    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 14.8k Views 2 Watching
      sdetweil @theaddies
      @theaddies got the log,let’s try this
      in terminal window, pm2 stop all
      ./run-start.sh
      • T Offline
        theaddies @sdetweil
        @sdetweil I get this.
        Ready to go! Please point your browser to: http://localhost:8080
        Starting chromium browser now, have patience, it takes a minute
        ./run-start.sh: line 147:  1281 Illegal instruction     "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2> /dev/null
        T S 2 Replies Last reply Reply Quote 0
        • T Offline
          theaddies @theaddies
          @theaddies The way I want to run the mirror is that it automatically opens and displays the mirror at boot. I sometimes see things for serveronly and I am not sure if that is what is being configured. I don’t think that is what I want.
            sdetweil @theaddies
            @theaddies ok, a little more info
            type in terminal window
            which chromium
            which chromium-browser
            they should return the file path to one of those
            whichever gives a path copy paste that in the terminal window
            and see if it will start
            I’ve never seen a pi 2, but this all works on pi 0w, also armv6l
              sdetweil @theaddies
              @theaddies because there is no electron browser anymore for armv6l
              I change the setup to serveronly, and then launch chrome browser over the server. you get the same result
              • T Offline
                theaddies @sdetweil
                /usr/bin/chromium-browser
                Illegal Instruction
                  sdetweil @theaddies
                  @theaddies ok, so there is that problem
                  oh, which raspi os image are you using?
                  MUST be the legacy image, 32 bit
                  lsb_release - a
                  will tell us
                  if buster is legacy
                  • T Offline
                    theaddies @sdetweil
                    @sdetweil ```
                    No LSB modules are available.
                    Distributor ID: Raspbian
                    Description: Raspbian GNU/Linux 11 (bullseye)
                    Release: 11
                    Codename: bullseye
                      sdetweil @theaddies
                      @theaddies yep, can’t run bullseye on armv6l
                      must be the legacy image, buster
                      SOOO
                      reflash SD card w buster and run install again
                      chromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
                      need to add another test to install
                      • T Offline
                        theaddies @sdetweil
                        @sdetweil Oh wow. Sorry for all the trouble. What a pain.
                        • 1 / 4
