    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 19.1k Views 2 Watching
      sdetweil @theaddies
      @theaddies yep, can’t run bullseye on armv6l
      must be the legacy image, buster
      SOOO
      reflash SD card w buster and run install again
      chromium is compiled for armv7, so instructions armv6 doesn’t have, this illegal instruction error
      need to add another test to install
      • T
        theaddies @sdetweil
        @sdetweil Oh wow. Sorry for all the trouble. What a pain.
          sdetweil @theaddies
          @theaddies no worries.
          I’ll update install to end if not buster on armv6l,
          then u would have known
          • T
            theaddies @sdetweil
            @sdetweil Thanks for all the help. I have several pi4s I just want to use the model 2 because the mirror is a perfect application for the older computer.
              sdetweil @theaddies
              @theaddies understood
              • T
                theaddies @sdetweil
                @sdetweil After I run the install script, what do I do. Since the script disables the screen saver and configures the Mirror to autostart I thought I would not need to do anything else. However, pm2 status all reveals that there is nothing running. I run pm2 status all and it is blank.
                I am not sure if I should follow the process in the link below.
                https://howchoo.com/g/ntcymzbimjv/how-to-install-magic-mirror-on-your-raspberry-pi
                When I reboot the mirror I get the magicmirror2 logo showing up and it seems to be booting up but then the screen goes blank and I have nothing. It is almost like it reboots the pi.
                  sdetweil @theaddies
                  @theaddies send me the ~/install.log
                  and do the same chromium
                  and
                  ./run-start.sh
                  tests
                  lsb_release -a
                  to confirm buster
                    sdetweil @theaddies
                    @theaddies you should not need to do anything. it should be setup to autostart
                    • T
                      theaddies @sdetweil
                      lsb_release -a
                      No LSB modules are available.
                      Distributor ID: Raspbian
                      Description:    Raspbian GNU/Linux 10 (buster)
                      Release:        10
                      Codename:       buster
                      • T
                        theaddies @sdetweil
                        @sdetweil for which chromium or which chromium-browswer I get nothing returned.
                          sdetweil @theaddies
                          @theaddies interesting, log says one of them got installed
                          Unpacking chromium-browser (92.0.4515.98~buster-rpt2)
                          note u had an extra w in the text on last message
                          browswer
                          pm2 setup for autostart having trouble…
                          you do
                          pm2 autostart
                          and it gives you the command to execute to make that happen
                          then it says it can’t find the systemd init system to update, after it just said that is the one to use…
                          will have to research and debug
                          • T
                            theaddies @sdetweil
                            pi@raspberrypi:~/MagicMirror $ ./run-start.sh
                            [07.04.2023 22:00.28.274] [LOG] Starting MagicMirror: v2.23.0
                            [07.04.2023 22:00.28.488] [LOG] Loading config ...
                            [07.04.2023 22:00.28.652] [DEBUG] config template file not exists, no envsubst
                            [07.04.2023 22:00.28.853] [LOG] Loading module helpers ...
                            [07.04.2023 22:00.28.933] [LOG] No helper found for module: alert.
                            [07.04.2023 22:00.29.513] [LOG] Initializing new module helper ...
                            [07.04.2023 22:00.29.565] [LOG] Module helper loaded: updatenotification
                            [07.04.2023 22:00.29.597] [LOG] No helper found for module: clock.
                            [07.04.2023 22:00.29.659] [WARN]  No /home/pi/MagicMirror/js/../modules/calendar_monthly/calendar_monthly.js found for module: calendar_monthly.
                            [07.04.2023 22:00.29.722] [LOG] No helper found for module: calendar_monthly.
                            [07.04.2023 22:00.41.528] [LOG] Initializing new module helper ...
                            [07.04.2023 22:00.41.561] [LOG] Module helper loaded: calendar
                            [07.04.2023 22:00.41.616] [WARN]  No /home/pi/MagicMirror/js/../modules/random_quotes/random_quotes.js found for module: random_quotes.
