    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 19.4k Views 2 Watching
      sdetweil @theaddies
      @theaddies got the log,let’s try this
      in terminal window, pm2 stop all
      ./run-start.sh
      T 1 Reply Last reply
      • T
        theaddies @sdetweil
        @sdetweil I get this.
        Ready to go! Please point your browser to: http://localhost:8080
        Starting chromium browser now, have patience, it takes a minute
        ./run-start.sh: line 147:  1281 Illegal instruction     "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2> /dev/null
        T S 2 Replies Last reply
        • T
          theaddies @theaddies
          @theaddies The way I want to run the mirror is that it automatically opens and displays the mirror at boot. I sometimes see things for serveronly and I am not sure if that is what is being configured. I don’t think that is what I want.
            sdetweil @theaddies
            @theaddies ok, a little more info
            type in terminal window
            which chromium
            which chromium-browser
            they should return the file path to one of those
            whichever gives a path copy paste that in the terminal window
            and see if it will start
            I’ve never seen a pi 2, but this all works on pi 0w, also armv6l
              sdetweil @theaddies
              @theaddies because there is no electron browser anymore for armv6l
              I change the setup to serveronly, and then launch chrome browser over the server. you get the same result
              • T
                theaddies @sdetweil
                /usr/bin/chromium-browser
                Illegal Instruction
                  sdetweil @theaddies
                  @theaddies ok, so there is that problem
                  oh, which raspi os image are you using?
                  MUST be the legacy image, 32 bit
                  lsb_release - a
                  will tell us
                  if buster is legacy
                  • T
                    theaddies @sdetweil
                    @sdetweil ```
                    No LSB modules are available.
                    Distributor ID: Raspbian
                    Description: Raspbian GNU/Linux 11 (bullseye)
                    Release: 11
                    Codename: bullseye
                      sdetweil @theaddies
                      @theaddies yep, can’t run bullseye on armv6l
                      must be the legacy image, buster
                      SOOO
                      reflash SD card w buster and run install again
                      chromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
                      need to add another test to install
                      • T
                        theaddies @sdetweil
                        @sdetweil Oh wow. Sorry for all the trouble. What a pain.
                          sdetweil @theaddies
                          @theaddies no worries.
                          I’ll update install to end if not buster on armv6l,
                          then u would have known
                          • T
                            theaddies @sdetweil
                            @sdetweil Thanks for all the help. I have several pi4s I just want to use the model 2 because the mirror is a perfect application for the older computer.
                              sdetweil @theaddies
                              @theaddies understood
                              • T
                                theaddies @sdetweil
                                @sdetweil After I run the install script, what do I do. Since the script disables the screen saver and configures the Mirror to autostart I thought I would not need to do anything else. However, pm2 status all reveals that there is nothing running. I run pm2 status all and it is blank.
                                I am not sure if I should follow the process in the link below.
                                https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi
                                When I reboot the mirror I get the magicmirror2 logo showing up and it seems to be booting up but then the screen goes blank and I have nothing. It is almost like it reboots the pi.
                                  sdetweil @theaddies
                                  @theaddies send me the ~/install.log
                                  and do the same chromium
                                  and
                                  ./run-start.sh
                                  tests
                                  lsb_release -a
                                  to confirm buster
                                    sdetweil @theaddies
                                    @theaddies you should not need to do anything. it should be setup to autostart
                                    • T
                                      theaddies @sdetweil
                                      lsb_release -a
                                      Description:    Raspbian GNU/Linux 10 (buster)
                                      Release:        10
                                      Codename:       buster
                                      • T
                                        theaddies @sdetweil
                                        @sdetweil for which chromium or which chromium-browswer I get nothing returned.
                                          sdetweil @theaddies
                                          @theaddies interesting, log says one of them got installed
                                          Unpacking chromium-browser (92.0.4515.98~buster-rpt2)
                                          note u had an extra w in the text on last message
                                          browswer
                                          pm2 setup for autostart having trouble…
                                          you do
                                          pm2 autostart
                                          and it gives you the command to execute to make that happen
                                          then it says it can’t find the systemd init system to update, after it just said that is the one to use…
                                          will have to research and debug
                                          • T
                                            theaddies @sdetweil
                                            pi@raspberrypi:~/MagicMirror $ ./run-start.sh
                                            [07.04.2023 22:00.28.274] [LOG] Starting MagicMirror: v2.23.0
                                            [07.04.2023 22:00.28.488] [LOG] Loading config ...
                                            [07.04.2023 22:00.28.652] [DEBUG] config template file not exists, no envsubst
                                            [07.04.2023 22:00.28.853] [LOG] Loading module helpers ...
                                            [07.04.2023 22:00.28.933] [LOG] No helper found for module: alert.
                                            [07.04.2023 22:00.29.513] [LOG] Initializing new module helper ...
                                            [07.04.2023 22:00.29.565] [LOG] Module helper loaded: updatenotification
                                            [07.04.2023 22:00.29.597] [LOG] No helper found for module: clock.
                                            [07.04.2023 22:00.29.659] [WARN]  No /home/pi/MagicMirror/js/../modules/calendar_monthly/calendar_monthly.js found for module: calendar_monthly.
                                            [07.04.2023 22:00.29.722] [LOG] No helper found for module: calendar_monthly.
                                            [07.04.2023 22:00.41.528] [LOG] Initializing new module helper ...
                                            [07.04.2023 22:00.41.561] [LOG] Module helper loaded: calendar
                                            [07.04.2023 22:00.41.616] [WARN]  No /home/pi/MagicMirror/js/../modules/random_quotes/random_quotes.js found for module: random_quotes.
                                            [07.04.2023 22:00.41.664] [LOG] No helper found for module: random_quotes.
                                            [07.04.2023 22:00.41.707] [LOG] No helper found for module: weather.
                                            [07.04.2023 22:00.42.663] [LOG] Initializing new module helper ...
                                            [07.04.2023 22:00.42.687] [LOG] Module helper loaded: newsfeed
                                            [07.04.2023 22:00.42.732] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Snow/MMM-Snow.js found for module: MMM-Snow.
                                            [07.04.2023 22:00.42.749] [LOG] No helper found for module: MMM-Snow.
                                            [07.04.2023 22:00.42.786] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Unsplash/MMM-Unsplash.js found for module: MMM-Unsplash.
                                            [07.04.2023 22:00.42.814] [LOG] No helper found for module: MMM-Unsplash.
                                            [07.04.2023 22:00.42.841] [LOG] All module helpers loaded.
                                            [07.04.2023 22:00.43.422] [LOG] Starting server on port 8080 ...
                                            [07.04.2023 22:00.44.420] [LOG] Server started ...
                                            [07.04.2023 22:00.44.470] [LOG] Connecting socket for: updatenotification
                                            [07.04.2023 22:00.44.531] [LOG] Starting module helper: updatenotification
                                            [07.04.2023 22:00.44.568] [LOG] Connecting socket for: calendar
                                            [07.04.2023 22:00.44.598] [LOG] Starting node helper for: calendar
                                            [07.04.2023 22:00.44.642] [LOG] Connecting socket for: newsfeed
                                            [07.04.2023 22:00.44.672] [LOG] Starting node helper for: newsfeed
                                            [07.04.2023 22:00.44.709] [LOG] Sockets connected & modules started ...
                                            [07.04.2023 22:00.44.744] [LOG]
                                            The screen for the raspberry pi is blank. this output is from ssh.
                                            I just typed it again and now I get
                                            /usr/bin/chromium-broswer
                                            sorry about that.
