    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 19.4k Views 2 Watching
      sdetweil @theaddies
      @theaddies you should not need to do anything. it should be setup to autostart
      T 1 Reply Last reply
      • T
        theaddies @sdetweil
        lsb_release -a
        No LSB modules are available.
        Distributor ID: Raspbian
        Description:    Raspbian GNU/Linux 10 (buster)
        Release:        10
        Codename:       buster
        • T
          theaddies @sdetweil
          @sdetweil for which chromium or which chromium-browswer I get nothing returned.
            sdetweil @theaddies
            @theaddies interesting, log says one of them got installed
            Unpacking chromium-browser (92.0.4515.98~buster-rpt2)
            note u had an extra w in the text on last message
            browswer
            pm2 setup for autostart having trouble…
            you do
            pm2 autostart
            and it gives you the command to execute to make that happen
            then it says it can’t find the systemd init system to update, after it just said that is the one to use…
            will have to research and debug
            • T
              theaddies @sdetweil
              pi@raspberrypi:~/MagicMirror $ ./run-start.sh
              [07.04.2023 22:00.28.274] [LOG] Starting MagicMirror: v2.23.0
              [07.04.2023 22:00.28.488] [LOG] Loading config ...
              [07.04.2023 22:00.28.652] [DEBUG] config template file not exists, no envsubst
              [07.04.2023 22:00.28.853] [LOG] Loading module helpers ...
              [07.04.2023 22:00.28.933] [LOG] No helper found for module: alert.
              [07.04.2023 22:00.29.513] [LOG] Initializing new module helper ...
              [07.04.2023 22:00.29.565] [LOG] Module helper loaded: updatenotification
              [07.04.2023 22:00.29.597] [LOG] No helper found for module: clock.
              [07.04.2023 22:00.29.659] [WARN]  No /home/pi/MagicMirror/js/../modules/calendar_monthly/calendar_monthly.js found for module: calendar_monthly.
              [07.04.2023 22:00.29.722] [LOG] No helper found for module: calendar_monthly.
              [07.04.2023 22:00.41.528] [LOG] Initializing new module helper ...
              [07.04.2023 22:00.41.561] [LOG] Module helper loaded: calendar
              [07.04.2023 22:00.41.616] [WARN]  No /home/pi/MagicMirror/js/../modules/random_quotes/random_quotes.js found for module: random_quotes.
              [07.04.2023 22:00.41.664] [LOG] No helper found for module: random_quotes.
              [07.04.2023 22:00.41.707] [LOG] No helper found for module: weather.
              [07.04.2023 22:00.42.663] [LOG] Initializing new module helper ...
              [07.04.2023 22:00.42.687] [LOG] Module helper loaded: newsfeed
              [07.04.2023 22:00.42.732] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Snow/MMM-Snow.js found for module: MMM-Snow.
              [07.04.2023 22:00.42.749] [LOG] No helper found for module: MMM-Snow.
              [07.04.2023 22:00.42.786] [WARN]  No /home/pi/MagicMirror/js/../modules/MMM-Unsplash/MMM-Unsplash.js found for module: MMM-Unsplash.
              [07.04.2023 22:00.42.814] [LOG] No helper found for module: MMM-Unsplash.
              [07.04.2023 22:00.42.841] [LOG] All module helpers loaded.
              [07.04.2023 22:00.43.422] [LOG] Starting server on port 8080 ...
              [07.04.2023 22:00.44.420] [LOG] Server started ...
              [07.04.2023 22:00.44.470] [LOG] Connecting socket for: updatenotification
              [07.04.2023 22:00.44.531] [LOG] Starting module helper: updatenotification
              [07.04.2023 22:00.44.568] [LOG] Connecting socket for: calendar
              [07.04.2023 22:00.44.598] [LOG] Starting node helper for: calendar
              [07.04.2023 22:00.44.642] [LOG] Connecting socket for: newsfeed
              [07.04.2023 22:00.44.672] [LOG] Starting node helper for: newsfeed
              [07.04.2023 22:00.44.709] [LOG] Sockets connected & modules started ...
              [07.04.2023 22:00.44.744] [LOG]
              Ready to go! Please point your browser to: http://localhost:8080
              Starting chromium browser now, have patience, it takes a minute
              The screen for the raspberry pi is blank. this output is from ssh.
