    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 18.3k Views 2 Watching
      sdetweil @theaddies
      @theaddies armv6 is slow. could be 3 minutes til mm comes up.
      can you show me the output of
      pm2 logs --lines=50
      the script should have modified package.json start clause to be ./run-start.sh
      no electron is available for armv6 anymore, so I try to launch chromium.
      also send me the ~/install.log
      sane userid at gmail
      T 2 Replies Last reply Reply Quote 0
      • T Offline
        theaddies @sdetweil
        @sdetweil It is slow, but I have been working on this for 12 hours so there is ample time for something to have worked.
        pi@raspberrypi:~ $ pm2 logs --lines=50
        [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
        [PM2] PM2 Successfully daemonized
        [TAILING] Tailing last 50 lines for [all] processes (change the value with --lines option)
        /home/pi/.pm2/pm2.log last 50 lines:
        PM2        | 2023-04-07T18:26:05: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:26:45: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:26:45: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:26:45: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:27:25: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:27:25: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:27:25: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:28:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:28:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:28:09: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:28:57: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:28:57: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:28:57: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:29:49: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:29:49: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:29:49: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:30:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:30:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:30:28: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:31:08: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:31:08: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:31:09: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:31:48: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:31:48: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:31:49: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:32:28: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
        PM2        | 2023-04-07T18:32:28: PM2 log: App [MagicMirror:0] starting in -fork mode-
        PM2        | 2023-04-07T18:32:28: PM2 log: App [MagicMirror:0] online
        PM2        | 2023-04-07T18:33:09: PM2 log: pm2 has been killed by signal, dumping process list before exit...
        PM2        | 2023-04-07T18:33:09: PM2 log: Deleting process 0
        PM2        | 2023-04-07T18:33:09: PM2 log: Stopping app:MagicMirror id:0
        PM2        | 2023-04-07T18:33:10: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGTERM]
        PM2        | 2023-04-07T18:33:12: PM2 log: pid=10286 msg=process killed
        PM2        | 2023-04-07T18:33:12: PM2 log: Exited peacefully
        PM2        | 2023-04-07T18:36:32: PM2 log: ===============================================================================
        PM2        | 2023-04-07T18:36:33: PM2 log: --- New PM2 Daemon started ----------------------------------------------------
        PM2        | 2023-04-07T18:36:33: PM2 log: Time                 : Fri Apr 07 2023 18:36:33 GMT-0400 (Eastern Daylight Time)
        PM2        | 2023-04-07T18:36:33: PM2 log: PM2 version          : 5.3.0
        PM2        | 2023-04-07T18:36:33: PM2 log: Node.js version      : 16.13.0
        PM2        | 2023-04-07T18:36:33: PM2 log: Current arch         : arm
        PM2        | 2023-04-07T18:36:33: PM2 log: PM2 home             : /home/pi/.pm2
        PM2        | 2023-04-07T18:36:33: PM2 log: PM2 PID file         : /home/pi/.pm2/pm2.pid
        PM2        | 2023-04-07T18:36:33: PM2 log: RPC socket file      : /home/pi/.pm2/rpc.sock
        PM2        | 2023-04-07T18:36:33: PM2 log: BUS socket file      : /home/pi/.pm2/pub.sock
        PM2        | 2023-04-07T18:36:33: PM2 log: Application log path : /home/pi/.pm2/logs
        PM2        | 2023-04-07T18:36:33: PM2 log: Worker Interval      : 30000
        PM2        | 2023-04-07T18:36:33: PM2 log: Process dump file    : /home/pi/.pm2/dump.pm2
        PM2        | 2023-04-07T18:36:33: PM2 log: Concurrent actions   : 2
        PM2        | 2023-04-07T18:36:33: PM2 log: SIGTERM timeout      : 1600
        PM2        | 2023-04-07T18:36:33: PM2 log: ===============================================================================
        • T Offline
          theaddies @sdetweil
          @sdetweil Log file sent.
            sdetweil @theaddies
            @theaddies got the log,let’s try this
            in terminal window, pm2 stop all
            ./run-start.sh
            • T Offline
              theaddies @sdetweil
              @sdetweil I get this.
