    MM-Navbar - Navigation Bar for Touchscreens to hide/show modules
    47 Posts 11 Posters 51.9k Views 15 Watching
      shashank @chrisyy
      @chrisyy hi, i installed this module works great, how can i toggle between 2 same modules, example MMM-mails i need to toggle emails between gmail and hotmail , gmail to show hotmail to hide and vice versa
      • T
        tidus5
        Hey @chrisyy - hope you are well.
        Since the update i have a problem with the hide/show all butt - function not recognized in this line
        			MM.getModules().exceptWithClass('MM-navbar').exceptWithClass('MMM-ShipmentTracking').exceptWithClass('clock').enumerate(function(module){
        and now the weather and the current weather are not hide at startup - do you have the same problem ?
          chrisyy @shashank
          @shashank u would need to have 2 of them installed, lets say one is Mail-Gmail, the second is Mail-Hotmail
          @tidus5 until now i haven’t tested it and im moving to a new place, so i my mirror aswell as my server is laying in a box right now. I saw that in the new version, there are visibility-locking options. Maybe this will have to do something with it. As soon as it is possible for me to do something, i will take a look and hopefully can fix this.
          second thing: u should not make 3x exceptwithclass, do one and separate the modules with commata.
          • I
            in_a_days
            I think this module is very cool! My present build is non-touch so I made some small additions (informed by @GinSeng in another thread) and I’m currently using voice to trigger the Navbar. Love it! I’ll be happy to provide code or details if anybody is interested.
              shashank @in_a_days
              @in_a_days hi, can you please share the code
              • A
                AlessandroRa @chrisyy
                Hi @chrisyy thank you for this awesome module!
                Only problem is that with this module on, the Hide/show all module disappeared. How can I fix it?
                Thanks!
                • I
                  in_a_days @shashank
                  @shashank
                  For sure. Forgive me if there are several steps.
                  First thing is to install this module
                  https://github.com/alexyak/voicecontrol
                  Go to your MagicMirror/modules folder and type
                  git clone https://github.com/alexyak/voicecontrol.git
                  Then install dependencies with
                  sudo apt-get install python-pyaudio python3-pyaudio sox
                  Next, install the navbar. Again, make sure you are in the MagicMirror/modules folder and type
                  git clone https://github.com/chr1syy/MM-navbar.git
                  Then you will need to go to this website and define your voice commands.
                  https://snowboy.kitt.ai/
                  Keep track of the keywords you define and the filenames you produce. Each keyword/command will require you to download a .pmdl file that needs to be copied into the MagicMirror folder on your Pi. I’m only using 3 commands so far - calendar, newsfeed, and weather.
                  Still with me? Sweet! Lets configure config.js. Go to the MagicMirror/config folder and
                  nano config.js
                  Assuming you know where to place a new module in this file, add the navbar module with
                                      module: 'MM-navbar',
                                      position: 'fullscreen_above'
                  Next we will add the voice control call to the same config.js file. There are a couple variables here that will depend on the keywords and filenames you used on the snowboy site. Here is the code I use
                                      module: 'voicecontrol',
                                      position: 'bottom_right',
                                              models: [
        keyword: "Calendar",
        description: "Say 'Calendar' to toggle display",
        file: "calendar.pmdl",
        message: "CALENDAR"
        keyword: "Newsfeed",
        description: "Say 'Newsfeed' to toggle display",
        file: "newsfeed.pmdl",
        message: "NEWSFEED"
        keyword: "Weather",
        description: "Say 'Weather' to toggle display",
        file: "weather.pmdl",
        message: "WEATHER"
                  Note that the keyword and file need to match the keyword and filenames you used on your Snowboy files. Save and quit out of config.js and we’ll hit the last step. We need to make a couple changes to the navbar code. Navigate to MagicMirror/modules/MM-navbar then
                  nano MM-navbar.js
                  First change is at line 13. Right now lines 12-19 look like this
                  notificationReceived: function(notification, payload, sender){
                  	if (notification === 'DOM_OBJECTS_CREATED'){
                  		MM.getModules().exceptModule(this).exceptWithClass('clock').enumerate(function(module){
                  			module.hide(1000, function(){
                  You will need to modify it to look like this
                              if (notification === "CALENDAR"){
                                      var calendarbutton = document.getElementById('calendar-button');
                                      calendarbutton.click();
                              if (notification === "NEWSFEED"){
                                      var newsbutton = document.getElementById('news-button');
                                      newsbutton.click();
                              if (notification === "WEATHER"){
                                      var weatherbutton = document.getElementById('weather-button');
                                      weatherbutton.click();
                  Now we’re going down to the section that originally starts on line 32
                  	wrapper.className = "center";
                  	weatherbutton.className = "wi wi-day-rain-mix navbar";
                  	calendarbutton.className = "fa fa-calendar navbar";
                  	newsbutton.className = "fa fa-newspaper-o navbar";
                  And change it to
                              weatherbutton.id = 'weather-button';
                              calendarbutton.id = 'calendar-button';
                              newsbutton.id = 'news-button';
                  Save, close and restart your MM and you should have a working, voice responsive nav bar. I know there are kind of a lot of steps here and typos and omissions are entirely possible. If you have any problems let me know and I’ll try to help. Cheers!