                            [07.04.2023 22:00.41.664] [LOG] No helper found for module: random_quotes.
                            [07.04.2023 22:00.41.707] [LOG] No helper found for module: weather.
                            [07.04.2023 22:00.42.663] [LOG] Initializing new module helper ...
                            [07.04.2023 22:00.42.687] [LOG] Module helper loaded: newsfeed
                            [07.04.2023 22:00.42.732] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Snow/MMM-Snow.js found for module: MMM-Snow.
                            [07.04.2023 22:00.42.749] [LOG] No helper found for module: MMM-Snow.
                            [07.04.2023 22:00.42.786] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Unsplash/MMM-Unsplash.js found for module: MMM-Unsplash.
                            [07.04.2023 22:00.42.814] [LOG] No helper found for module: MMM-Unsplash.
                            [07.04.2023 22:00.42.841] [LOG] All module helpers loaded.
                            [07.04.2023 22:00.43.422] [LOG] Starting server on port 8080 ...
                            [07.04.2023 22:00.44.420] [LOG] Server started ...
                            [07.04.2023 22:00.44.470] [LOG] Connecting socket for: updatenotification
                            [07.04.2023 22:00.44.531] [LOG] Starting module helper: updatenotification
                            [07.04.2023 22:00.44.568] [LOG] Connecting socket for: calendar
                            [07.04.2023 22:00.44.598] [LOG] Starting node helper for: calendar
                            [07.04.2023 22:00.44.642] [LOG] Connecting socket for: newsfeed
                            [07.04.2023 22:00.44.672] [LOG] Starting node helper for: newsfeed
                            [07.04.2023 22:00.44.709] [LOG] Sockets connected & modules started ...
                            [07.04.2023 22:00.44.744] [LOG]
                            Ready to go! Please point your browser to: http://localhost:8080
                            Starting chromium browser now, have patience, it takes a minute
                            The screen for the raspberry pi is blank. this output is from ssh.
                            I just typed it again and now I get
                            /usr/bin/chromium-broswer
                            sorry about that.
                              sdetweil @theaddies
                              @theaddies screen black, yes, takes long time
                              increase swap space helps some
                              use Midori browser helps some more (have to install Midori, and set an env variable, see doc )
                              • T
                                theaddies @sdetweil
                                @sdetweil The screen has been black for an hour. When i reboot, the first thing I see is the MagicMirror logo. That is different than before. Before it booted into the raspian desktop and then the magicmirror loaded. It did take a while. Now, as I said above, I see the MagicMirror logo it seems to be loading and then the screen goes blank. It does not come back. ssh works, but the keyboard and mouse on the pi itself will not wake it up.
                                I did see the correct screen after I ran the command below, but I can’t do that now.
                                DISPLAY=:0 npm start
                                S 4 Replies Last reply Reply Quote 0
                                  sdetweil @theaddies
                                  @theaddies pm2 is not working for autostart for some reason
                                    sdetweil @theaddies
                                    @theaddies reboot, then run the fixuppm2 script from my scripts page…
                                    let me know
                                      sdetweil @theaddies
                                      @theaddies ok, I was able to reproduce the problem
                                      after reboot do this
                                      pm2 startup
                                      it will return a command to execute
                                      copy paste that command and hit enter
                                      it worked for me to manually enter the command
                                      i opened this issue in pm2
                                      https://github.com/Unitech/pm2/issues/5582
                                        sdetweil @theaddies
                                        @theaddies i updated the install script to fail if the system is bullseye and this is an armv6l device
                                        • T
                                          theaddies @sdetweil
                                          @sdetweil I cannot get the pi to display anything via hdmi. my only access to it now is via ssh.
                                            sdetweil @theaddies
                                            @theaddies eh? not even the desktop?
                                            I installed fresh on my pi0w, (all via ssh) and after fixing the pm2 issue it autostarts mm as expected