              Ready to go! Please point your browser to: http://localhost:8080
              Starting chromium browser now, have patience, it takes a minute
              ./run-start.sh: line 147:  1281 Illegal instruction     "$b" -noerrdialogs -kiosk -start_maximized --new-window --site-per-process --no-zygote --no-sandbox --disable-infobars --app=http://localhost:$port --ignore-certificate-errors-spki-list --ignore-ssl-errors --ignore-certificate-errors --user-data-dir=$r 2> /dev/null
              T S 2 Replies Last reply Reply Quote 0
              • T Offline
                theaddies @theaddies
                @theaddies The way I want to run the mirror is that it automatically opens and displays the mirror at boot. I sometimes see things for serveronly and I am not sure if that is what is being configured. I don’t think that is what I want.
                  sdetweil @theaddies
                  @theaddies ok, a little more info
                  type in terminal window
                  which chromium
                  which chromium-browser
                  they should return the file path to one of those
                  whichever gives a path copy paste that in the terminal window
                  and see if it will start
                  I’ve never seen a pi 2, but this all works on pi 0w, also armv6l
                    sdetweil @theaddies
                    @theaddies because there is no electron browser anymore for armv6l
                    I change the setup to serveronly, and then launch chrome browser over the server. you get the same result
                    • T Offline
                      theaddies @sdetweil
                      /usr/bin/chromium-browser
                      Illegal Instruction
                        sdetweil @theaddies
                        @theaddies ok, so there is that problem
                        oh, which raspi os image are you using?
                        MUST be the legacy image, 32 bit
                        lsb_release - a
                        will tell us
                        if buster is legacy
                        • T Offline
                          theaddies @sdetweil
                          @sdetweil ```
                          No LSB modules are available.
                          Distributor ID: Raspbian
                          Description: Raspbian GNU/Linux 11 (bullseye)
                          Release: 11
                          Codename: bullseye
                            sdetweil @theaddies
                            @theaddies yep, can’t run bullseye on armv6l
                            must be the legacy image, buster
                            SOOO
                            reflash SD card w buster and run install again
                            chromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
                            need to add another test to install
                            • T Offline
                              theaddies @sdetweil
                              @sdetweil Oh wow. Sorry for all the trouble. What a pain.
                                sdetweil @theaddies
                                @theaddies no worries.
                                I’ll update install to end if not buster on armv6l,
                                then u would have known
                                • T Offline
                                  theaddies @sdetweil
                                  @sdetweil Thanks for all the help. I have several pi4s I just want to use the model 2 because the mirror is a perfect application for the older computer.
                                    sdetweil @theaddies
                                    @theaddies understood
                                    • T Offline
                                      theaddies @sdetweil
                                      @sdetweil After I run the install script, what do I do. Since the script disables the screen saver and configures the Mirror to autostart I thought I would not need to do anything else. However, pm2 status all reveals that there is nothing running. I run pm2 status all and it is blank.
                                      I am not sure if I should follow the process in the link below.
                                      https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi
                                      When I reboot the mirror I get the magicmirror2 logo showing up and it seems to be booting up but then the screen goes blank and I have nothing. It is almost like it reboots the pi.
                                        sdetweil @theaddies
                                        @theaddies send me the ~/install.log
                                        and do the same chromium
                                        and
                                        ./run-start.sh
                                        tests
                                        lsb_release -a
                                        to confirm buster
                                          sdetweil @theaddies
                                          @theaddies you should not need to do anything. it should be setup to autostart
                                          • T Offline
                                            theaddies @sdetweil
                                            lsb_release -a
                                            Description:    Raspbian GNU/Linux 10 (buster)
                                            Release:        10
                                            Codename:       buster