                  C S 2 Replies Last reply Reply Quote 0
                    chrisyy @in_a_days
                    @in_a_days maybe u can make a fork of it in git? Thanks for sharing ur code.
                    @AlessandroRa There’s also a button in this module for hiding/showing everything. Do u have another module that will do this function for it?
                    @All
                    Forgive me if I’m not answering in time. Since I’m moving my time is very limited.
                    When we are done (maybe in 2-3 Weeks) i will do some updates on my own mirror and will update code if needed.
                    U can also submit code on git, i will take a look and implement it.
                    I’ll try to Keep in touch.
                    I A 2 Replies Last reply Reply Quote 0
                    • I
                      in_a_days @chrisyy
                      @chrisyy
                      Here is the navbar code with my modifications:
                      https://github.com/in-a-days/MM-navbar
                      The user will still need to install voicecontrol, create and load the .pmdl files, and properly configure config.js.
                      Is the show/hide all button part of this build? I’m looking for something like
                      	var showallbutton = document.createElement("span");
                      to match these
                      	var weatherbutton = document.createElement("span");
                      	var newsbutton = document.createElement("span");
                      And I’m not finding anything. Thanks again, I really love this module!
                      • A
                        @chrisyy All I have is the weather, calendar and news buttons, how can I get more of them?
                        I’m using: Mail, Hello World, Alarm, News, Calendar and Music player.
                        For hiding/showing all I’m using this module: https://github.com/masters1222/mm-hide-all
                        • T
                          tosti007 Module Developer
                          @chrisyy first of all I want to say that your module looks really nice, unfortunate that my mirror won’t have touch ;(. This module could be used in conjunction with my ProfileSwitcher module. This way you won’t have to bother with showing/hiding certain modules and others won’t have to modify your code. :)
                          If there is anything don’t hesitate to contact me!
                          ProfileSwitcher, TouchNotifications
                            chrisyy @AlessandroRa
                            @AlessandroRa for now, u have to copy a button and Change the code to another module.
                            @tosti007 Thanks for the tip. i’ll have a look at the module.
                              chrisyy @in_a_days
                              @in_a_days the code for Show/hide alle of the modules is
                              MM.getModules().exceptModule(this).exceptWithClass(‘clock’).enumerate(function(module){
                              but there is not a button implemented until now.
                              • T
                                I gave your code a look an notived that you imported jquery. First of all, you could also direct to a external file, see module documentation, this way you only have to change that line when you want to update the jquery. However if you would replace the on with addEventListener then you wouldn’t have to import jquery at all. Your code wouldn’t have to change much at all since that method takes the same parameters.
                                  shashank @in_a_days
                                  @in_a_days hi, how can i change code to show more modules apart from clock, i need weather and calendar to show as default
                                  • I
                                    in_a_days @shashank
                                    @shashank
                                    So right now it hides all modules by default. If you want everything to show by default I think you just need to comment out a section from MM-navbar.js. These are lines 12 - 19 right now:
                                    Just open and close a comment around this section so it looks like this:
                                    /*notificationReceived: function(notification, payload, sender){
                                    And I think it should display all your normal modules on startup.
                                    • A
                                      @chrisyy thank you man, so let me get this straight: I find a button that I like on internet, I copy its code and I put it into the module?
                                      I’m sorry, but I’m kinda new to this :)
                                      • T
                                        tosti007 Module Developer @AlessandroRa
                                        @AlessandroRa No you will have to take a look at Font Awsome which is being used throughout the magic mirror. In the link you can find all the icons you can use. (someone correct me if i’m wrong)
                                          shashank @in_a_days
                                          @in_a_days Hi, My requirement is i need to show clock, weather and Calendar by default and all other modules should be hide.
                                          • T
                                            @all, I made a module which is similair to this one. In mine you can set custom profiles and swap between them. Hope that this helps one of you guys :)
                                            • 2 / 3
