cannot get Raspberry pi 2 to run
@sdetweil I get this.
Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minute ./run-start.sh: line 147: 1281 Illegal instruction "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2> /dev/null -
@theaddies The way I want to run the mirror is that it automatically opens and displays the mirror at boot. I sometimes see things for serveronly and I am not sure if that is what is being configured. I don’t think that is what I want.
@theaddies ok, a little more info
type in terminal window
which chromium
which chromium-browserthey should return the file path to one of those
whichever gives a path copy paste that in the terminal window
and see if it will start
I’ve never seen a pi 2, but this all works on pi 0w, also armv6l
@theaddies because there is no electron browser anymore for armv6l
I change the setup to serveronly, and then launch chrome browser over the server. you get the same result
/usr/bin/chromium-browser Illegal Instruction -
@theaddies ok, so there is that problem
oh, which raspi os image are you using?
MUST be the legacy image, 32 bit
lsb_release - a
will tell us
if buster is legacy
@sdetweil ```
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 11 (bullseye)
Release: 11
Codename: bullseye -
@theaddies yep, can’t run bullseye on armv6l
must be the legacy image, buster
SOOO
reflash SD card w buster and run install againchromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
need to add another test to install
@sdetweil Oh wow. Sorry for all the trouble. What a pain.
@theaddies no worries.
I’ll update install to end if not buster on armv6l,
then u would have known -
@sdetweil Thanks for all the help. I have several pi4s I just want to use the model 2 because the mirror is a perfect application for the older computer.
@theaddies understood
@sdetweil After I run the install script, what do I do. Since the script disables the screen saver and configures the Mirror to autostart I thought I would not need to do anything else. However, pm2 status all reveals that there is nothing running. I run pm2 status all and it is blank.
I am not sure if I should follow the process in the link below.
https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-piWhen I reboot the mirror I get the magicmirror2 logo showing up and it seems to be booting up but then the screen goes blank and I have nothing. It is almost like it reboots the pi.
@theaddies send me the ~/install.log
and do the same chromium
and
./run-start.sh
testslsb_release -a
to confirm buster
@theaddies you should not need to do anything. it should be setup to autostart
lsb_release -a No LSB modules are available. Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster -
@sdetweil for which chromium or which chromium-browswer I get nothing returned.
@theaddies interesting, log says one of them got installed
Unpacking chromium-browser (92.0.4515.98~buster-rpt2)
note u had an extra w in the text on last message
browswer
pm2 setup for autostart having trouble…you do
pm2 autostart
and it gives you the command to execute to make that happenthen it says it can’t find the systemd init system to update, after it just said that is the one to use…
will have to research and debug -
pi@raspberrypi:~/MagicMirror $ ./run-start.sh [07.04.2023 22:00.28.274] [LOG] Starting MagicMirror: v2.23.0 [07.04.2023 22:00.28.488] [LOG] Loading config ... [07.04.2023 22:00.28.652] [DEBUG] config template file not exists, no envsubst [07.04.2023 22:00.28.853] [LOG] Loading module helpers ... [07.04.2023 22:00.28.933] [LOG] No helper found for module: alert. [07.04.2023 22:00.29.513] [LOG] Initializing new module helper ... [07.04.2023 22:00.29.565] [LOG] Module helper loaded: updatenotification [07.04.2023 22:00.29.597] [LOG] No helper found for module: clock. [07.04.2023 22:00.29.659] [WARN] No /home/pi/MagicMirror/js/../modules/calendar_monthly/calendar_monthly.js found for module: calendar_monthly. [07.04.2023 22:00.29.722] [LOG] No helper found for module: calendar_monthly. [07.04.2023 22:00.41.528] [LOG] Initializing new module helper ... [07.04.2023 22:00.41.561] [LOG] Module helper loaded: calendar [07.04.2023 22:00.41.616] [WARN] No /home/pi/MagicMirror/js/../modules/random_quotes/random_quotes.js found for module: random_quotes. [07.04.2023 22:00.41.664] [LOG] No helper found for module: random_quotes. [07.04.2023 22:00.41.707] [LOG] No helper found for module: weather. [07.04.2023 22:00.42.663] [LOG] Initializing new module helper ... [07.04.2023 22:00.42.687] [LOG] Module helper loaded: newsfeed [07.04.2023 22:00.42.732] [WARN] No /home/pi/MagicMirror/js/../modules/MMM-Snow/MMM-Snow.js found for module: MMM-Snow. [07.04.2023 22:00.42.749] [LOG] No helper found for module: MMM-Snow. [07.04.2023 22:00.42.786] [WARN] No /home/pi/MagicMirror/js/../modules/MMM-Unsplash/MMM-Unsplash.js found for module: MMM-Unsplash. [07.04.2023 22:00.42.814] [LOG] No helper found for module: MMM-Unsplash. [07.04.2023 22:00.42.841] [LOG] All module helpers loaded. [07.04.2023 22:00.43.422] [LOG] Starting server on port 8080 ... [07.04.2023 22:00.44.420] [LOG] Server started ... [07.04.2023 22:00.44.470] [LOG] Connecting socket for: updatenotification [07.04.2023 22:00.44.531] [LOG] Starting module helper: updatenotification [07.04.2023 22:00.44.568] [LOG] Connecting socket for: calendar [07.04.2023 22:00.44.598] [LOG] Starting node helper for: calendar [07.04.2023 22:00.44.642] [LOG] Connecting socket for: newsfeed [07.04.2023 22:00.44.672] [LOG] Starting node helper for: newsfeed [07.04.2023 22:00.44.709] [LOG] Sockets connected & modules started ... [07.04.2023 22:00.44.744] [LOG] Ready to go! Please point your browser to: http://localhost:8080 Starting chromium browser now, have patience, it takes a minuteThe screen for the raspberry pi is blank. this output is from ssh.
I just typed it again and now I get
/usr/bin/chromium-broswersorry about that.
@theaddies screen black, yes, takes long time
increase swap space helps some
use Midori browser helps some more (have to install Midori, and set an env variable, see doc )