              I just typed it again and now I get
              /usr/bin/chromium-broswer
              sorry about that.
                sdetweil @theaddies
                @theaddies screen black, yes, takes long time
                increase swap space helps some
                use Midori browser helps some more (have to install Midori, and set an env variable, see doc )
                • T
                  theaddies @sdetweil
                  @sdetweil The screen has been black for an hour. When i reboot, the first thing I see is the MagicMirror logo. That is different than before. Before it booted into the raspian desktop and then the magicmirror loaded. It did take a while. Now, as I said above, I see the MagicMirror logo it seems to be loading and then the screen goes blank. It does not come back. ssh works, but the keyboard and mouse on the pi itself will not wake it up.
                  I did see the correct screen after I ran the command below, but I can’t do that now.
                  DISPLAY=:0 npm start
                  S 4 Replies Last reply
                    sdetweil @theaddies
                    @theaddies pm2 is not working for autostart for some reason
                      sdetweil @theaddies
                      @theaddies reboot, then run the fixuppm2 script from my scripts page…
                      let me know
                        sdetweil @theaddies
                        @theaddies ok, I was able to reproduce the problem
                        after reboot do this
                        pm2 startup
                        it will return a command to execute
                        copy paste that command and hit enter
                        it worked for me to manually enter the command
                        i opened this issue in pm2
                        https://github.com/Unitech/pm2/issues/5582
                          sdetweil @theaddies
                          @theaddies i updated the install script to fail if the system is bullseye and this is an armv6l device
                          • T
                            theaddies @sdetweil
                            @sdetweil I cannot get the pi to display anything via hdmi. my only access to it now is via ssh.
                              sdetweil @theaddies
                              @theaddies eh? not even the desktop?
                              I installed fresh on my pi0w, (all via ssh) and after fixing the pm2 issue it autostarts mm as expected
                              • T
                                theaddies @sdetweil
                                @sdetweil I just followed the procedure on a pi4 and everything worked great.
                                  sdetweil @theaddies
                                  @theaddies cool
                                  my pi0w test
                                  flash sd card with legacy full desktop, 32gb sd card
                                  edit the wap_supplicant file to enable wifi
                                  boot
                                  auto run update
                                  enable ssh
                                  change machine name (add a 0) (have others running on the network , pi3, pi4, pi42…)
                                  reboot
                                  logon via ssh
                                  paste my install script url
                                  run
                                  select yes to pm2
                                  select yes to screen saver off
                                  pm2 install failed
                                  fixuppm2 script failed
                                  reboot
                                  logon via ssh
                                  run the pm2 startup command
                                  copy/paste the output to execute pm2 setup again
                                  worked this time
                                  run fixuppm2 to add mm as an app…
                                  mm starts
                                  reboot
                                  mm starts
                                  • T
                                    theaddies @sdetweil
                                    @sdetweil I am loathed to start the pi2 over again for the fourth time. here is what I have right now. I think I got MagicMirror and mm removed from the pm2. I installed mm when I thought things were not working.
                                    The HDMI output still does not work. I was thinking now I would run the pm2 startup command although I am sure I already did it and then I would run fixuppm2.
                                    • T
                                      theaddies @theaddies
                                        sdetweil @theaddies
                                        @theaddies yes, it says spawining, so pm2 is not set to autostart
                                        do
                                        pm2 startup
                                        it will output a command string, copy paste that command string (last line) and hit enter,
                                        DO NOT USE MINE BELOW
                                        pi@raspberrypi0:~ $ pm2 startup
                                        [PM2] Init System found: systemd
                                        [PM2] To setup the Startup Script, copy/paste the following command:
                                        sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                                        note the error in your post of running my fixuppm2 script
                                        init system not found
                                        THAT is the problem… for some reason it cannot figure out HOW to do the correct startup stuff…
                                        BUT it just said what type to use…
                                        • T
                                          theaddies @sdetweil
                                          @sdetweil OK So I went ahead and did the whole thing over again for the fourth time with the exact method you outlined. It works. It would be nice to somehow let the next poor sod who wants to waste 2 days of their life of the right way to do this on a pi2.
                                            sdetweil @theaddies
                                            @theaddies I am trying to get a fix for pm2. not our code, so nothing we can force
                                            glad u got it working
