesnt render in the module itself try .ns-box-inner span.light
                B 1 Reply Last reply Jan 10, 2017, 5:02 PM Reply Quote 0
                  broberg Project Sponsor @strawberry 3.141
                  @strawberry-3.141 said in How to set Font in Alarm Clock:
                  I installed the module just to test it, I also noticed the .ns-box-inner
                  but, something is overwriting font-size, font-color
                  I’ve managed to change the color by using .ns-box-inner span.light {color: #00F;}
                  but changing that to font-color will go back to the original colors.
                  M 1 Reply Last reply Jan 10, 2017, 6:28 PM Reply Quote 0
                    morozgrafix Moderator @broberg
                    @strawberry-3.141 & @broberg I believe that default alert module has inline styles for alerts and notifications that would override any CSS that is set outside of it.
                    For example take a look at https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L39
                    		if (message.title) {
                    			msg += "<span class='thin' style='line-height: 35px; font-size:24px' color='#4A4A4A'>" + message.title + "</span>";
                    		if (message.message){
                    			if (msg != ""){
                    				msg+= "<br />";
                    			msg += "<span class='light' style='font-size:28px;line-height: 30px;'>" + message.message + "</span>";
                    and https://github.com/MichMich/MagicMirror/blob/master/modules/default/alert/alert.js#L81
                    		if (params.title) {
                    			message += "<span class='light' style='line-height: 35px; font-size:30px' color='#4A4A4A'>" + params.title + "</span>"
                    		if (params.message) {
                    			if (message != ""){
                    				message += "<br />";
                    			message += "<span class='thin' style='font-size:22px;line-height: 30px;'>" + params.message + "</span>";
                    I believe that most elegant way of fixing it is to move those styles into CSS file and have ability to override it in custom.css or other file.
                    S B 2 Replies Last reply Jan 10, 2017, 6:30 PM Reply Quote 2
                      strawberry 3.141 Project Sponsor Module Developer @morozgrafix
                      @morozgrafix thats correct, another possibility could be !important
