    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 14.2k Views 2 Watching
    • T Offline
      theaddies @sdetweil
      @sdetweil Log file sent.
        sdetweil @theaddies
        @theaddies got the log,let’s try this
        in terminal window, pm2 stop all
        ./run-start.sh
        • T Offline
          theaddies @sdetweil
          @sdetweil I get this.
          Ready to go! Please point your browser to: http://localhost:8080
          Starting chromium browser now, have patience, it takes a minute
          ./run-start.sh: line 147:  1281 Illegal instruction     "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2> /dev/null
          T S 2 Replies Last reply Reply Quote 0
          • T Offline
            theaddies @theaddies
            @theaddies The way I want to run the mirror is that it automatically opens and displays the mirror at boot. I sometimes see things for serveronly and I am not sure if that is what is being configured. I don’t think that is what I want.
              sdetweil @theaddies
              @theaddies ok, a little more info
              type in terminal window
              which chromium
              which chromium-browser
              they should return the file path to one of those
              whichever gives a path copy paste that in the terminal window
              and see if it will start
              I’ve never seen a pi 2, but this all works on pi 0w, also armv6l
                sdetweil @theaddies
                @theaddies because there is no electron browser anymore for armv6l
                I change the setup to serveronly, and then launch chrome browser over the server. you get the same result
                • T Offline
                  theaddies @sdetweil
                  /usr/bin/chromium-browser
                  Illegal Instruction
                    sdetweil @theaddies
                    @theaddies ok, so there is that problem
                    oh, which raspi os image are you using?
                    MUST be the legacy image, 32 bit
                    lsb_release - a
                    will tell us
                    if buster is legacy
                    • T Offline
                      theaddies @sdetweil
                      @sdetweil ```
                      No LSB modules are available.
                      Distributor ID: Raspbian
                      Description: Raspbian GNU/Linux 11 (bullseye)
                      Release: 11
                      Codename: bullseye
                        sdetweil @theaddies
                        @theaddies yep, can’t run bullseye on armv6l
                        must be the legacy image, buster
                        SOOO
                        reflash SD card w buster and run install again
                        chromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
                        need to add another test to install
                        • 1 / 4
