    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 18.6k Views 2 Watching
      sdetweil @theaddies
      @theaddies pm2 is not working for autostart for some reason
        sdetweil @theaddies
        @theaddies reboot, then run the fixuppm2 script from my scripts page…
        let me know
          sdetweil @theaddies
          @theaddies ok, I was able to reproduce the problem
          after reboot do this
          pm2 startup
          it will return a command to execute
          copy paste that command and hit enter
          it worked for me to manually enter the command
          i opened this issue in pm2
          https://github.com/Unitech/pm2/issues/5582
            sdetweil @theaddies
            @theaddies i updated the install script to fail if the system is bullseye and this is an armv6l device
            • T Offline
              theaddies @sdetweil
              @sdetweil I cannot get the pi to display anything via hdmi. my only access to it now is via ssh.
                sdetweil @theaddies
                @theaddies eh? not even the desktop?
                I installed fresh on my pi0w, (all via ssh) and after fixing the pm2 issue it autostarts mm as expected
                • T Offline
                  theaddies @sdetweil
                  @sdetweil I just followed the procedure on a pi4 and everything worked great.
                    sdetweil @theaddies
                    @theaddies cool
                    my pi0w test
                    flash sd card with legacy full desktop, 32gb sd card
                    edit the wap_supplicant file to enable wifi
                    boot
                    auto run update
                    enable ssh
                    change machine name (add a 0) (have others running on the network , pi3, pi4, pi42…)
                    reboot
                    logon via ssh
                    paste my install script url
                    run
                    select yes to pm2
                    select yes to screen saver off
                    pm2 install failed
                    fixuppm2 script failed
                    reboot
                    logon via ssh
                    run the pm2 startup command
                    copy/paste the output to execute pm2 setup again
                    worked this time
                    run fixuppm2 to add mm as an app…
                    mm starts
                    reboot
                    mm starts
                    • T Offline
                      theaddies @sdetweil
                      @sdetweil I am loathed to start the pi2 over again for the fourth time. here is what I have right now. I think I got MagicMirror and mm removed from the pm2. I installed mm when I thought things were not working.
                      The HDMI output still does not work. I was thinking now I would run the pm2 startup command although I am sure I already did it and then I would run fixuppm2.
                      • T Offline
                        theaddies @theaddies
                          sdetweil @theaddies
                          @theaddies yes, it says spawining, so pm2 is not set to autostart
                          do
                          pm2 startup
                          it will output a command string, copy paste that command string (last line) and hit enter,
                          DO NOT USE MINE BELOW
                          pi@raspberrypi0:~ $ pm2 startup
                          [PM2] Init System found: systemd
                          [PM2] To setup the Startup Script, copy/paste the following command:
                          sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                          note the error in your post of running my fixuppm2 script
                          init system not found
                          THAT is the problem… for some reason it cannot figure out HOW to do the correct startup stuff…
                          BUT it just said what type to use…
                          • T Offline
                            theaddies @sdetweil
                            @sdetweil OK So I went ahead and did the whole thing over again for the fourth time with the exact method you outlined. It works. It would be nice to somehow let the next poor sod who wants to waste 2 days of their life of the right way to do this on a pi2.
                              sdetweil @theaddies
                              @theaddies I am trying to get a fix for pm2. not our code, so nothing we can force
                              glad u got it working
