    cannot get Raspberry pi 2 to run
    39 Posts 2 Posters 19.1k Views 2 Watching
      sdetweil @theaddies
      @theaddies screen black, yes, takes long time
      increase swap space helps some
      use Midori browser helps some more (have to install Midori, and set an env variable, see doc )
      • T
        theaddies @sdetweil
        @sdetweil The screen has been black for an hour. When i reboot, the first thing I see is the MagicMirror logo. That is different than before. Before it booted into the raspian desktop and then the magicmirror loaded. It did take a while. Now, as I said above, I see the MagicMirror logo it seems to be loading and then the screen goes blank. It does not come back. ssh works, but the keyboard and mouse on the pi itself will not wake it up.
        I did see the correct screen after I ran the command below, but I can’t do that now.
        DISPLAY=:0 npm start
        S 4 Replies Last reply Reply Quote 0
          sdetweil @theaddies
          @theaddies pm2 is not working for autostart for some reason
            sdetweil @theaddies
            @theaddies reboot, then run the fixuppm2 script from my scripts page…
            let me know
              sdetweil @theaddies
              @theaddies ok, I was able to reproduce the problem
              after reboot do this
              pm2 startup
              it will return a command to execute
              copy paste that command and hit enter
              it worked for me to manually enter the command
              i opened this issue in pm2
              https://github.com/Unitech/pm2/issues/5582
                sdetweil @theaddies
                @theaddies i updated the install script to fail if the system is bullseye and this is an armv6l device
                • T
                  theaddies @sdetweil
                  @sdetweil I cannot get the pi to display anything via hdmi. my only access to it now is via ssh.
                    sdetweil @theaddies
                    @theaddies eh? not even the desktop?
                    I installed fresh on my pi0w, (all via ssh) and after fixing the pm2 issue it autostarts mm as expected
                    • T
                      theaddies @sdetweil
                      @sdetweil I just followed the procedure on a pi4 and everything worked great.
                        sdetweil @theaddies
                        @theaddies cool
                        my pi0w test
                        flash sd card with legacy full desktop, 32gb sd card
                        edit the wap_supplicant file to enable wifi
                        boot
                        auto run update
                        enable ssh
                        change machine name (add a 0) (have others running on the network , pi3, pi4, pi42…)
                        reboot
                        logon via ssh
                        paste my install script url
                        run
                        select yes to pm2
                        select yes to screen saver off
                        pm2 install failed
                        fixuppm2 script failed
                        reboot
                        logon via ssh
                        run the pm2 startup command
                        copy/paste the output to execute pm2 setup again
                        worked this time
                        run fixuppm2 to add mm as an app…
                        mm starts
                        reboot
                        mm starts
                        • T
                          theaddies @sdetweil
                          @sdetweil I am loathed to start the pi2 over again for the fourth time. here is what I have right now. I think I got MagicMirror and mm removed from the pm2. I installed mm when I thought things were not working.
                          The HDMI output still does not work. I was thinking now I would run the pm2 startup command although I am sure I already did it and then I would run fixuppm2.
                          • T
                            theaddies @theaddies
                              sdetweil @theaddies
                              @theaddies yes, it says spawining, so pm2 is not set to autostart
                              do
                              pm2 startup
                              it will output a command string, copy paste that command string (last line) and hit enter,
                              DO NOT USE MINE BELOW
                              pi@raspberrypi0:~ $ pm2 startup
                              [PM2] Init System found: systemd
                              [PM2] To setup the Startup Script, copy/paste the following command:
                              sudo env PATH=$PATH:/usr/local/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                              note the error in your post of running my fixuppm2 script
                              init system not found
                              THAT is the problem… for some reason it cannot figure out HOW to do the correct startup stuff…
                              BUT it just said what type to use…
                              • T
                                theaddies @sdetweil
                                @sdetweil OK So I went ahead and did the whole thing over again for the fourth time with the exact method you outlined. It works. It would be nice to somehow let the next poor sod who wants to waste 2 days of their life of the right way to do this on a pi2.
                                  sdetweil @theaddies
                                  @theaddies I am trying to get a fix for pm2. not our code, so nothing we can force
                                  glad u got it working
